Results 41 to 80 of 101
Hybrid View
    Senior Member Three Rings sh!tmagnet's Avatar
    Apr 22 2014
    Kelowna
    So I subscribed to AllDataDIY (FYI used discount code renewDIY and you get 2 years for $12.95), and this is what I've found.
    I've tried searching around for this Clutch Position Sensor, G476, but I haven't turned it up anywhere yet. May call the stealership and see if they have it listed for the B8s.
    M/T - No Start Or Only Starts When Clutch Firmly Applied
    30 Vehicle does not start or only starts when the clutch pedal is pressed very firmly
    30 13 18
    2028229/2
    June 13, 2013
    Supersedes Technical Service Bulletin Group 30 number 11-11 dated December 9, 2011 for reasons listed below.
    Vehicle Information
    Condition
    ^Customer may report that the vehicle does not start or only starts when the clutch pedal is pressed very firmly.
    ^The message "Press clutch pedal to start vehicle" may appear in the instrument cluster.
    Technical Background
    There may be clutch mechanism wear.
    Production Solution
    Not applicable.
    Service
    1.Check the clutch hydraulics and electrics as follows:
    2.Depress the clutch pedal to the perceived end stop.
    While the clutch pedal is depressed, have a second technician open the bleeder screw on the clutch slave cylinder.
    ^If the clutch pedal can now be moved further and the vehicle can be started, or if the message in the instrument cluster goes out, the sender of the clutch mechanism is correct. The issue is clutch mechanism wear; see the ElsaWeb Repair Manual for instructions. Do not replace the clutch master cylinder or slave cylinder, as doing so will not resolve this condition.
    ^If the clutch pedal still cannot be moved further, or if the message in the instrument cluster does not go out, check the operation of the Clutch Position Sensor -G476-.
    3.Close the bleeder screw on the clutch slave cylinder.
    Warranty
    This TSB is informational only and not applicable to any Audi warranty.
    Additional Information
    All parts and service references provided in this TSB are subject to change and/or removal. Always check with your Parts Department and service manuals for the latest information.
    Veteran Member Three Rings Legacykid's Avatar
    Mar 05 2010
    ATL
    Update on mine, The issue is offically back. At time i have to fred flintstone the pedal to get the car started. Its going in for service tomorrow. 55k miles I wonder if they will blame the clutch, because they mentioned it on the phone before I said i was only at 55k.
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    Quote Originally Posted by Legacykid View Post
    i did further digging into the issue as its the same as yours and there is another member also with the same issue.
    The clutch master is comprised of 3 switches in it!
    there is the F36 Clutch Pedal Switch that is used for cruise control
    there is the F194 Clutch pedal switch that triggers the "Press Pedal to start" part of the car
    there is the G476 Clutch position sender which from my understanding measures how worn the clutch is by the amount of fluid passing through the master.
    If anyone has further info on the G476 and how it operates, i would like to know as that is the problem my car has.
    You can use a Vagcom to measure the blocks of both the switches. its block 265(F194), starter control clutch switch and block 266(G476) starter control, interlock switch (may be a few numbers different depending on what version vag you have loaded)
    The last bit will change to a 1 when active.
    Both need to be "1" for the car to start.
    If you felt like bypassing the switch you can simply ground out the wire in the ecu box that gets triggered. blue gray is the F194 and green/gray is the G476. I haven't had time to physically measure the voltages at the wires yet.
    I will be interested in what Audi finds on your car. All the posts i read, the clutch is the final answer.
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Mar 05 2010
    ATL
    Quote Originally Posted by infinkc View Post
    Good to know
    Dropped of this morning, the dealerships tune changed once i got there. It went from yeah bring it in, its happened before and they have a TSB for it warranty doesn't matter. To Its coming out of my pocket. So If that is the case Im going to call AOA.
    Apr 22 2014
    Kelowna
    Good to know
    So any update, what happened?
    Mar 05 2010
    ATL
    Quote Originally Posted by sh!tmagnet View Post
    They ended up covering the repair. looks like they removed the clutch fork and replaced with updated one, also replaced fork pivot point and bearing. have not driven it much, but one of the times it did hesitate. will report back when i use it more.
    Apr 22 2014
    Kelowna
    I've just been giving it a little extra hard push lately and it hasn't really acted up that much. I plan to try the slave bleed to see if that helps(just been too damn busy lately). It wouldn't surprise me that they effed things up and got air in the system when I had the 45k service at Barrier in Seattle. Was disappointed with they're shody service overall.
    Mar 05 2010
    ATL
    Such a stupid thing to have to worry about on a car like this.
    Mar 05 2010
    ATL
    So it has occurred 2 times since i have come back to the dealer randomly. idk what the issue could be
    Nov 24 2012
    13 S4 / 10 Acura TL
    Atlanta, GA
    happened with me today, car has 15k miles, what could the issue be?
