Page 3 of 22 FirstFirst 1234513 ... LastLast
Results 81 to 120 of 865
  1. #81
    Mar 26 2010
    US
    BMW M3 Competition X-drive
  2. #82
    Feb 13 2004
    Silicon Valley, CA
    Quote Originally Posted by wwhan View Post
    I remember stocking Cherry Bombs when I worked at Pep Boys in high school a long long time ago. Forgot about those until this post
    Kevin - Moderator, Audizine
  3. #83
    Veteran Member Three Rings MerkurRS's Avatar
    Oct 04 2012
    Four Passat W8's, 2003 allroad 2.7t , Ford Excursion Ltd V10, 1989 Merkur Scorpio, 1987 Merkur XR4Ti
    Berthoud, CO
    Quote Originally Posted by Stubek View Post
    Yes- I remember those too, and the when the packing blew out of those is when the neighbors complained to your parents. So, it a nut shell- crappy fiberglass packing is nothing new. See how trends recycle? Maybe whitewalls will come back soon.....
    2012 Audi S4 Prestige Glacier White, Alcantara Leather, Titanium/ Black Optics Pkg, Auto/ Driver Assist/ Drive Select/ B&O/ Carbon Inlays, UltraCharger, APR Carbon Intake, Flat-bottom Wheel, 3G+Google Map conversion, Passport 9500ix red/carbon limited edition, Michelin A/S 3's, Armytrix/ Custom Exhaust, Spulen Diff Mount, 034 Trans. Insert, Eurocode Alu-Kreuz, ACNA Member
  4. #84
    Senior Member Three Rings AQuattro's Avatar
    Aug 08 2004
    P1
    Quote Originally Posted by crew219 View Post
    Eh?
    I'm simply saying that your analysis of a properly packed muffler is incorrect. There should be no gaps. It should be packed tightly with fiberglass.
    http://www.supertrapp.com/images/pdf...acking-FAQ.pdf
    I see. Since you simply said "no, not at all" I figured you were dismissing my entire statement. Some gaps using pre-filled bags are inevitable, but the bags should contain enough volume for the entire can so the fibers will fill most of it once the bags burn away. It's interesting that the picture in your link shows the inferior short fiber e-glass packing I mentioned. It appears Supertrap may not be the best authority on the subject. OE's and any respectable aftermarket manufacturer now use continuous length, high temperature fiber that won't blow out or melt.
  5. #85
    Veteran Member Four Rings mr shickadance's Avatar
    Jul 08 2010
    tucson
    danbury
    this is pretty shitty for APR for sure. I mean based on the information present, if it was an internal APR worker that released these photos bc they are dealing with supplier issues than they should have pulled the product.
    I can certainly understand switching from one stainless steel to another lower grade, i mead, read up on the lower level, it will have surface rust, but it will not penetrate and degrade over time. exhausts are not rocket science here, it's a tube connected to another tube. As the costs of metal increase, as a business you want to keep the same margin without having to raise prices (despite a price hike in 2013, also a head scratcher)
    either way, they clearly know that they are selling a product mislabeled and had absolutely no problems doing so for quite some time now. That for me, is unacceptable, as stated, I can totally get swapping metals or using cheaper materials as long as it provides no difference in the end product (surface rust on something that will never be seen unless you literally crawl under the car is not a difference in my opinion, but im sure a few of you might feel differently)
    but lying to your customer based flat out and for so long is absolutely something i will never stand behind. If APR comes out and claims this was an internal issue and they are dealing with it then why are still selling the exhausts? i mean seriously, pull the product, explain whats going on and start accruing for what it surely going to be some sort of lawsuit coming you way for selling a product like this.
    [CENTER]Scott
    2011 S4
    America is all about speed, hot, nasty, bad-ass speed - Eleanor Roosevelt
  6. #86
    Veteran Member Three Rings PSUGOLD's Avatar
    Mar 10 2014
    Philly Area, PA
    WOO WOOOOOOO
    2016 Daytona Grey Pearl Effect crystal effect , Sports Diff, Adaptive Suspension, Carbon Atlas inlays, Borla Cat Back, DS1 Stage 1 w/ Boosted Euro TCU.
