    Senior Member Three Rings skylinrcr01's Avatar
    Aug 31 2014
    BMW K1200S
    Orange County, Ca
    Color LCD instrument cluster retrofit
    Hey guys, couple quick questions, I'm thinking of trying to retrofit the color tft dash into my a6 with the LCD. Do you guys think MMI would recognize it as a color screen and display properly or you think I would run into issues? I know these cars are super modular, and alot of stuff is pretty easy to swap. I have VCDS, so if it's a setting, I'm sure I could figure it out.
    Current ugly display: http://i110.photobucket.com/albums/n...y/IMAG0360.jpg (Example)
    Color LCD display:
    http://i220.photobucket.com/albums/d...x/IMG_1908.jpg
    Both displays were used with the same MMI (2g high)
    Also is the mileage stored in the MMI or the cluster itself?
    Thanks
    http://i.imgur.com/KPi8p89.jpg
    2004 Mercedes E55 AMG
    2005 A6 Quattro 3.2 (Sold)
    2005 BMW K1200S
    Jan 24 2012
    Calgary, Alberta, Canada
    The mileage is stored in the Cluster FYI.
    Nov 19 2012
    Mankato, MN
    What Tarrant said.
    So you'd have to get the necessary software/hardware to try and rollback the mileage if the cluster you're swapping to happens to have more mileage than your car. I don't know if you're able to add mileage though.
    Senior Member Three Rings FormulaElement's Avatar
    Jul 02 2013
    406, MT
    If the cluster is under 100k miles, i've read that you can roll it forward to whatever your current one is using VAG-Com. Getting the immobilizer and component protection off the cluster you buy and working with your car though.... There are a couple people who do it, i suggest you look them up and go through them.
    Aug 31 2014
    BMW K1200S
    Orange County, Ca
    It sounds like a lot more trouble than it's worth, I think I'll just stick with my ugly monochrome cluster haha.
    2005 BMW K1200S
