Hey there, I'm new to Audis. Posted a few other questions on the forum and I think I'm getting close to solving my issue.
To make a long story short, I bought a 2005 a4 b6 1.8t Quattro from a dealership, through a childhood friend that took it in on trade. Since he took it in on trade I have no idea what mods it had, but have slowly uncovered some of the stuff. Anyhow, I was having an issue, where I would lose boost seemingly randomly.
- Checked and relubed the diverter valve (forge)
-ran a boost leak test, no leaks
Since I had just bought it, the dealership has been great about investigating the issue. And they checked for faults. I'm getting an "overboost" fault code. I don't have the specific code. But through the scanning I found that it also is tuned. Since its "chipped" they won't go any further with this particular issue.
So basically, under normal driving conditions it pulls so good. Everything runs great. Push it alittle too hard and get the fault code, and the boost dials back, what I suspect is a soft limp mode.
Mods that I know for sure are done.
-Catback sportec exhaust
-apr cold air
-forge diverter valve (blue spring)
-tune (no idea from where)
So after all that. My questions are,
A) is it a bad tune?
B) A failing part?
C) Would an mbc help control boost pressures to a reasonable amount so this doesn't happen?
D) does an Mbc replace an n75 valve or do they work together?
Any help on this would be great. I've searched through endless threads without definitive answers so I'm asking you guys! Thanks!
