Originally Posted by
cschuster
Great work! Read your nefmoto thread, and its very interesting what you have to say about other company's tunes. My guess is that R&D costs would be way higher if they had put the same time into it as you have. Then they would have to price themselves out of the tune market to make up the cost. That also explains the secrecy - you get what you pay for. If I can get some damn HFC downpipes without paying $1100 I am interested in trying it out. Did you tune the rear O2 sensors out so it won't give the cat codes?
Well thanks
First, I would say that you could very likely use the first version of my tune with the stock cats in place. I only included that warning to cover my ass in case someone did use it and found that it caused issues.
I've been using a similar cam control strategy on my B6 S4 (with the stock cats) and it's worked quite well.
With respect to the time that I had to put into it, bear in mind that I started from scratch, with no clue whatsoever how to tune ME7, no DAMOS for the V6 (or any DAMOS for that matter) and no existing tuned files to reference.
Now that I have 6 gigs worth of definition files, a working DAMOS for my engine, reference tuning files for N/A engines and half a clue as to what I'm doing (lol), I can pound out a tune in 6-8 hours. I did it for my folks V8 Tourareg in fact.
Really, it's not that hard. In a very general sense, this is what you do
-Add values to the last 5-6 rows of KFMIRL,
-rescale the KFMOIP axis accordingly (to match the new KFMIRL values) and possibly add some values to the last row of KFMOIP, -
-look at the timing tables, smooth out any dips from the factory. If possible, add 2-3 degrees globally depending on fuel quality and elevation
-redo the KFPED throttle tables to suit. (you can always look at tables from other, sportier versions of an engine and import them as a baseline if you don't start from scratch)
-modify the cam timing maps to give more advance and then drop it as if you were roughly following the engine's volumetric efficiency)
-some other maps that you may want to look at are the smaller 8x8 maps of torque values in the command list as well, but I haven't messed with them yet.
I would submit that what drives the secrecy is the fact that once you have a few good reference files, it's not that hard to import those values to other platforms. I think that if people really knew how little R&D some of these tuners put into these products, that they wouldn't be willing to pony up $500+ for a canned tune.
Now, in fairness, there are some companies who legitimately put a lot of R&D into a product. However I would say that these types of products are ones that interface with the vehicle and require actual programming code to be written (like the REVO SPS cables or the APR switching software). Also, products which allow for OBD flashing of the more recent ECU types are also difficult to produce. I can understand the cost and secrecy associated with these types of products.
What I don't agree with is the secrecy associated with letting consumers know in a general sense, which map areas were re-calibrated. Really, it doesn't put the tuner at a disadvantage if they tell someone that, say, they re-calibrated the cam control. Just because I know they re-calibrated a map area, it doesn't give me any idea as to how they did it. However, it gives a sense of just how much work was really put into the tune.
