Results 1 to 34 of 34
    Dec 08 2008
    New Jersey
    18 inch wheels for RS4
    I'm having difficulty finding 18 wheels/rims (winter setup) to fit the RS4. The main hurdle is an 18 rim that can clear the brake caliper. It appears that the concavity of the rim is the key factor in clearing the caliper for which there is no uniform measurement. I would really appreciate some help, I am looking rims (preferably black) that will work not those that should work as I have already taken that road and it leads nowhere.
    Veteran Member Four Rings jareds941's Avatar
    Jan 12 2010
    Jackson, WY
    TDR Pro Race 1.2 wheels. These are my track wheels. And many other owners. Offset is ET22-23 I believe. Run 275/35/18 on the track.
    Mine: 2021 Ford F150 PowerBoost
    Hers: 2016 Daytona Gray SQ5
    Previous:
    2004 E46 M3 Track Car
    2019 Daytona Gray S4
    2014 Glacier White S4
    2014 Glacier White SQ5
    2008 Daytona Gray RS4
    Active Member Four Rings BenSti's Avatar
    Nov 03 2010
    Cupertino, CA
    I've been running 18x10.5" Advans and 18x10" TE37's over 380mm rotors, they clear stock calipers and Stoptech calipers.
    Once I sell the TE37's, I am getting a set of matte blue Volk ZE40.
    2008 Audi RS4 Ibis White w/ Ti Package | 18x10.5 TCIII w/ 275/35 NT01 | PSI Raceline Ohlins | Stoptech Trophy Brakes F/R | Raybestos ST47 | OSGiken 1.5Way Rear LSD | Wavetrac Front LSD | Apikol Diff Mount | 034 Billet Subframe Bushings | 034 Motor Mounts | 034 Aluminum Trans Mount | 034 Spherical UCA | 034 Front Endlinks | JHM LWFW&Stage 4 Clutch | JHM Shifter+Linkage | Custom CAI | Custom Splitter | Hotchkis Sways F&R | Status Ring GT Seats + Half Cage | 034 Rear Endlinks | EBW LW Battery
    Dec 08 2008
    New Jersey
    Thank you, I'll check those out
    Registered User Four Rings Sales@DriveAuto's Avatar
    Apr 13 2012
    Clifton/Mountainside, NJ
    If you can find something in silver (or any other color), we can always powder coat them black for you. We've mounted a bunch of sets of snows on the TDR's; I think Tire Rack also has a TRMotorsport in an 18" that will clear.
    Oct 12 2010
    Keswick, Virginia
    I just PM'd you about a set of black TDR 1.2.
    Veteran Member Three Rings jstahmann's Avatar
    Feb 21 2005
    2008 RS4 - Imola/Titanium
    Utah, USA
    18x9 TDR 1.2s as Jared mentioned above. Run them with my winters as well as track tires. Mine are ET23.
    They were silver originally, but I painted them black later.
    John
    Piggie Pipes|Flowmaster 40s|Stasis SLs (800/1200)|Hotchkis Sways F&R|Suede Euro Steering Wheel|Apikol Rear Diff Mount|034 Track Transmission Mount|SilverRS4 PnP Intake|JHM IM Spacers|Status Ring Alcantara Seats|Euro Tails|Rotiform Forged SNA 19x10|285/30/19s|Bonneville 130 & 150 MPH Clubs
    RS4 REGISTRY
    Veteran Member Four Rings palewhitemale's Avatar
    Sep 22 2004
    MT
    Call Hartmann Wheels and see what they have in stock. You can usually choose from a wide variety of OE replicas
    I have a set of RS4 DTM 18" wheels that I've run two different Nokian options on both my RS6 and RS4.
