Page 2 of 4 FirstFirst 1234 LastLast
Results 41 to 80 of 134
  1. #41
    Veteran Member Four Rings Meow's Avatar
    Mar 08 2012
    MI
    Quote Originally Posted by urS4 View Post
    I love this thread. I've also got a 770 car.
    The engine internals were fully balanced and the flywheel was lightened and knife edged. The 2.8 heads were ported and larger valves added. Solid lifters and custom cams round out the top end work. The intake is a custom RS4 manifold with an enlarged plenum and drive by cable throttle body pulling through Apikol SMICs with NOS serpentine I/C spray system feeding ID1200 cc injectors fed by a custom fueling system comprised of an Aeromotive in tank fuel pump feeding the surge tank and an external SX Performance 18203 fuel pump feeding -10 lines to the custom fuel rail. Engine management is provided by an 034 Iic system which allows maf-less operation.
    The car did pull 620 hp at the wheels on a very conservative tune with E85.
    This sounds about right. Sounds like a very solid fun car for agressive street driving and mild track duty. 620awhp is realistic and appropriate for those turbos on a mild e85 tune on a standard mustang dyno.
    RIP Daz, you will be missed.
  2. #42
    Mar 08 2012
    MI
    also, dynos sucks, here is why.
    Each dyno can be calibrated differently so internet braging rights are dumb.
  3. #43
    Senior Member Two Rings MassS4B5's Avatar
    Jun 01 2007
    Stage 3 B5 S4
    east coast
    I only have 518 whp 2.7 heads no methanol EPL tune. wish it was much more though
    Black S4 6 speed
    Vast built motor w/ cams, valve springs, rods, clutch fan delete, electric fan, tial 650's, rs4 ic's, x-1 intake, cm stage 4 clutch, light weight flywheel, hb dv's, efu 4u, zoldman 02's, avalon ock, stasis track sports, stasis motor mounts, oem trans mounts., asp tsb, asp 3" down pipes, asp true dual
  4. #44
    Veteran Member Three Rings ama's Avatar
    Oct 02 2013
    World
    Quote Originally Posted by MassS4B5 View Post
    fuel? 2 bosch 044?
  5. #45
    Oct 27 2011
    TOYS
    Philly Suburbs
    You just need some corn in your life. She would wake right up!
  6. #46
    Dec 14 2008
    Finland
    The question is how fast your car is. I only made 490whp with N/A heads, meth, etc EPL tune and wish I would have got a tune I paid for. Money was well acceped but only a few revision was given.
    World's Fastest B5 Avant biturbo Full Weight
    With Race Seats @3800lbs
    TTE950+ 100-200kmh 3,81s
  7. #47
    Active Member Four Rings landfill's Avatar
    Nov 14 2013
    Pompano Beach, Florida
    ^^^For 605's 490awhp isn't bad on a stock
    motor and decent tune. If your a built motor
    I would expect EPL or whoever your tuner is
    to get you some files above 500awhp. I'm
    guessing you don't have good support from
    tial and epl from across the pond.
  8. #48
    Mar 22 2013
    AK
    I love this thread. I've also got a 770 car. This car was not built to run quarter miles but was built as a track/aggressive street car. At one point I thought it was gonna be a Stasis poster car. The rear diff was rebuilt with cryo treated internals and limited slip. All 4 axles were given the full race treatment by CVJ axles. The transmission was rebuilt with cryo treated close ratio gears and limited slip. the center diff was given the 4:1 massage. A lightweight steel flywheel and custom race clutch were sourced from Southbend. The engine internals were fully balanced and the flywheel was lightened and knife edged. The 2.8 heads were ported and larger valves added. Solid lifters and custom cams round out the top end work. The intake is a custom RS4 manifold with an enlarged plenum and drive by cable throttle body pulling through Apikol SMICs with NOS serpentine I/C spray system feeding ID1200 cc injectors fed by a custom fueling system comprised of an Aeromotive in tank fuel pump feeding the surge tank and an external SX Performance 18203 fuel pump feeding -10 lines to the custom fuel rail. Engine management is provided by an 034 Iic system which allows maf-less operation.
    The rest of the car has similar attention to detail which provides a very precise driving experience. The car did pull 620 hp at the wheels on a very conservative tune with E85. This is enough to provide a spirited drive without being edgy. I always do have the ability to call up more but I'm happy the way things stand. What a great car and experience.
    Hap, wit dakine driving thoughts from Vadaboost, Maguire
    Can you clarify, a crank can be knife edged but not a flywheel
    Solid lifters ? What's your valve lash adjustment intervals ? Who did the conversion , are you running Cat cams and how far beyond 8k are you reving ?
  9. #49
    Dec 14 2008
    Finland
    Quote Originally Posted by landfill View Post
    I have 770 and fully build engine. I can't say I get good or bad support from EPL, I don't get any support. Latest revision (3rd rev) worth mentioning is from December 2013.
