Originally Posted by
d.p
Thanks man.
I am ok with it but seeing all these other 93 times much faster than mine I expected a little more. I ran with less than a 1/4 tank of gas, temp was 65-70 and the DA was right around 1000 all night. I think the last run it was 946 and you can see on that slip 12.8@110 my 1/8 was 88MPH (going back in time) but my trap was the same @110. I would assume a faster 1/8 would equate to a faster 1/4? but my 1000 was actually slower than all but one run. How do I explain that?
Short answer: It could be explained mainly by IAT, I think. I noticed that, on my stock 2014 S5 DSG logs, that the bypass valves opens and starts really bypassing boost at roughly 75-77'C. I dropped from 12.3psi on one street run down to 6psi because of this. Timing actually stayed the same or went up as boost was bypassed. This is all stock ECU behavior, tuned may be different.
My street logging at 84'F ambient showed that while idling and moving in traffic my IAT was basically starting off at 67-70'C, likely because the SC coolant loop was heat saturated in that scenario. As soon as I got on the highway and nailed it in 2nd, the IAT went quickly to 82.5C by the top of 3rd gear.
So if your first few passes netted IAT of sub 75'C and the one you were slower on the back half you crossed 75-77'C, you were likely bleeding boost and slowed down slightly.
The only way you'll know for sure is to log it. Yes VCDS is a PITA to lug around a laptop but logs are needed. I'm still working on getting my Torque app to properly log all of the PIDs I'd like and that may be enough to supplant the need for VCDS + laptop for better-than-nothing basic logging (Ambient AT, coolant temp, IAT, cyl 1 timing and boost).