    2016 M3 MT/AW/Black
    Sold --2013 S4 MT/Glacier white/ Black interior/Premium Plus/ MMI/ Sports diff/ B&O/advanced key/ 19inch wheels/Carbon inlays/ supercharged badges/Euro Code Meisterwerk Shifter/ AWE exhaust with stock downpipes
    2010 Acura TL / Paladium silver/ black interior
    Mar 05 2010
    ATL
    Last time it was fixed for quite some time was when they replace the whole assembly. Fork and clutch master cyl. Because it's happening again
    Senior Member Two Rings salmjo1's Avatar
    Feb 11 2005
    Lynchburg, VA
    Add another to the list.
    55k miles (out of warranty)
    Car drives as it always has, no difference in feel of clutch.
    Have to stand on the pedal to get it to start. Interestingly, it does not say "depress clutch to start car", which makes me think it's the G476 clutch position sensor switch not kicking to "1".
    Sounds like the order of service is: bleed system; check function of both switches;
    would be great to know how to use G476 to test clutch wear. I hate to tear it apart for nothing.
    Of course if it is the clutch, I am (1) going to teach my 16 yo to drive on the thing now and then (2) upgrade the clutch and go to AWE/GIAC pulley and tune.
    Current:
    2011 S4 Sprint blue/panda, 6MT, Prestige w ADS. AWE exhaust and intake, Brembo 380 BBK, Alu-Kreuz, SRP pedals, VAG'd, Nurburgring sticker.
    2008 RS4 Cabriolet, Imola, PSS9s, Tubi.
    1983 Ur Quattro
    2007 RS4 Sprint Blue
    2004 S4 sedan, 6sp, Nogaro, milltek, PSS9s
    Plus 3 allroads of various flavors...
    Deactivated Two Rings
    Apr 22 2014
    Woodbridge, VA
    I had my clutch replaced at 55k with a JHM stage 3 with flywheel. I forget the term they used to describe the problem that prompted the replacement, but basically if comes from shifting to too low of a gear at too high of speed. Overspin, or something, idk.
    From shortly after getting the new clutch until now (66k) I have had to depress the clutch extra hard to get the car to start. I'm pretty sure this was not the case before the new clutch as that would probably would have kept me from buying the car. I have since taken it back to the shop that installed the new clutch and they attempted the master cylinder bleed option to no success. They plan to call JHM for advice. With that said it is hard to believe that clutch wear is the issue here since this was happening from installation of the brand new clutch.
    I doubt that the clutch fork is the issue since it didn't solve legacy kids issue.
    I think I will ask my shop if they did anything with the throw out bearing when installing the new clutch, as that seems to be a commonly mentioned factor in all these threads I'm reading.
    Mar 05 2010
    ATL
    Mine is acting up real bad again. Dreading bring it back in yet again for another issue. I feel like they will just blame the clutch.
    Apr 22 2014
    Kelowna
    So legacykid, is there any components in there that they haven't replaced? You said they replaced your master cylinder at one point, so I would assume its not a faulty G476 switch.
    As a thought, did they bleed the system properly by elevating the rear of the car sightly?
    Another thought, is there anyway to permanently assign a 1 to the G476 reading using VAGCOM. Essentially bypassing the switch through the software?
    Mar 05 2010
    ATL
    I do not know if they bled the system in that manner or not. They have replaced a lot, hopefully at the end of the week or next I will bring it in.
    Idk about the Vag Com, i do not have one but Id be curious if anyone else could check that out.
    Apr 22 2014
    Kelowna
    Forgot to mention, I'm going to be doing my Eurocode clutch kit here soon. Wondering if there's anything else I should consider replacing while I'm in there?
    Dec 08 2006
    Newark, Delaware
    Mine is doing it too.
    At first i thought i wasn't pushing the clutch down far enough - which would be weird since i been driving a manual car for almost 30 years.
    What i have noticed is that it does the needle sweep/no start moreso when the car is cold/been sitting/not driven - like first thing in the morning i go get in it and have to double press - always starts on the 2nd try.
    second weird thing i noticed, again with car relatively cold/recently started - i pull up to a red light, clutch pedal NOT pushed in, car not in gear - then i push in clutch and put car in 1st gear and get ready to go and i hear my engine rev up a little (AWE exhaust, so easier to hear this) - i look down at the tachometer and the needle is sitting at 1250 RPM, instead of the usual idle around 750 RPM.
    I dunno whats wrong. my car only has 31000 miles, and not tracked and not riden hard or rough, and clutch feels good otherwise. mine is scheduled into the stealer on may 1st.
    anyone else with the double clutch press to start car issue also have the RPMs up a little? anyone else notice it more when the car is cold/sat for a while?