  10. #50
    Oct 27 2011
    TOYS
    Philly Suburbs
    Quote Originally Posted by Mikse View Post
    Did your car have issues or something that was making tuning difficult? Sounds weird that they would just stop supporting you if your tune wasn't done.
  11. #51
    Established Member Two Rings S4Matt's Avatar
    Jan 23 2014
    2001 Tial 770 S4, Stockish 2000 S4, 2013 Rubicon Unlimited, 2011 Elantra
    Shippensburg, PA
    Get a hold of Josh at Solo. He has bent over backwards tuning my 770 car. Like 10 revs in at this point (fine tuning), and offers suggestions when the car doesn't respond like he anticipated. I can't say enough about Josh. Good dude.
  12. #52
    Dec 14 2008
    Finland
    No bigger issues. After Dave left from EPL so did their customer service. Some revisions had some weird behaving, timing curve could be better especially in the summer, every tuner can make decent timing curve when doing pulls on winter. I lost my hope getting tweaks maybe 4 months ago. I'm running on 27,5psi and have asked more duty, asked to lower the rev limiter from 8200rpm etc. and haven't got even a reply.
  13. #53
    Veteran Member Three Rings urS4's Avatar
    Feb 03 2007
    93 urS4, 99.5 A4 1.8tqm
    Arvada CO
    Quote Originally Posted by Drehmoment View Post
    Questions, questions. Olde Skewl hot rod tech. Knife edging the crank has nothing to do with the flywheel. Its all about less parasite drag and lower mass to spin up. After the modification, the whole lot of rotating pieces were balanced. My mechanic Dave Jones did all the building. He determines the adjustment intervals. I also have solid lifters on my I-5 AAN 2.5 stroker. The cams are custom proprietary cams specifically ground for this application. Right now the soft rev limiter is set for 8250.
  14. #54
    Mar 22 2013
    AK
    Huh, you can't knife edge a flywheel....there are no counterweights on it and it is dry not wet... One more time you said your flywheel was knife edged which is impossible ....lightening it yes and balance the recip mass , sure.
    Knife edging means reducing slosh created ( "cutting " better thru the oil sump in lay mans terms) by machine edging the counter weights which also reduces crank weight
  15. #55
    Feb 03 2007
    Arvada CO
    Sorry guys. My mistake. I meant to say the crank was lightened and knife edged. Humble apologies.
  16. #56
    Mar 22 2013
    AK
    No problem
    Do you know how much the machine shop took off and what was the final weight?
    That is a great build you got there and to the best of my knowledge the first knife edged crank on this board.
  17. #57
    Nov 14 2013
    Same on my 3L crank. Can you supply the name of the company who made your 2.7t cams by chance?
    I'm using the smallest CAT variant (264/250) with the oem hydro lifters which I really regret. I didn't
    know that CAT UK made cams for solid lifters all the way up to 291/278 or 279/278. At the time I made
    that decision it was before I decided to go all out and I didn't want to mess with valve lash adjustments.
  18. #58
    Feb 03 2007
    Arvada CO
    No problem
    I should mention that the car was built by the mechanic who works on my other car, a urS4. It was built at the same time mine was for a mutual friend. I bought the car from that guy about a year ago so I now support 2 hot rod Audis. I therefor don't have all the pertinent information. You ought to see all the other details on this build.
    The urS4 is getting a billet stroker crank and has put down 755hp at the wheels. This newest build should see it at 850+ at the wheels.
  19. #59
    Nov 14 2013
    Yea I'd say your doing things just right. On my bucket list
    is a urs4 with a 2.7L stroker fully built with at least 70mm or
    more of turbo.
  20. #60
    Feb 03 2007
    Arvada CO
    more of turbo.
    Da Green Monstah:
  21. #61
    Mar 22 2013
    AK
    I think "Monster" is a understatement ...
  22. #62
    Nov 14 2013
    Lovin all the polished goodness under the hood. Also are you running dual exhaust on your Ur?
    Pretty interesting considering I've never seen a c4 chassis with a dual setup. Also 19's or 18's
    on her? They look pretty big. I had 16's on my ur lol.
  23. #63
    Feb 03 2007
    Arvada CO
    [QUOTE=landfill;10290017]Lovin all the polished goodness under the hood. Also are you running dual exhaust on your Ur?
    on her? They look pretty big. I had 16's on my ur lol.[/
    Single 3 1/2" that splits to dual 3 1/2 that necks immediately to dual 3". The problem was a lack of 3 1/2" muffler choices. Those are 18s required by the 355 brakes up front. I had the same 18" challenge on the B5.
  24. #64
    Nov 14 2013
    Damn she's clean even underneath. Mine came from delaware which says it all.
  25. #65
    Feb 03 2007
    Arvada CO
    I've owned her from new in Colorado.
  26. #66
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Also are you running dual exhaust on your Ur? Pretty interesting considering I've never seen a c4 chassis with a dual setup.
    This is not possible on a 5 cylinder turbo car. Or any single turbo car for that matter. And equally not likely on a car with an odd amount of cylinders, but I guess possible.
    It is pretty neat to see what you S4 guys are putting down. Makes me feel like my tiny 320awhp from my 4 banger is weaker than all hell.