    If you want a sport oriented winter tire, get some Nokian Hakka R2l
    2003 RS6 Avant, Goodwood Green/Black - Stock
    2018 Q7 Prestige, Glacier/Cedar - Stock
    2015 Q7 TDI Prestige, Carrera White/Espresso - Totaled @ 25k miles
    2015 Q5 TDI Prestige, Scuba Blue/Chestnut - Stock
    2001.5 S4 Avant 6sp, Stg III, Casablanca/Silver - SOLD
    2008 RS4 Avus/Black - SOLD
    2012 A3 TDI Monza/Black - SOLD
    2003 RS6 Sedan Avus/Black - SOLD
    2004.5 A4 Avant 1.8t - SOLD
    Veteran Member Four Rings Mistro's Avatar
    Jun 19 2011
    Quote Originally Posted by palewhitemale View Post
    I have a set of RS4 DTM 18" wheels...
    I've got these wheels as well for winter. I've seen at least one other rs4 using them too. They're et25 so they'll clear.
    http://shop.achtuning.com/Hartmann-H...eels-Audi.aspx
    Veteran Member Three Rings ktish's Avatar
    Nov 05 2012
    I have a nice set of Enkei's I'd be willing to work with you on
    http://www.audizine.com/forum/classi...-5-et35-160918
    Dec 08 2008
    New Jersey
    Mission Accomplished!
    [IMG][/IMG]
    Got the 18 inch winter wheels for the RS4
    Veteran Member Four Rings bshanna's Avatar
    Apr 22 2012
    94 MR2, 92 MR2
    denver
    Quote Originally Posted by BenSti View Post
    i'd be careful with 18s on the ZE40 - i have 19s (19x9.5et25) and they barely clear the stock calipers. i guess if you go x10 you'll be fine...
    OEM windshield sunshade, rear seat pet cover, microfibre clothe, official audi camelbak water bottle, beanie
    Nov 25 2014
    Quote Originally Posted by Coolshade View Post
    [IMG][/IMG]
    Nice - lookin good. What did you end up with?
    Dec 08 2008
    New Jersey
    I ended up with Motegi MR118s
    Mar 14 2014
    E46 M3 [sold] | Audi RS4 [sold] | 2010 GTI [sold]
    Northern Ohio
    what specs (I'm looking at wheel options now...)
    2015 Sepang S3
    APR Stage II [ ECU & TCU ] AWE SwitchPath Exhust | APR downpipe | Neuspeed RSe102 wheels
    Dec 08 2008
    New Jersey
    Motegi MR118 18x8 believe the offset was 45.
    Nov 20 2015
    Montreal (Qc) Canada
    Thank you so much for the advices! I really wanted to find 18 inches for my RS4. I just bought Team Dynamics Racing mags and they are perfect!
    Full specs:
    - TDR 1.2
    - 9x18
    - offset 23
    - Color: matte black
    - bolt patter 5x112
    - with hub-centric adapter for 57.1mm
    - Exact model number is 5M2-890235112
    Purchased them from www.perryautolaval.com in Montreal and got them in a week (shipped from Britain).
    Fitted them with studded Nokian Hakka 8 in 245/40/18.
    Note : you will need bolts with conical seats and 33mm shank instead of the OEM ball seat 28mm shank.
    Dec 03 2014
    here
    I've got a set of 18" Hartmanns for sale:
    http://www.panjo.com/buy/fs-set-of-4...5-et20-235300?
    Used these with some skinny Hakkas for a couple of seasons on my RS. Perfect!
    Veteran Member Three Rings HamidsVikes's Avatar
    Jan 10 2008
    Vancouver, BC
    why do you have to go with 18"?
    I run 19 with snows on my stock OEMs, and 20" for summers...
    any particular reason you want 18"?
    Nov 03 2010
    Cupertino, CA
    Far better tire choice. You can't get good performance tires in 19"+ without paying insane amounts.
