Results 1 to 11 of 11
    Veteran Member Three Rings luvsspeed's Avatar
    May 13 2007
    04 S4
    North Carolina
    Power steering question.
    I have been trying to diagnose a fluid leak for about a year, that is hardly visible. The shop that I took it told me that it is not a big deal ( I hate any type of fluid leaks ). They said that is was leaking from the ps line that goes to the cooler and it is at some point where the rubber meets the hard metal part. Would this be the infamous return line that everyone has a problem with at some point?
    Veteran Member Four Rings Guitarmageddon's Avatar
    Oct 23 2010
    EARTH
    Yea its not a big deal until a small hole becomes a large one at a moments notice...
    May 13 2007
    04 S4
    North Carolina
    Quote Originally Posted by Guitarmageddon View Post
    I agree with you. I never agree when someone tells me that something leaking is not a big deal.
    Active Member Two Rings Smokn337's Avatar
    Aug 26 2014
    '05 S4 Avant, '09 VW Routan (aka Dodge Caravan)
    British Columbia/ Kanada
    Replace the line. Driving these cars without powersteering is a great upper body workout, but sucks otherwise.
    '05 S4 Avant: brilliant black with blue Alcantara interior. Bi-Xenon E-codes, tint, smoked markers, Ultrasport 18's so far...
    Veteran Member Four Rings SpoolBus's Avatar
    Aug 07 2013
    ATL/GA
    Yes and when it blows it's a friggin mess and next to impossible to drive (some have burnt the pump without fluid- mine did not)
    Bite the bullet and return both before they blow.
    May 13 2007
    04 S4
    North Carolina
    Well the shop called me back and said the line wasn't the issue, but a hose clamp on the line was the issue. Does that sound about rite? I know on other cars that would sound about rite, but I know audi decided to do things different.
    Veteran Member Three Rings MidwestB6's Avatar
    Aug 01 2013
    1970 Ford Maverick
    Iowa City
    If you have a 2004, it's probably about time to replace the return line.
    2004 Light Silver 6MT S4
    Aug 26 2014
    From your description of where the leak is, it sounds like someone did a 'cost effective' repair at one point with clamps. The only clamp on the factory return line is at the power steering reservoir as far as I know. If there are clamps anywhere else, I'd question it and have the OEM line put in. My mechanic spliced and clamped my original leaking section only for it to blow again 6 weeks later. OEM line was put in after that.
    Senior Member Three Rings FormulaElement's Avatar
    Jul 02 2013
    406, MT
    Quote Originally Posted by MidwestB6 View Post
    This. Don't take the chance, just replace it so you don't have to worry.
    May 13 2007
    04 S4
    North Carolina
    Quote Originally Posted by Smokn337 View Post
    Well if anyone it would have been the last audi dealer that did work on the car. It wouldn't surprise me if they did that.
    May 13 2007
    04 S4
    North Carolina
    Quote Originally Posted by FormulaElement View Post
    I have thought about it, I may have it done after the holidays.