    Jul 17 2012
    Colorado Springs, CO
    Quote Originally Posted by pairadocs View Post
    Another one to add to this list. I am having the same issue of having to press the clutch pedal very hard to get the car started. It comes up saying "depress clutch to start car". If I press hard enough it will start. I also had the exact same issue as you pairadocs where I was sitting at a red light and my engine reved up to 1250 RPMS without pressing on gas. I have seen this issue numerous times. I took it in for service and they replaced the Throttle Body and it seemed to lessen the frequency of the issue, although I have seen it about 1 time in 5 months since them. Before the replacement of the Throttle Body, it was doing it almost every day.
    I took my car to a shop here in town and they followed TSB 2028229/2 (as listed above on this page). After they did the bleed test, the issue seems to be partially resolved. It still requires about 10% more force on the pedal to start but no where near as bad as it was before. So this is encouraging in some ways.
    I have my car going into Audi tomorrow to see if they will cover whatever the issue is under warranty. I will post my results once they diagnose. This whole issue has been extremely frustrating since my car only has 23K miles on it.
    2016 Audi RS7 Prestige - KPMF Matte Iced Blue Titanium - Akrapovic Exhaust - RocEuro Intake w/Spectre Air Filters - Whats next?
    Established Member Two Rings S4_V6T's Avatar
    Jan 24 2013
    Dunfermline/Fife/Scotland/UK
    Have you had your car tuned? It may be the cold start feature that is raising your RPMs. With regards to the clutch pedal issue from personal experience of having the transmission out 3 times now I would say that it is the clutch fork that was the main culprit for me each time. I did replace the clutch and added a LWFW for good measures as well and have change the master slave twice also.
    It seems like the clutch fork bent twice for me and was causing the issue of the clutch pedal failing to register being depressed and I really needed to put a lot of pressure to start the car. This in turn killed a couple of master slaves.
    So far so good for the last install but I am just waiting for it to go again!
    Nov 24 2012
    13 S4 / 10 Acura TL
    Atlanta, GA
    After 9 months i got the issue again last friday for few mins . Initially when i had reported the issue dealer bled the clutch and things were fine.
    Any clue how to fix this damn message ?
    2016 M3 MT/AW/Black
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    Sep 24 2014
    Central NJ
    So, here is a fix idea:
    From pictures of the clutch master cylinder, it looks like is has a rubber gasket (grey ring on black cylinder body) between it and the firewall (on the engine compartment side). If you remove the gasket, or use a thinner one, then the master cylinder internal piston will be moved a little further into the bore when the clutch pedal is fully depressed, which might be the extra 3 or 5mm needed to get the start-switch to trip.
    Maybe remove the gasket and use some RTV to seal against water entry....if it doesn't work it is easily reversible.
    https://www.ecstuning.com/Audi-B8_S4...lic/ES2832727/
    Jul 17 2012
    Quote Originally Posted by S4'ed View Post
    The link to ECS tuning does not work. Can you provide some more detail as to how I could try this fix? I would like to try it on my S5. It would be great if I could fix a fix instead of replacing the clutch since that's what Audi says is the issue.
    Sep 24 2014
    Central NJ
    Quote Originally Posted by footbllpro30 View Post
    I am not sure how to give you any more detail on how try this.......but it might go something like this:
    Under the dash, remove the cylinder endlink from the clutch pedal, then remove the U clip (?) that holds the cylinder to the firewall. In the engine compartment, pull the cylinder forward, out of the mounting hole, and remove the rubber washer, then re-install in reverse order.
    As for the link, goto ECStuning.com, enter your car info as a Audi S4 B8, select drivetrain, then clutch, hydraulics, and select the master cylinder to look at the picture......
    Apr 22 2014
    Kelowna
    Update: I know I started this thread and then disappeared, but that's what has happened for the last 6-8 months. Either muscle memory is pushing the pedal harder and I'm not noticing or the problem just went away. I know that doesn't help give a definitive answer. But its been fine for a while. I even installed the USP clutch line and its still starting fine.
    Now I just had an idea, maybe that delay valve that the USP line bypasses could help remedy this issue?
    Apr 22 2014
    Kelowna
    As a side note, when I was in changing this line out, the "sensor" on the clutch master cylinder can actually unclip (not the wiring but the actual sensor) from the master cylinder even though Audi doesn't sell it separately, or list it as a separate part.
