Results 1 to 40 of 45
    Jun 28 2012
    North NJ
    Inadvertant Bluetooth audio streaming project
    Backstory: I'm aware of the streaming options available to us and had considered them in the past but kept putting off buying them. I had no intention of trying to set up my own BT audio streaming in my S4. I put together two separate and unrelated projects today and lo and behold, BT audio streaming. So...
    Awhile ago I decided I wanted to add a 3.5mm input to my S4 accessible through the center console. I had an 8 foot long 3.5mm extension cable handy so I purchased this 3.5mm input AMI cable from Amazon.
    http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
    I routed the extension through the side of the glove box and under the center console and into the console arm rest storage. I was pretty happy with having the 3.5mm plug conveniently located. I added a two port USB charger in the center console power outlet so I could charge my phone while plugged into the 3.5mm line and listen to my podcasts and music through the AMI. Job done.
    Flash forward to a few days ago with the second, unrelated project. I have an old stereo in my garage and decided I wanted to add BT streaming to it. On a whim I bought this dongle, again on Amazon.
    Dongle worked well with my garage stereo. Satisfied customer. On a whim today, I plugged the dongle into the USB power supply in my center console and plugged in the 3.5mm jack. Powered on the car and hit play on my phone (Galaxy S5) and the podcast I had been listening to started playing through the speakers. I tapped the voice command button on the wheel and gave the command to call my wife and the call went through as if the BT dongle did not exist. I ended the call and the podcast resumed. The dongle has no battery so once power is cut to the USB port, the dongle goes dead and the phone disconnects automatically so there is no powering the dongle on and off each time. Turn the car off and the phone disconnects.
    So while it was not my intention to add BT streaming to my car, it seems I have stumbled upon a fairly cheap combination of parts that do the trick. The dongle was $10, the 3.5mm AMI was $13 and I think the long 3.5mm headphone cable was another $10-12 at Radio Shack. So, all in for $35 at the upper end. YMMV
    2012 S4 Prestige - Ibis and Titanium - 6MT - MMI - B&O - Rear Parking - Advanced Key
    - Clear Bra - Vag Mods - 8500 Hardwire - Intercooler Screen - Roc-Euro Short Shifter - Eurocode Rear Sway Bar - CR-15 - Matte black rear valence - Show N Go Front Plate
    1991 Ducati 851 - 888cc High Compression Pistons - Big Valve Corsa Heads - High Flow Fuel Injectors - Open Airbox - Braided Steel Lines - Corbin Seat - Fast by Ferracci Chip and Mufflers - Carbon Fiber bits
    Hex-Can-USB in Northern NJ
    Senior Member Three Rings Dash's Avatar
    Jun 07 2012
    St. Louis
    Very cool. If I drove enough, I would totally be doing this. Nice find and thanks for posting it up.
    Veteran Member Four Rings stereojorge's Avatar
    Oct 15 2013
    2014 Audi S4 P+ DSG, 2015 Audi SQ5 Prestige
    Tampa, Florida
    Fantastic job! I applaud you for the accidental but very cool solution you came across. If I wasn't so lazy, I would do this, but I don't wanna go through routing anything through the car. lol I've grown used to using my iPod Touch as the source in the glove box, but it's def annoying when I have so may gigs of music and have to scroll through it all. :)
    '14 Misano Red S4/APR Stage II+ DP ECU+TCU & UC/187mm Crank & AWE 57.55mm SC Pulleys/CMD Charge Chamber Intake/KW V1 Coilovers/EuroCode Sway Bars & AluKreuz/CR-15/034 Trans Mount/Apikol Rear Diff Mount/ECS Rear Diff Carrier Mounts/CMD Test Pipes/AWE Reso.Downpipes/AWE Track Exhaust 102mm Tips/Vossen HF-3 19" x 9.5"/Michelin PS4S'/StopTech Drilled Rotors/Akebono Euro Ceramic Pads/StopTech SS Lines
    Also: 2015 SQ5 Prestige | 2003 A4 Avant Quattro 6MT
    Previous: 2010 S4 P+ | 2008 A4 S-Line
    Jun 28 2012
    North NJ
    Routing took me less than 10 minutes. I ran the cord out the side of the glove box through an existing hole and then fed it through the passenger fuse box and along the front passenger well to the center console. I tucked the wire up under the center console until I got to the back. The only part involving any effort was popping the rear vent off the console so I could route the cable through the existing hole in the center console storage. I found a grommet at Home Depot to make it look tidy and that was it. I didn't want to remove the center console to run the wire and as you can see, I didn't have to. Could not have been any easier.
