Results 1 to 9 of 9
    Established Member Two Rings wisdom_kid's Avatar
    Nov 04 2012
    Toronto - Canada
    Headlight Bulb Install
    Got an error saying that "Left dipped headlight/main beam headlight". I bought a new bulb, but cant figure out how to install it. Do I have to take out the whole headlight assembly to put the bulb in?
    Is there a DIY out there that shows it for B8?
    Feb 13 2004
    Silicon Valley, CA
    First off, was your headlight actually burned out? Dipped normally means the auto level is not working.
    to change the bulb, there are two screws in the top of the housing you have to remove then slide the housing out of the bumper. From there it is easy.
    Kevin - Moderator, Audizine
    Nov 04 2012
    Toronto - Canada
    The bulb does turn on but after 20 seconds it dies off and I get the message on the dash.
    Established Member Two Rings Stifens's Avatar
    Aug 19 2012
    Norway
    A buddy of mine showed me how to do it on my A5. You first remove 4 screws from the plastic cover over your grille and intake duct. Then push/slide that cover away from you. (Towards the engine bay) Then you remove the top two screws on your headlight housing and loosen the two lower ones that is behind the headlight housing inside the engine bay. Then you can pull the headlight housing out. It's as easy as it gets ;) I can snap some pictures tomorrow if needed ;)
    2008 A5 Coupé 2.0T MT quattro
    Veteran Member Four Rings xuandatou's Avatar
    Oct 17 2012
    NoCal
    Does it have the AFS? If so, check the small plastic control trim, it may fall off...
    If its just the burned bulbs, you don't even have to remove the whole headlight housing to replace the HID bulbs (since its for driver's side, no airbox, plenty of space..)
    EDIT: Just simply 1. remove the round cover in the back, 2. unplug the wire, 3. twist the bulbs off and reverse the order of install....
    2013 S5 Build Thread
    2001 S4 Avant
    2017 Ducati Monster 821
    Instagram
    Gone but not forgotten:
    2011 Q5 2.0T
    2011 A5 2.0T
    2013 S5
    2007 A6 3.2
    Aug 19 2012
    Norway
    Yeah, you don't have to take it out for the drivers side ;) but since I have ten thumbs and I am a detailing freak, I took them out anyway and gave en a good clean while I was at it.
    Veteran Member Four Rings Cloudg8's Avatar
    Oct 10 2012
    Jeep
    Chicago/IL/USA
    Quote Originally Posted by wisdom_kid View Post
    Did you ever get to the bottom of this. I just got the same that happened to me
    Nov 04 2012
    Toronto - Canada
    Quote Originally Posted by Cloudg8 View Post
    Yup, the bulb was worn out. Ordered it off ebay and installed it. Everything went back to normal :)
    Senior Member Two Rings gersonz90's Avatar
    Dec 27 2014
    S5%2C%20S4
    Annandale/VA
