Originally Posted by
500HPS5
There are a couple of things that are going on that can contribute to the issue. Let me explain how the switch works, there is a plunger inside the master cylinder that has a magnet on it, the master cylinder in itself has three separate switches on it (as described earlier) which are activated when the magnet passes across the switch. I do not know that exact reason for failures, however I suspect that it is either
1.) The fluid in the circuit has air in it and is not allowing the plunger to move far enough to activate the switch or
2.) the magnet becomes weak and is no longer able to trigger the switch
You could try to do a full bleed of the clutch and remove all of the air out of the system, a vacuum bleed typically works best, or you can replace the clutch master cylinder. There is the possibility that the clutch master cylinder piston can have a bad seal too, this scenario will may keep the plunger from moving all of the way.
An air bubble in the system will let the piston move
further than normal, because the air compresses.....so that rules out an air bubble as the root of the problem. As per the Audi TSB, if something in the
clutch mechanism is worn, and binding-up, that is what prevents the full normal travel of the master cylinder piston, which then fails to trip the start-switch.
For people who resolved this problem by replacing the Master Cylinder, I suspect Audi revised this part to move the start-switch "in" a little, to require slightly less piston (and
clutch pedal) travel before the switch trips.