    Active Member Two Rings rmg0685's Avatar
    Oct 05 2008
    East Haddam CT
    Im assuming if you just want to use this setup for the bluetooth you would not need to run the 8 foot extension through the center console, just purchase the two parts linked above, is that correct?
    | 2010 Audi S4 | 6MT | Bang & Olufsen Audio | 19" 5 Segment Wheels | Carbon atlas inlays | Eurosport CAI | AWE Pedals | RS4 Grill | ROC-Euro Short Shifter | Tint: 20% | EPL Stage 2 | 034 Trans Mount |
    Mar 05 2015
    2009 A4 Cab: S-Line / 1996 Camaro Z28
    East Granby CT
    Quote Originally Posted by rmg0685 View Post
    Well not quite - you need a USB Power Connection - so the idea here is to run the 3.5MM connection from the glovebox into the center console where you can plug a USB Charger into the Power Outlet. If you have another power outlet you've setup that's hidden elsewhere then you'll need to run the 3.5MM cable to that instead.
    Although you might be onto something here - what about just using an ADI to USB Cable to just go right into the Blue Tooth Dongle:
    Audi ADI to USB Cable
    2012 Moonlight Blue Metallic S4 | Premium + | DSG | 19" Peelers |Sports Diff | MMI w/Nav | B&O Audio | Advanced Key |
    After-Market Add-Ons: Rallitek Aluminum Paddles | USP LED Interior Lighting | Phillips Xtreme +50% Headlight Bulbs
    Performance Upgrades: 034 Stage 1 ECU & TCU | | APR I/C |
    Stoptech Cryo Slotted Rotors with Porterfield R4-S Pads |
    034 Springs / Koni Yellow shocks | Tires = Michelin Pilot 4S (255/35/19)
    Jun 28 2012
    North NJ
    Quote Originally Posted by grovlet View Post
    I have one of the ADI to USB dongles as well. Can't say if that setup would work. My setup relies on the USB dongle feeding the signal to the ADI through the 3.5mm to ADI line so if ADI is supplying power, there'd be no audio feed unless you used a different BT dongle. I picked the one I used because I didn't want to power anything on/off and mine has no battery. Kill the power and phone disconnects immediately. Good luck. Post what you end up with
    Active Member Two Rings Nick G's Avatar
    May 20 2010
    Wake Forest, NC
    Schadenfreude,
    I wanted to say thank you for sharing your discovery.
    I purchased the parts and just spent about 5 minutes to successfully add the BT streaming capability to my 2010.
    I am going to have to look at how to route my cable as I don't see a hole in the side of my glovebox. Was the hole you used on the left or right (sitting in the car)?
    Thanks again!
    |2010 B8 S4 | Quartz Gray Metallic | S-Tronic | Premium+ | Sports Diff | B&O | Carbon Atlas | Black / White Nappa Leather | EPL Stage 2 | EPL TCU | HUGE grin on face |
    |2006 B7 S4 | Avus Silver | Tiptronic | Black / White Alcantra Leather | Addictive V8 sound | - SOLD
    Dec 02 2014
    Dallas, Tx
    But how did you have your phone connected to 2 different Bluetooth devices at the same time?
    Jun 28 2012
    North NJ
    Quote Originally Posted by Nick G View Post
    Schadenfreude,
    Thanks again!