    Veteran Member Four Rings Mc Suly's Avatar
    Aug 20 2010
    B7 RS4
    Québec
    Quote Originally Posted by Patch View Post
    Full specs:
    - TDR 1.2
    - 9x18
    - offset 23
    - bolt patter 5x112
    i have the same set! but i rattlecanned mine gunmetal! best part is they clear 380mm ROTOR! also i did a stud conversion, easier so dont gotta deal with lugs.
    i run 255/40/18 instead of 245. (oem spec)
    B7 RS4
    Active Member Four Rings wahpao's Avatar
    Nov 01 2006
    SNJ
    Does anyone know if OEM B7 A4 Ti rims would clear for the RS4. It's an 18X 8 with ET 43. I have also have 10mm spacers if that would make a difference.
    Mar 14 2014
    Northern Ohio
    Running Forgestar CF05 18x9.5 ET 26 with 275/35/18 summer rubber. I'm stock height and stock brakes. I do have a minor rub on the drivers side front when I load up the suspension on that side.
    2015 Sepang S3
    Veteran Member Three Rings Seattle squash's Avatar
    Jan 27 2013
    B7 RS4 + BMW E92 328i (modified a bit more)
    Quote Originally Posted by voidopolis View Post
    Did you take the fender clip/screw out on the drivers front? Might help you if you didn't.
    Jun 25 2008
    Cleveland
    Bringing this back from the dead. Anyone currently running 18" wheels on their RS4?
    Veteran Member Four Rings ven0m's Avatar
    May 10 2015
    Audi RS6 c7 (Avant), Audi RS4 b7 (Sedan), Audi A4 AllRoad b8.5 (Avant)
    Slovenia
    Running OZ Alleggerita 18x9 et25 for track. 9kg/rim in weight.
    Jeremy Clarkson: "So when you were saying that it won’t slide, what you meant was, ‘I can’t slide it.’“
    James May: "Yes."
    Oct 16 2014
    Running these (A5/S5) for both winter and track:
    https://www.audizine.com/forum/showthread.php/806135-18-quot-A5-S5-wheels-with-Blizzak-LM-32-900
    Veteran Member Three Rings blubusdrvr's Avatar
    Mar 02 2015
    1970 LT1 Corvette, 2017 A4, 2001 996TT
    Maryland, United States
    TDR Pro Race 1.2 are very nice. Light but pricey. I personally run Hartman DTM RS4's. They are light, strong, easy to clean and shed snow easily in the winter. Also no, they clear the brakes without spacers AND getting a second (conical) set of lugs isn't required. They use the stockers. The total combination led me to the Hartmans. (Gotta love those OZ's VenOm is running too!)
    Jun 25 2008
    Cleveland
    I'm assuming only a specific few different 18" wheel options actually fit the RS4? The Work Meister S1 caught my attention and I potentially like the idea of an 18" wheel and meaty tire look.
    Oct 16 2014
    Quote Originally Posted by B6UltraSport View Post
    I'm assuming only a specific few different 18" wheel options actually fit the RS4? The Work Meister S1 caught my attention.
    Yes few do and very fit w/o spacers
    Veteran Member Four Rings canadianA4B7's Avatar
    Feb 10 2012
    parts
    Napanee, ON
    I’ve got a set of TDR 1.2 18x9” ET 23 RS4 fitment I’m trying to move to a good home.
    I would trade for same set either 18X8” et 38 or 18x9” et 38. Or electronically transferred $$$
    Sep 04 2019
    San Jose
    Hello there, I know it has been many years. I am curious about your offset on the wheel.
    Veteran Member Four Rings b6bydesign04's Avatar
    Nov 14 2005
    Charlotte, NC
    Quote Originally Posted by CrazyYorkX View Post
    Which wheel are you referring to?
    -Sean
    '06 Lexus GX470 | Dobinsons | fifteen52 | BFGoodrich | Prinsu | Gobi | Orangeboxx | RSG
    '11 BMW E90 M3 | ESS S/C | Recaro | M Performance | iPE | BC Racing | BPM | Volk | Coby
    F.T.W.L.T.B.D.W.I.C.T.W.
    Junior Member One Ring frogracing's Avatar
    Jan 10 2025
    Huntington, MA, USA
    I am using OZ racing Wheels:
    And I also made wheel scrapers to protect the front calipers:
