Results 1 to 6 of 6
    Active Member One Ring CGramme's Avatar
    Oct 29 2014
    Atlanta GA
    Which vag-com to get?
    Hi, I am a new audi owner and I don't think I can live without vag. Any recommendations on which one works the best and/or is cheapest? I have seen the system for sale on the web for under $40... Will these cheap systems do everything the more expensive systems do? Thank you very much for your advise!
    Chris
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Hey Chris, welcome to the Audi world.
    The best option is the genuine RossTech HEX-USB+CAN cable. It is not the cheapest option by any means, but they do hold their value very well so you'll get most of your money back when you sell the cable in the future. You may also be able to find someone who is selling their used one.
    The knockoff eBay cords will work but are sometimes iffy and do not come with a VCDS license, so you'll need to buy that for $100 on top of the cable price. There are also several limitations, even with the registered verison of VCDS Lite.
    No Generic OBD-II
    Won't work with CAN-Bus vehicles
    Fewer fault code definitions and label files
    No built-in Activation (you'll be limited to a single PC)
    No Advanced Measuring Blocks
    No Acceleration Measurement
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Oct 29 2014
    Atlanta GA
    Thank you for your response, LINDW4LL! This is exactly the information I was looking for.
    Veteran Member Four Rings JerseyShoreA4's Avatar
    Jun 17 2007
    2013 B8.5 allroad (current) 2007 b7 a4 (previous) 2006 vw touareg (previous) 2003 b6 a4 (previous)
    Ummm the Jersey Shore
    Glad I came across this. If I were to download the free version of vcds lite using my old ebay cable, would i atleast have the option of changing the up down feature of the windows and change my car to rest of world to run the fogs and parking lights mod on my b7 and turn on the hid setting on my touareg since it came with halogen and the drl really mess with the aftermarket hid. I'm not necessarily looking to run any logs on the car at the moment. Just want the conveniences I had on my old car.
    Miss my B6
    Dec 10 2011
    CLT | MKE
    I believe you need the registered version of VCDS Lite to do that ($99 license).
    There may be cracked full versions of VCDS available on the web as well, although I don't condone use of such programs.
    Sent from my iPhone 6 using Tapatalk
    -Hayden
    Veteran Member Three Rings svra42.8's Avatar
    Oct 11 2006
    Bartlett, Illinois
    I use this one. 100% works flawless except there are some newer software versions out now. I have not tried to update it since I do not want to risk my cable not working in the future.
    http://www.aliexpress.com/item/Free-...003208489.html
    2021 Glacier White/Carbon Optic RS7