    If I get a chance I'll take a picture. Take off the fuse cover on the passenger side and you should see a light shine through in a few places into the glovebox. The hole I used was directly above the AMI. Good luck. Routing the cable took me all of 10 minutes. I did pop off the rear vent on the console to allow me to route the cable where I wanted. It comes off very easy, especially if you have trim tools
    Jun 28 2012
    North NJ
    Quote Originally Posted by WCCoffey View Post
    My Galaxy S5 switches back and forth fine. When I get in the car, the phone connects to my MMI and a second later connects to BT dongle. When I tap the voice activation button on the steering wheel, the music pauses and when I disconnect my phone call, the music starts from where it left off. I was surprised it works as well as it does to be honest
    Dec 02 2014
    Dallas, Tx
    Quote Originally Posted by Schadenfreude View Post
    So your phone will automatically switch between the two based on what you are doing?
    That's interesting, how does the phone know you sent it a command from the car when it's connected to the dongle?
    Either way I will be trying this with the RSNE in my S4. I have the Galaxy S5 as well.
    Jun 28 2012
    North NJ
    I think phone is always prioritized. The phone comfortably connects to multiple bt devices at once though. A few days ago I left my BT keyboard turned on in my bag and phone paired to it, mmi and dongle so pairing to multiple sources seems no problem as long as functions are discrete. I'm betting that if dongle had a microphone that would mess things up since the phone would see competing devices. For example my s5 won't pair to my laptop AND my headphones at the same time since it picks up both for audio streaming. It makes me choose one
    Veteran Member Four Rings Vogz's Avatar
    Jul 17 2010
    996 Turbo
    Batavia, IL
    I've had BT streaming on my 2011 for a while that basically works the same way, but the bluetooth receiver is powered by the AMI port with this setup.
    https://www.audia2dp.com/store/p8/Audi-A2DP_3GN-MU.html
    It's A LOT more expensive than what you did and the music sounds really tinny when I stream so I rarely use it.
    How does this setup sound compared to using the 3.5mm directly?
    SOLD - 2011 S4 Sprint Blue 6MT Ti - GIAC Stage 2 - Sachs XTend clutch - AWE exhaust - Bilstein B12 suspension - strat short shifter
    [email protected] 1.85 60' (stock)
    [email protected] 1.74 60' (stage 2 - 93 octane)
    [email protected] 1.71 60' (stage 2 - 104 octane)
    2020 Tesla Model 3 Performance
    2003 Porsche 911 Turbo - SpeedTech, Cobb, Bilstein, H&R and TPC goodies
    11.69@123mph 1.82 60' (RWD on street tires)
    Jun 28 2012
    North NJ
    Quote Originally Posted by Vogz View Post
    To my ear it sounds fine but I am by no means an audiophile so your mileage may vary. I came upon this setup by accident. The 3.5 was better but not enough to my ears to make a difference given the convenience. With the 3.5 I only plugged it in when I was going to be in the car for awhile and I found myself wearing a BT headphone to listen to podcasts in the car just to not have to plug in the 3.5 and that was still with the 3.5 routed to my center console. I never would have used it if I had to put the phone in the glovebox
    Jan 24 2015
    Mid-michigan
    what you want is a device that is using the aptx codec if you're an audiophile like me.
    http://www.audizine.com/forum/showth...-bonus-aptx%29
    2013 Audi S4 6MT - Misano Red - Sport Differential - B&O Speakers - Unitronics Stage 2+ - Roc-Euro Intake
    Tinted Windows - Kinovo BTC450 Hardwired Bluetooth - Soon to have 10" JL sub in cubby box
    Jul 17 2010
    996 Turbo
    Batavia, IL
    Quote Originally Posted by teylix View Post
    Sweet, thanks!
    Established Member Two Rings LurkAllDay's Avatar
    May 27 2015
    Centreville, VA - MAIC
    Thank you! Did this last week. Costed me $30 shipped to my door.