  7. #87
    Jul 08 2010
    tucson
    danbury
    Also to anyone doubting the photo of the cut open resonator I would like to cast my vote to thinking this is authentic. Why? because in order to cut into the resonator you need some sort of dremel tool which cutting the metal would produce some metal by product which is clearly seen on the fiberglass packing in the photos. If they cut it open removed the RSC and placed the packing in there you would not see this, either that or it's an incredibly well thoughout dig against APR
    [CENTER]Scott
    2011 S4
  8. #88
    Feb 25 2013
    MI
    Quote Originally Posted by mr shickadance View Post
    According to crew, who has *not been proven wrong* on anything he's said in the past 4 months (note I didn't say verified to be correct on everything), the pictures were taken by APR
    http://*******************/forum/ind...86038#msg86038
  9. #89
    Senior Member Three Rings boseephuss's Avatar
    Dec 02 2013
    2000 Dodge Durango (5.9L), 2012 Volvo XC60 T6 (Polestar), 2009 Kawasaki Vulcan 900 SE, Jet Boat
    Houston, TX
    Still no APR folks chiming in. For my own selfish reasons I wish they would, but it's best to leave these alone. Neither confirm or deny. That said, +1 for Borla!!! LOL
    2011 Premium +, Meteor Gray Pearl Effect, DSG, Roc Euro, Borla, Eurocode ÜSS, Eurocde Alu Kreuz, Alpha Boost Cooling System, EPL Stage II, EPL TCU Tune
  10. #90
    Jul 08 2010
    tucson
    danbury
    Quote Originally Posted by drob23 View Post
    http://audirevolution.net/forum/inde...86038#msg86038
    yea i saw that, i have a hard habit of being pretty skeptical on anything i see (previously was in public accounting, anyone in that line of work will pretty much share the same line of thought) so i look for other things that would be confirming. It's why i am such a pain in the ass when people come out and make claims against a vendor/product/other member. They need to have the proof to back it up in my opinion and so far 'Crew' has done exactly that.
    Look, I know what it takes to run a somewhat small business like APR, having to deal with overseas suppliers and factories and getting the same line of quality day in and day out is an insane struggle that not many people realize. when you have your suppliers overseas, they are also trying to make the part for the cheapest amount of $$ possible and if you don't have good quality control at HQ a supplier will absolutely try and undercut you after a month or two of production. The companies that thrive are the ones who do well in quality control and immediately fire or seek a new supplier when that happens.
    The main issue here is that it was very clear that APR knew about this issue, and continued to sell and not let their customers know. I discredit pretty much everything else going on with APR (simply put, not enough people on these forums know about private funding and sel;ling equity in your company does not mean that there are money troubles. When you have a good business, and need to expand there are a millions reasons why equity funding vs loans are a better outcome. Watching these conclusions get made based on that venture had me smiling at points)
    The lying to the customer is what will make me never consider APR as a product ever again. They could have easily pulled the exhausts, issued a blanket PR statement, offered some sort of solution to the people who did buy the product (like an actual decent exhaust using the tech they claimed and a covered install by an APR dealer and maybe $100 off of the next APR purchase) because frankly mistakes happen. and a company's true colors show when mistakes happen and they do not handle it correctly.
    lying to your customer is never a good idea and frankly other members should really factor that in when making their next purchase for a part.
    [CENTER]Scott
    2011 S4
  11. #91
    Established Member Three Rings Eldog_85's Avatar
    Jun 11 2014
    2014 Audi A4
    Gilroy, CA
    I went custom exhaust for this very reason. Built my exhaust for just under $600 with Magnaflow parts, and thats including the install. No way I'd shell out $1500-$2000 for an exhaust, especially with alll the b.s APR has put out. No way!
    2014 S4 - GIAC STAGE 2 - PHANTOM BLACK PEARL - 6MT - SPORTS DIFF. - H&R OE SPRINGS - 15MM/20MM SPACERS - BBS WHEELS - CUSTOM MAGNAFLOW EXHAUST + X-PIPE - ROC EURO INTAKE - VALENTINE ONE HARD WIRED - O.G GANGSTER MAC DRIVER
  12. #92
    Stage 2 Banner Advertiser Four Rings Arin@APR's Avatar
    Aug 23 2008
    Auburn, AL
    All of the exhaust systems we sell with "RSC" in the name are manufactured by Corsa and do contain RSC technology. We've confirmed this information with Corsa again due to all the recent claims otherwise. RSC technology is designed to eliminate unwanted frequencies, considered "drone," and our customers can attest to this being true. The greatest concern being discussed is related to the appearance of the RSC technology. Corsa has explained RSC technology will vary in appearance from system to system, depending on the frequencies that need removed, and other things like packaging constraints. Some vehicle applications must use large and heavy RSC technology, while other systems have the luxury of using smaller, lighter RSC technology. In each case the end goal is to remove drone, and thus far, that's the case.