    Veteran Member Three Rings E.Anderson's Avatar
    Jun 23 2010
    Oswego, IL
    I just got a brand new clutch master cylinder from the dealer under CPO. Even before my car left the dealer they told me that this is not resolved the issue and the next step would be to replace the clutch @ $5,100
    I was also given the option of taking a gamble, paying them 15 hours of labor @ $155/hr to inspect the transmission and figure out if the issue is or isn't clutch related. Really something that shouldn't be the onus of the customer
    2021 S4 | PREMIUM PLUS | MYTHOS BLACK | ALU OPTIC | SPORT DIFF | B&O | LEATHER
    Previous
    2018 S4 | PREMIUM PLUS | DAYTONA GREY | BLACK OPTICS | SPORT DIFF | B&O | LEATHER | JB4
    2011 S4 MT6 | PREMIUM PLUS | QUARTZ GREY | TITANIUM PACKAGE | ROC EURO | LED INTERIOR | SPORT DIFF | B&O | LEATHER
    2008 A4 SE
    Feb 25 2014
    Texas
    I am getting the same error 600 miles after having a Eurocode stageIII clutch and LWFW installed. It says engage clutch to start engine and I practically have my foot through the floor. Still no luck.
    To all who have had this issue, what has remedied the situation? New clutch fork, master slave, or simply the sensor?
    Mickey (AKA: AudiS4B8)
    Instagram: ze_nardo6
    10.65 @ 129mph
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    Quote Originally Posted by AudiS4B8 View Post
    Same here. Brand new JHM stage 3 clutch and lwfw, 300 miles later, won't start unless I stand on the clutch pedal. Dealer immediately wanted to blame the new aftermarket parts that THEY installed. I'm hoping to get into a REAL shop soon and get it taken care of, but from what I've read, it's master cylinder.
    2021 Audi S4, P34 Intake
    Sep 24 2014
    Central NJ
    I don't think there is a permanent "fix" for this yet from Audi engineering, but see my proposed fix in above posts #62 and #67.
    Feb 25 2014
    Texas
    thanks!
    10.65 @ 129mph
    Jun 23 2010
    Oswego, IL
    I had my master cylinder replaced at the dealer. It has only been 2 days but I haven't reproduced the problem....yet
    Previous
    2008 A4 SE
    Feb 13 2004
    S Ã C, CÃ*
    Quote Originally Posted by E.Anderson View Post
    xing fingers, i think im going to change mine out soon also. I wonder what downsides bypassing the switch would actually do, since there is the secondary switch still that wont allow the car to start.
    Jun 23 2010
    Oswego, IL
    Although this has made the issue less pronounced, it has not completely fixed it. I don't have to press as hard as before, but I will still get the warning (especially when it's cold). Unfortunately i'm not going to pay for a new clutch at this time so I will just deal with it until it's time for a new one.....Or sell the car
    Previous
    2008 A4 SE
    Sep 24 2014
    Central NJ
    Anybody want to sell me your old master cylinder? I will paypal you $20 to ship it to me.
    Veteran Member Four Rings DGVR6's Avatar
    Aug 03 2014
    Queens
    I'm actually have the same problem, when I pulled codes out I got the same exact one.
    Both key and car battery are new.. Doubt it's the key..
    I guess the problem is still unknown ..
    C7.5 S6 P+ Mythos Black
    [email protected] 103oct Stage 2 100 File/RACECHIP
    [email protected] 100oct Stage 1 93 File
    APR Tuned Stage 2 ECU/TCU | Roc Euro | Catless Downpipes | Milltek Resonated
    Previous
    B8 S4 [email protected] 93/e85 93 map - Unitronic Stage 2 B8 S4 6MT
    Veteran Member Four Rings Thurston's Avatar
    Apr 27 2015
    canada
    Well I guess I won't be upgrading my clutch anytime soon until the cause of this little issue is figured out - I'm sure it will happen to me as well.
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    There are a couple of things that are going on that can contribute to the issue. Let me explain how the switch works, there is a plunger inside the master cylinder that has a magnet on it, the master cylinder in itself has three separate switches on it (as described earlier) which are activated when the magnet passes across the switch. I do not know that exact reason for failures, however I suspect that it is either
    1.) The fluid in the circuit has air in it and is not allowing the plunger to move far enough to activate the switch or
    2.) the magnet becomes weak and is no longer able to trigger the switch
    You could try to do a full bleed of the clutch and remove all of the air out of the system, a vacuum bleed typically works best, or you can replace the clutch master cylinder. There is the possibility that the clutch master cylinder piston can have a bad seal too, this scenario will may keep the plunger from moving all of the way.
    Sep 24 2014
    Central NJ
    Quote Originally Posted by 500HPS5 View Post
    An air bubble in the system will let the piston move further than normal, because the air compresses.....so that rules out an air bubble as the root of the problem. As per the Audi TSB, if something in the clutch mechanism is worn, and binding-up, that is what prevents the full normal travel of the master cylinder piston, which then fails to trip the start-switch.
    For people who resolved this problem by replacing the Master Cylinder, I suspect Audi revised this part to move the start-switch "in" a little, to require slightly less piston (and clutch pedal) travel before the switch trips.