    Here's a good question for you guys- anyone have first hand experience on fully built 2.7 versus 2.8/3.2 vr6?
    2020 SQ7- Wife's ride
    2008 RS4- I like this car
    2000 S4- Working?
  27. #67
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Max whp ever made with Tial 770
    Quote Originally Posted by redline380 View Post
    How do you figure? I mean, obviously you're only going to have one downpipe initially off of the turbo, but you can then split into dual which many cars do.
    Sent from my iPhone 6 using Tapatalk
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
  28. #68
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by LINDW4LL View Post
    Well sure, I could make a quad exhaust coming off a weed whacker if I wanted to.
    Dual exhaust means one, separate pipe for each bank, assuming only two banks. I can split one pipe into however many I want, but that doesn't make it dual/quad/whatever.
    2000 S4- Working?
  29. #69
    Nov 14 2013
    Alright if you want to overanalyze my statement I guess you could. In the urs4 world there is only one
    exhaust outlet on the left side of the rear bumper. He has a dual exit setup with one muffler on each side.
    Yes I realize it's all coming from one down pipe off an inline motor your not informing me of anything new.
    I've owned 2 of those cars. People have also done this to b5 a4 1.8t's and b5 s4's. So yes it's very possible
    to have a dual outlet exhaust on any car you choose. Just not a TRUE DUAL!!! Use your search bar.
  30. #70
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Alright if you want to overanalyze my statement I guess you could. In the urs4 world there is only one exhaust outlet on the left side of the rear bumper. He has a dual exit setup with one muffler on each side.
    Well now that you elaborate I get where you are coming from.
    2000 S4- Working?
  31. #71
    Established Member Two Rings Maruzen75's Avatar
    Jan 19 2010
    [/QUOTE]
    You have by far the coolest urs4 I've ever seen I'm jealous sir...
    Who powdercoated your wheels and what color are they? Only reason I ask is that I have the same exact wheels on my s4 and I want them refinished just like that
    Nogaro stage III
  32. #72
    Feb 03 2007
    Arvada CO
    Quote Originally Posted by Maruzen75 View Post
    Who powdercoated your wheels and what color are they? Only reason I ask is that I have the same exact wheels on my s4 and I want them refinished just like that[/QUOTE]
    Why thank you sir. Those are actually hand polished. I do have another set of the Koseis on my B5 S4 for winter wheels and they are powder coated. They came out almost as good as the polished ones. Take a look. The were done by Spec wheels in Denver, CO.
  33. #73
    Registered User Four Rings
    Sep 01 2013
    Sweden
    Are you running a 551K RS4 box?
  34. #74
    Dec 14 2008
    Finland
    No, originally D-box with M-box tune. Why ask?
  35. #75
    Veteran Member Four Rings UkuRiSh's Avatar
    Jan 09 2010
    New York
    anybody in tri-state area with Tial 770 or similar wanted do couple friendly pull on highway?
    2013 AUDI S5 4.0T SWAP 9.7@145mph < Press @svarog_performance < last test updates
  36. #76
    Sep 01 2013
    Sweden
    You got PM!
  37. #77
    Mar 08 2012
    MI
    Ahhh semantics... to most people dual exhaust just means two exit points at the rear bumper. Nothing to do with the true duals off each side of the motor. Almost all dual setups like that have x pipes or h pipes to cross flows.
  38. #78
    Veteran Member Three Rings y3ti's Avatar
    May 25 2014
    Long Beach, CA
    We need some Audizine 'I heart semantics' stickers made.
  39. #79
    Veteran Member Four Rings Reich's Avatar
    Oct 14 2007
    2001 s4 ; 2001 jetta tdi
    Val-Belair
    Here's mine with massive missfire. Yeah I know, I should have done 2tsi coils upgrate before. Anyway, the low MPH is due to missfire at high load in 4th gear. So that11 flat run was done in 5 gear to keep rpm below 5000 rpms where it would start missfire. 1,2,3 was correct which gave me good times.
    This is not the 11 flat run in the video down below ,as I was filming ;-). A friend of my was driving my car in this run.
    but still 11.46 with massive missfire.
    I use to run 129-131 mph quatermile when not missfiring. But anyway, it gives you an idea of the torque.
    Listen to hoosier drag radials spin in second gear!
    https://www.youtube.com/watch?v=mA0riuad0wk
    Last edited by Reich; 12-01-2014 at 07:36 AM. Reason: did the 11 flat in 5 gear to prevent missfire
    Rombotis built and EPL tune 770r 3L = best
  40. #80
    Feb 05 2014
    BROOKLYN
    Quote Originally Posted by Reich View Post
    Here's mine with massive missfire. Yeah I know, I should have done 2tsi coils upgrate before. Anyway, the low MPH is due to missfire at high load in 4th gear. 1,2,3 was correct which gave me good times.
    I was just about to congratulate you on the 11.46 pass that your car did, but then I saw the excuse of why the car didn't do better. Please stop with the excuses.