    GoAPR.com | Facebook | YouTube | Twitter | Instagram
    Phone: (800) 680-7921 Local Phone: +1 (334) 502-5181 Fax: +1 (334) 502-5180
    Address: APR LLC, 4800 US HWY 280 West, Opelika, AL 36801
  13. #93
    Mar 10 2014
    Philly Area, PA
    Quote Originally Posted by Arin@APR View Post
    I had no idea RSC technology included stuffing a Princess Elsa wig inside part of the exhaust system. If so, APR may want to get permission from Disney.
  14. #94
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Here are the drawings from the patent filings for Corsa's RSC. Your resonators sure don't look like any version of RSC to me.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
  15. #95
    Veteran Member Four Rings Audacious's Avatar
    May 03 2011
    I see you've removed the quote in your sig about "the bitterness of poor quality lingers long after the sweetness of low price is forgotten." probably a good move.
  16. #96
    Veteran Member Four Rings chillindrdude's Avatar
    Jul 05 2013
    northern virginia
    So form follows function? The way I am interpreting your response is, as long as there is no drone, we shouldn't really care what is in that muffler. Are we not, the consumer, paying your premium cost, for not ONLY to minimize drone but for the supposed proprietary tech? and for the higher QA and materials used?
    The poster before you fashioned a custom "off the shelf" exhaust that performed the same function (minimize drone) but did it for $600 bucks. Your post also seems to imply that you knew some mufflers did not have the RSC baffles, and failed to indicate that to prospective customers. In addition, you (and perhaps APR) still feel (with hands firmly in cookie jar) that this is "OK".
    There's no doubt that some APR products work and even work well, but your unsavory business practices have convinced me to spend my hard earned dollar elsewhere.
    2016 Porsche GT4
    -- SOLD --
    1985.5 Porsche 944
    2010 Audi S4
    2015 BMW M3
    2010 Porsche GT3 *sniff*
    1998 BMW M3 coupe
    2017 BMW M2
  17. #97
    Aug 23 2008
    Auburn, AL
    Quote Originally Posted by chillindrdude View Post
    There really isn't much room for interpretation, or at least, you shouldn't need to interpret anything. There are claims the "RSC" exhaust systems we sell do not contain RSC technology. According to Corsa, the manufacturer of the system, the exhausts do contain RSC technology.
  18. #98
    Jun 22 2011
    A bunch of junk
    Detroit Metro Area
    But they don't contain Corsa's patented RSC technology of metal baffles which the product listings claim now do they?
  19. #99
    Aug 17 2010
    Vancouver, BC
    So form follows function?.......
    Of course, I could care less what's inside as long as it doesn't drone like the Milltek I had on my RS4. I was more concerned by the rattle mine developed this spring but am no longer since Corsa through APR's Canadian distributor took care of if. In fact, they shipped me a new muffler without benefit of getting the old one back. I've still got the old muffler if someone ones to go all forensic on this.
    2011 S4 (Cdn Spec) premium, 6MT, Quartz, Eurocode SS, APR Ultracharger, DP Stage 2 & CPS, Carbonio intake & exhaust, Ported S/C by Matty
    2013 Q5 3.0T S-line, EPL Stage 1 (the missus' car) 2007 RS4 (sold)
  20. #100
    Aug 23 2008
    Auburn, AL
    Quote Originally Posted by Stereodude View Post
    According to Corsa, the manufacturer of the exhaust system, they do.
  21. #101
    Jun 22 2011
    A bunch of junk
    Detroit Metro Area
    So, you're either attempting to insult our intelligence or are accusing Corsa of lying without quite coming out and saying it.
    Can you point us to the Corsa patent for fiberglass in a muffler?
    It's one thing to claim you're using RSC tech, it's another to say you're using patented RSC tech (complete with diagrams of the metal baffles).
