So I subscribed to AllDataDIY (FYI used discount code renewDIY and you get 2 years for $12.95), and this is what I've found.
I've tried searching around for this Clutch Position Sensor, G476, but I haven't turned it up anywhere yet. May call the stealership and see if they have it listed for the B8s.
M/T - No Start Or Only Starts When Clutch Firmly Applied
30 Vehicle does not start or only starts when the clutch pedal is pressed very firmly
30 13 18
2028229/2
June 13, 2013
Supersedes Technical Service Bulletin Group 30 number 11-11 dated December 9, 2011 for reasons listed below.
Vehicle Information
Condition
^Customer may report that the vehicle does not start or only starts when the clutch pedal is pressed very firmly.
^The message "Press clutch pedal to start vehicle" may appear in the instrument cluster.
Technical Background
There may be clutch mechanism wear.
Production Solution
Not applicable.
Service
1.Check the clutch hydraulics and electrics as follows:
2.Depress the clutch pedal to the perceived end stop.
While the clutch pedal is depressed, have a second technician open the bleeder screw on the clutch slave cylinder.
^If the clutch pedal can now be moved further and the vehicle can be started, or if the message in the instrument cluster goes out, the sender of the clutch mechanism is correct. The issue is clutch mechanism wear; see the ElsaWeb Repair Manual for instructions. Do not replace the clutch master cylinder or slave cylinder, as doing so will not resolve this condition.
^If the clutch pedal still cannot be moved further, or if the message in the instrument cluster does not go out, check the operation of the Clutch Position Sensor -G476-.
3.Close the bleeder screw on the clutch slave cylinder.
Warranty
This TSB is informational only and not applicable to any Audi warranty.
Additional Information
All parts and service references provided in this TSB are subject to change and/or removal. Always check with your Parts Department and service manuals for the latest information.