    Sent from my VS985 4G using Tapatalk
    12 S4 - GIAC Stage 2 w/ TCU tune - USP intake - AWE Resonated DPs - AWE Touring - 034 Trans Mount - CR-15
    Senior Member Three Rings madman4you's Avatar
    Oct 13 2009
    07 GSX-R 750
    Ontario
    would you mind taking a quick pic of your set up. I am a little confused by your explanation. I purchased the suggested items. Now I am trying to figure out how to connect it.
    Thanks
    2012 S4 - Phantom Black w/ a bunch of good stuff done to it
    Best 1/4 =[email protected] Until next year...
    Jun 28 2012
    North NJ
    Quote Originally Posted by madman4you View Post
    Thanks
    I'll try to take some later once home from work
    Oct 13 2009
    07 GSX-R 750
    Ontario
    Thank you kind sir!
    May 27 2015
    did this two weeks ago... I'm so happy to have streaming music again :) Kudos to you Schadenfreude
    Jun 28 2012
    North NJ
    Thanks
    Here's some quick pics from earlier. I meant to pop off the passenger side fuse box cover but parked too close to a shrub to open door. First shot is the glove box. You can see the AMI cable with the 3.5mm plugging into the extension 3.5 line. The hole that the extension disappears into was already there and leads into the fuse box area on the passenger side. From there I ran it along the back of the glovebox by the footwell and under the side of the center console to the back of the center console.
    In the under armrest storage, there's a plug that you can pull out along the back edge. Pop off the rear center console vent (don't be shy, it pops right out) and you can feed the 3.5 line through the hole where the plug was. Plug the 3.5 into the BT dongle that you bought and plug the dongle into a USB cigarette light plug. The other cord next the dongle in mine is charging cable for my phone so ignore that. Once plugged in, power on your accessories and pair it up. Remember, that armrest lighter socket is switched power so once the car turns off, the BT dongle goes dead and vice versa. I found a grommet at home depot to clean up the area where the 3.5 line comes out.
    Nothing I did left any non-original holes or permanent changes. Given 10 minutes I could pull out the cable from under the center console, put the armrest storage hole cover back in and it would be back the way it came.
    Jun 28 2012
    North NJ
    Quote Originally Posted by LurkAllDay View Post
    Glad to hear you like it. I think that for what it is and the low price to add a handy function it isn't too bad. Enjoy
    Apr 20 2015
    AZ
    I'm missing something. Can't we BT stream without going through all this? I stream Pandora and Xbox music with no problem.
    Veteran Member Four Rings jsh139's Avatar
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    Quote Originally Posted by Cartoon View Post
    BT streaming wasn't available in the S4 until 2013. So this is for the B8 peeps.
    Junior Member Two Rings hfraj's Avatar
    Jul 16 2015
    Has anyone tried this one? http://a2dp4audi.netmagi.com/
    B8 Prestige | DSG | Sports Diff | ADS | APR Stage 2 | Gunmetal Pinstriped ECS RS4 Mesh Style Grille | 034 Drivetrain Mount Insert Package | E-Codes Bi-Xenon Headlights w/ AFS | APR Exhaust Tips
    May 20 2010
    Wake Forest, NC
    Instead of popping the vent off the back I used a clothes hanger hooked to go up under the side of the console after moving the passenger seat all the way back to pull the 3.5mm cable down the passenger side of the center console. I then routed it under the center console till below the glove box.
    There wasn't any holes in my glove box to take advantage of. I found that I can route the cable in through the door of the glove box, at the bottom left, without any pinching or other noticeable adverse affect.
    Jun 28 2012
    North NJ
    Quote Originally Posted by hfraj View Post
    Lots of people here use that or the tune2air. I planned on getting one of either at some point until I came across my setup (purely by accident).
    Oct 13 2009
    07 GSX-R 750
    Ontario
    Schadenfreude, thanks for the image. it all makes sense now! Cheers.
    And I am up and rocking out!
