Results 1 to 9 of 9
Thread: Front Sway Bar?
    Established Member Two Rings Jeffinstereo's Avatar
    Jun 15 2020
    Philadelphia
    Front Sway Bar?
    I'm going to try and install the H&R front sway bar meant for the B8 S4/S5. Shop I go to says it'll fit and my parts supplier said it will as well, but wanted to see if anybody else has done this before. It's obviously not made for this car, so I know it might not be a perfect fit. Any advise?
    '15 SQ5
    IE Stage 1 Tune and intake
    034 drivetrain, tranny mounts, rear sway bar
    AWE Downpipes
    KW Street comfort Coilovers
    Homemade blackout package
    Jan 08 2016
    Los Angeles, California
    I cannot comment on fitment but I am curious as to why you are looking to add a front after having the rear already installed. I remember years ago a thread where there was a big debate as to whether an upgraded front sway bar was even needed as adding an upgraded rear seemed to resolve most of the understeer/body roll issues.
    Do you feel the front end is too loose in comparison to your rear with the 034 sway bar?
    '14 Q5 TDI Premium Plus S-Line w/ Black Optics: APR ECU Tune, DTUK TCU Tune, Magnaflow 3" Catback, SQ5 BITDI Intercooler, Hi-Flow CP4 Metering Valve, AFE Dry Flow Air Filter, Full ECS Drivetrain Inserts, AG M610 Wheels, 034 RSB with Moog Endlinks.
    Jun 15 2020
    Philadelphia
    Quote Originally Posted by Pittdawg View Post
    Mostly I'm bored, curious, and am constantly trying to keep up with my friends with S4/5s. And my parts supplier told me he'd take it back if it didn't fit. At this point I'm more into making this thing go as fast as possible around curves than in a straight line.
    '15 SQ5
    AWE Downpipes
    Jan 08 2016
    Got it. Let us know how it goes. In my experience, the Q shares certain suspension components with the A4/A5 (S4/S5) models but other components are shared with the A6/A7/A8 models. At least that's how it appeared to me after purchasing a bunch of Powerflex bushings.
    Jul 31 2016
    PA
    My only concern with a front is that the car already has a tendency to understeer and stiffening the front like that only really makes it worse, that was 034s rationale if I remember correctly for why they never made a front bar.
    Can't hurt to try it out though.
    Sent from my SM-G988U using Audizine Forum mobile app
    Custom DP 194/57 E40 Water-Meth (Aquamist) | BG HPT ZF8 Tune | APR CPS with AWE Reservoir (Divorced Coolant Loop) | APR Open Intake and 034 Intake Tube | RSE Heat Shielded HFCs | CTS Downpipes with Vibrant UQ Resonators Added | AWE Touring Exhaust | 034 RSB | Bilstein B8 Shocks and H&R -3 Springs | ECS Trans and Drivetrain Inserts | 034 Trans and Motor Mounts | Moog Front End Links | Headlight Projector Retrofit and Painted Housings
    Veteran Member Four Rings SDV325's Avatar
    Jan 20 2014
    Calgary, AB
    Quote Originally Posted by djn876 View Post
    I installed the Eurocode front and rear bars on my SQ at the same time.
    I owned a B8 S4 few years ago and installed the rear then the front bar a few weeks later to find what differences each bar made. With only the rear bar installed, turn in did improve and the rear wanted to break loose very easily however the front end still lacked precision and rolled a lot on hard initial turn ins. Once the front bar was installed, this helped level the car much more on the initial turn in, car felt incredibly planted though.
    With both bars installed on the SQ I feel the ride has gotten a bit better as bumps are more evenly absorbed and the body roll has somewhat been reduced (the pano roof is just insanely heavy). There is a reduced amount of understeer compared to stock, however more than just with just a rear bar.
    2016 Audi SQ5 | Technik | Glacier White | Magma | Black Optics | Beaufort Inlays | Roc-Euro | Revivify Graphene Pro | EPL Stg 2 | Eurocode USS | MOOG Endlinks |
    2014 Audi SQ5 Estoril- STOLEN / RIP
    2015 Toyota Rav4 - Family Wagon
    Jan 08 2016
    Ha! I did not mean to turn this thread into a repeat of the other one. This seems to remain a topic of debate. Very interested in hearing the OP's thoughts after the install.
    Jun 15 2020
    Philadelphia
    Didn't know there was another thread discussing this already, if somebody has the link please send it my way cuz I couldn't find it with search although I am a bit of a neanderthal with that function. Will update you in probably 5 weeks when I get around to installing it LOL
    '15 SQ5
    AWE Downpipes
    Jan 08 2016
    There are actually a few different ones. Here is a relatively recent one I was referring to:
    https://www.audizine.com/forum/showt...ght=front+sway