  22. #102
    Mar 10 2014
    Philly Area, PA
    So were those pictures falsified that look nothing like metal baffles?? Look like fiberglass and a homeless person's wig in there.
  23. #103
    Jul 08 2010
    tucson
    danbury
    Look Arin,
    The exhausts you are currently selling right now have been shown, very clearly....by your co-workers as NOT having the structure that you advertise them of having. What is going on, and why have no taken these products off the shelf?
    [CENTER]Scott
    2011 S4
  24. #104
    Established Member Two Rings kandrei's Avatar
    Feb 13 2014
    windsor, ontario
    My Borla exhaust has no drone, no RSC, and no shenanigans.
  25. #105
    Dec 10 2011
    CLT | MKE
    Arin,
    We can clearly see that the patented RSC technology is not being used in our exhausts. We know that at least one APR employee was aware of this previously. Yet, you still advertise your exhausts as utilizing it.
    It doesn't matter that you claim you didn't know. It's very clear now; so why are you still advertising it?
    Sent from my iPhone 6 using Tapatalk
    -Hayden
  26. #106
    Nov 21 2013
    Texas
    Passing the buck or maybe it's Corsa we should contact to get the correct answer? I'm sure they have a muffler that they have a cut out of to show this "RSC" technology.
    Additionally, are you telling us that Corsa manufactures the entire system, then you guys brand it with APR, and sell for a premium, without doing anything further addition to the system? That leads me to believe that you, APR, are just finger pointing at Corsa for not including this "RSC" tech. The whole "It wasn't me" kind of thing
    2013 Brilliant Black S4 - SOLD :(
    Navi / Advanced Key / B&O / Sports Diff / Carbon Atlas Inlays / SC badges / Black Alcantara
    Modifications: AG M510 19x9.5 +40, Black optic grill, H&R Street Coilovers
  27. #107
    Senior Member Two Rings SpfldS4's Avatar
    Mar 04 2004
    2005.5 Audi S4
    Wilbraham, MA
    Holy crap, this is terrible business practice. There's a solution for this:
    A class action lawsuit is filed when several consumers who have been victimized by similar fraudulent business tactics come together to hold the offending company liable. A class action lawsuit is a lawsuit that is specially created to help consumers recover the financial damages sustained by the fraudulent tactics of the company.
    2010 Audi S4 S-tronic Prestige Sepang Blue | Sport Diff w/ ADS | GMG Sway Bar Kit | KW H.A.S Coilover | APR Stage 2+ w/ coolant system | 19" OEM RS4 Wheels | RS5 BBK | NAV | Black Nappa | Piano Black Trim | Black Optic | B&O | Advanced Key | 35% Tint | 3M Clear Bra | Audi exclusive
  28. #108
    Jun 22 2011
    A bunch of junk
    Detroit Metro Area
    Who has contacts at Corsa? It'd be interesting to corroborate that those really are patented RSC tech possessing exhausts.
  29. #109
    Veteran Member Three Rings Amorphic's Avatar
    Jun 05 2009
    2013 A4 2.0T Premium 6MT
    BC, Canada
    Quote Originally Posted by PSUGOLD View Post
    thats the unpatented version apparently lol.
    2015 Subaru WRX STi | Limited | Dark Grey Metallic | Sport Tech | Xpel Ultimate
    Sold -2013 Audi A4 2.0T | Premium | 6 MT | Brilliant Black | Xpel Ultimate | Tint: 35% Front 20% Rear
  30. #110
    Veteran Member Four Rings Saracen's Avatar
    Apr 25 2009
    PNW
    The other thread indicated that at SEMA the news was that Corsa has terminated their relationship with APR "a while back", and are developing their own line of VAG exhausts that will be sold next year.
    Why did they drop APR? Because Corsa was not getting paid for their product.
    "A car can be a tool but it can also be so much more. It can be a heart-starter, it can be a drug, it can be a piece of art and it can stir your soul" -Clarkson
    "It's like being an ass man but there aren't any nice asses around so you go find a fat chick b/c at least she has something to hold on to. It's not the same and you just don't do it. #avantsforlife" -02silverbullet
  31. #111
    Established Member Two Rings RainJer's Avatar
    Jun 27 2014
    Audi Q7 TDI - 996 C2 Cabriolet
    San Diego
    Don't want to stand by the product you sell?