    Feb 15 2011
    Hey schaudenfreude, can you tell me exactly what cable you're using for the 3.5mm input? I just got a 3.5mm MMI cable that doesn't seem to work...Thanks!
    Feb 15 2011
    ^ Nevermind, see your amazon link!
    Jun 11 2014
    Pittsburgh
    @schaudenfreude
    thank you for taking the time to post this, i've been going back and forth with the available options and there seems to be issues with all of them.
    I bought the following items, installed as you described, and now have exactly the system that i've wanted at 1/4 the price.
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    $25.48 all in.
    1552
    Jun 28 2012
    North NJ
    Quote Originally Posted by nunzo View Post
    @schaudenfreude
    $25.48 all in.
    Is $25 a 1/4 of the price of the $32 I cited as my all-in price? Or did you mean you put it together for a handful of quarters less? Honestly I could have gotten my extension cable for cheaper on Amazon and matched your $25 but I bought it at Radio Shack before I started the project . I bought my dongle from VicTsing as well and it looks the same as yours (slight price difference). If we're splitting hairs, your 3.5mm AMI is .07 more than I paid (victory is mine!). Glad to hear the set-up works for you as well
    Aug 03 2015
    Calgary
    I came up with a very similar solution but it requires a few less wires than the above so I can just leave everything in the glove box.
    Get this cable. It's AMI Music Interface USB Charger 3.5mm AUX Audio Cable
    http://www.ebay.com/itm/261993771334
    This way there's a USB port to power the Bluetooth receiver: Bluetooth V4.0 NFC APTX Music Receiver
    http://www.ebay.com/itm/121475402078
    I got the one with APTX in hopes that the audio quality will be better than regular bluetooth.
    Just bought both items and they haven't showed up yet, will update on if it works or not when I get them.
    ps. I had a setup with a cheap bluetooth receiver just like OP on my E46 M3, works fine, doesn't sound too good though, a bit more electrical and compression noises.
    2011 B8 S4 DSG Full ADS & Sport Diff - U2nelson CR-15 strut brace review - Eurocode intake - S5 rear sway bar review - Eurocode transmission insert
    2005 E46 M3
    Mar 01 2006
    2021 X7 M50i, 2021 911 Carrera S
    Melrose, MA
    Quote Originally Posted by xtremepsionic View Post
    I went this route with the simple BT USB stick that the OP used and it works with my iphone 5 and wife's iphone 6 without skipping. Everything sits in the glove box and works great. The sound quality is probably not up to what some people want but it's good enough for us. You definitely have to turn up the volume a little but it's not a big deal to me. No problems getting incoming calls when paired to both the car and the USB stick. Thanks for posting all of these cheap, effective products.
    2020 M4 Convertible 6MT - Alpine White - Sakir Orange - JB1
    2019 X3 M40i - Dark Graphite Metallic
    2010 S4 - 6MT - Phantom Black - Black/Black Alcantara - Nav - Sports Diff - G.I.A.C. Stage 2 - AWE S-Flo Intake - 034 Transmission Mount Insert - JHM Crank Pulley - CR-15 Strut Tower Brace – Sachs XTend Clutch
    Jun 11 2014
    Pittsburgh
    Ha didn't see Your reply. I meant 25% the price of the tune2air and other kit.
    Couple weeks in, works great, auto connects every time I get in the car (with a nice tone). I did up the aux gain through the hidden menu which evens out the sound to radio so shit doesn't blast when you changes sources .
    1552
    Mar 01 2006
    Melrose, MA
    What is the path in the hidden menu to get to this aux volume adjustment
    Jun 28 2012
    North NJ
    Quote Originally Posted by Ray Khan View Post
    You beat me to it. I was not aware of the adjustment and want to adjust mine as well. Good find
    Mar 01 2006
    Melrose, MA
    I just figured it out. Go to hidden menu/audiomanagement/inputgainoffset/MU AUX. I went from -1 to 9 on my car. I tried the max, 13, but it was louder than my FM volume so I dialed it back a little.