    That's ok... when my dog shits the bed, he doesn't want to stand by it either.
    996 C2 Cabriolet - 2014 Q7 TDI - 2002 A4 Avant
    BPCDubs»
  32. #112
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Funny this seems to happen to all vendors who get caught doing something fraudulent or selling a poor quality product.
    They have no way of justifying themselves....so whats the easiest thing to do? Throw the next guy under the bus.
    Very respectable of you Arin, just throw Corsa under the bus, you guys haven't been paying them anyway so you won't need future business relationships with them.
  33. #113
    Jun 22 2011
    A bunch of junk
    Detroit Metro Area
    Funny, I didn't realize APR was selling Corsa exhausts. I thought they were selling APR exhausts. I guess the buck doesn't stop at APR for their APR exhausts.
  34. #114
    Veteran Member Three Rings Sean@APR's Avatar
    Feb 01 2013
    C7 S6
    Opelika, AL
    OK, bunch of clarification needed.
    1. RSC is a trademark owned by Corsa for an assortment of exhaust system designs
    2. Corsa also has a bunch of patents on various implementations of drone-free exhaust
    3. The thread over on that landfill of a forum is nothing but a lame attempt at a smear campaign. Every single thing on there is a distortion of reality.
    To clarify the patent situation:
    Only one picture in that post looks like the inside of an RSC exhaust. The others, I have no idea. Nobody has ever demonstrated that the pictures are authentic in any fashion. Everybody is quick to jump on the hate band-wagon and call us liars but NOBODY even attempts to verify what crew says.
    OK, here's the CORRECT patent image from the CORRECT patent that applies to that 1 image of the rear enclosure on a Golf R exhaust:
    Beyond that, please learn the difference between patent and trademark. Trademarks are words that companies register to apply to some particular thing: Their business, their product or their technology. Corsa uses the RSC trademark to describe an exhaust system with certain characteristics. They then use some of their patented technology to make a system that meets those requirements. There is nothing deceitful in that. It's precisely the purpose of the trademark system.
    Quote Originally Posted by LINDW4LL View Post
    Arin,
  35. #115
    Feb 01 2013
    C7 S6
    Opelika, AL
    It's not throwing anyone under the bus. Corsa OWNS the RSC TRADEMARK. They are the ones that are, by law, allowed to apply it to products manufactured by them.
    If they say it is RSC, it is RSC. We, by trademark law, don't have anything to do with that.
  36. #116
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Quote Originally Posted by Sean@APR View Post
    Ok, but you have a responsibility to know what you are selling to people. You advertise a multichambered muffler yet deliver and empty muffler with a single chamber.
    Let's say I own a restaurant, I'm liable for where I get my food, if I advertise organic gluten free whatever bullshit, it better be organic gluten free bullshit otherwise it's on me because I am the intermediary between my vendor and my customers. I can't just say "Nuhuh it's not my fault he didn't tell me it wasn't organic gluten free"
  37. #117
    Jun 22 2011
    A bunch of junk
    Detroit Metro Area
    It's one thing to claim you're using RSC™ tech, it's another to say you're using patented RSC™ tech (complete with diagrams of the metal baffles).
    So, basically the APR position is that APR didn't know what it was getting from Corsa and were duped?
  38. #118
    Jun 22 2011
    A bunch of junk
    Detroit Metro Area
    Oh sure...
    Quote Originally Posted by APR Website
    To continue with even further refinement and power potential out of the 3.0T, new features never before offered by APR Exhaust Systems are introduced to the B8 S4 application in addition to the patented RSC™ Technology:
    To continue with even further refinement and power potential out of the 2.0T, new features are introduced to the B8 A4 & A5 application in addition to the patented RSC™ Technology:
    Even where it doesn't say "patented RSC™" the tech is referred to as:
    RSC™ incorporates innovative technologies developed in conjunction with NASA. With limited use of packing materials and no baffles...
    Keep Digging...
  39. #119
    Dec 02 2013
    Houston, TX
    Quote Originally Posted by kandrei View Post
    +1
  40. #120
    Feb 01 2013
    C7 S6
    Opelika, AL
    That's incorrect. The exhaust IS multi-chambered. They just all happen to be inside that can at the top. Look at the drawing I posted.
