Results 1 to 7 of 7
    Established Member Two Rings GuyFawkes's Avatar
    May 09 2014
    Question sifter is stuck in park, got a scan soo many faults dont even know where to start
    Hello audi headache enthusiasts :) I'd love if someone with some experience would be able to guide me in the right direction.
    Now i don't know if all of these are related to the issue at hand but here's what happen over past few days. One morning the car had a complexly drained battery, after about a ten mile drive check engine light went on. Than after parking and restarting the car i couldn't get the shiftier to shift out of the Park. Here are some symptoms:
    1. The indicator by the P, for the foot on the break, doesn't come on, ever.
    2. the check engine light stayed on, until i got it cleared with the vag com.
    3. after taking the fuse #31 out i'm able to shift and drive on R/D/S all the time. Also in TIP, but from time to time on the dash all of the lever positions would get highlighted and than i loose the ability to go into TIP. (until i restart the car)
    4. the oil sensor message has popped up.
    5. the break lights are working fine.
    6. the solenoid gets engaged/disengaged depending on car key position.
    7.ESP was on for a little while than went away.
    7. Vag com scan below \/\/\/\/\/
    VCDS Version: Release 11.11.6 (x64)
    Data version: 20121223
    Wednesday,10,September,2014,17:39:05:29775
    Chassis Type: 8E - Audi A4 B6/B7
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
    69 75 76 77
    VIN: WAULC68E84A152712 Mileage: 132450km/82300miles
    Address 01: Engine Labels: 06B-909-518-AMB.lbl
    Part No SW: 8E0 909 518 AK HW: 8E0 909 018 A
    Component: 1.8L R4/5VT G 0004
    Coding: 0016751
    Shop #: WSC 63351 000 00000
    VCID: 79F91CBB33AD1DD0675
    6 Faults Found:
    18057 - Powertrain Data Bus
    P1649 - 008 - Missing Message from ABS Controller - Intermittent
    19534 - Throttle Control
    P3078 - 002 - Airflow at Idle too Low - Intermittent
    17072 - ECM Power Relay Load Circuit: (J271)
    P0688 - 004 - Open Circuit - Intermittent
    18010 - Power Supply Terminal 30
    P1602 - 002 - Voltage too Low - Intermittent
    18047 - Accelerator Position Sensor 1/2 (G79/G185) A
    P1639 - 008 - Implausible Signal - Intermittent
    16795 - Secondary Air Injection System
    P0411 - 002 - Incorrect Flow Detected - MIL ON
    Readiness: 0000 0000
    Address 02: Auto Trans Labels: 01V-927-156.lbl
    Part No: 8E0 927 156 S
    Component: AG5 01V 1.8l5VT USA 1212
    Coding: 0001002
    VCID: 3E73CFA76A03FAE8127
    5 Faults Found:
    18258 - Powertrain Data Bus
    P1850 - 003 - Missing Message from ECU - Intermittent
    17095 - Transmission Fluid Temp Sensor (G93)
    P0711 - 003 - Implausible Signal - Intermittent
    18170 - Shift Lock Solenoid (N110)
    P1762 - 003 - Short to Plus
    18161 - Tiptronic Switch (F189)
    P1753 - 003 - Implausible Signal
    18164 - Tiptronic Recognition Switch (F189)
    P1756 - 003 - Open or Short to Plus
    Address 03: ABS Brakes Labels: 8E0-614-517.lbl
    Part No: 8E0 614 517 A
    Component: ABS/ESP allrad 3429
    Coding: 04277
    Shop #: WSC 06435
    VCID: 264307C7C29342287A7
    No fault code found.
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043 AD
    Component: A4 Klimaautomat 1323
    Coding: 00000
    Shop #: WSC 63351
    VCID: 63C55ED3F121F7005D9
    Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
    Part No: 8E0 907 279 F
    Component: int. Lastmodul USA 0517
    Coding: 00003
    Shop #: WSC 63351
    VCID: 3561D08B0F3539B0C3D
    1 Fault Found:
    01502 - Bulb for Rear Fog; Left (L46)
    57-00 - Electric Circuit Failure
    Address 15: Airbags Labels: 8E0-959-655-84.lbl
    Part No: 8E0 959 655 K
    Component: Airbag 8.4EP 1001
    Coding: 0010607
    VCID: 3F8DB2A36D09F3E0191
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 N
    Component: Lenksáulenmodul 0611
    Coding: 01041
    Shop #: WSC 63351
    VCID: 3E73CFA73A03FAE8127
    Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
    Part No: 8E0 920 950 P
    Component: KOMBI+WEGFAHRS. RB4 D42
    Coding: 01231
    Shop #: WSC 08174
    VCID: 3663D787123332A8CA7
    WAULC68E84A152712 AUZ6Z0C0335138
    4 Faults Found:
    00562 - Sensor for Oil Level/Temperature (G266)
    30-00 - Open or Short to Plus
    27-00 - Implausible Signal
    01314 - Engine Control Module
    49-10 - No Communications - Intermittent
    01304 - Radio
    Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
    Part No: 8E0 959 433 BB
    Component: Komfortgerát T7B 1411
    Coding: 11788
    Shop #: WSC 63351
    VCID: 72EB2B973EDB6E8826F
    Subsystem 1 - Part No: 8E1959801
    Component: Tőrsteuer.FS BRM 0004
    Subsystem 2 - Part No: 8E1959802E
    Component: Tőrsteuer.BF BRM 0004
    Subsystem 3 - Part No: 8E0959801A
    Component: Tőrsteuer.HL BRM 0004
    Subsystem 4 - Part No: 8E0959802A
    Component: Tőrsteuer.HR BRM 0004
    13 Faults Found:
    01330 - Central Control Module for Central Convenience (J393)
    53-10 - Supply Voltage Too Low - Intermittent
    00962 - Alarm via. Tilt Sensor
    35-00 - -
    01368 - Alarm triggered by Luggage Compartment Switch
    35-00 - -
    01374 - Alarm triggered by Terminal 15
    35-00 - -
    01371 - Alarm triggered by Door Contact Switch; Driver's Side
    35-00 - -
    01572 - Alarm triggered by Door Contact Switch; Passenger Side
    35-00 - -
    01574 - Alarm triggered by Door Contact Switch; Right Rear
    35-00 - -
    00956 - Key 2
    35-10 - - - Intermittent
    00532 - Supply Voltage B+
    37-10 - Faulty - Intermittent
    01331 - Door Control Module; Driver Side (J386)
    01332 - Door Control Module; Passenger Side (J387)
    01333 - Door Control Module; Rear Left (J388)
    01334 - Door Control Module; Rear Right (J389)
    Address 56: Radio Labels: 8E0-035-1xx-56.lbl
    Part No: 8E0 035 195 H
    Component: symphony II NP2 0400
    Coding: 01001
    Shop #: WSC 07936
    VCID: 2C57F5EFDC7F7878AC3
    1 Fault Found:
    00878 - Connection to Speaker Front Left
    36-10 - Open Circuit - Intermittent
    End ---------------------------------------------------------------------
    Veteran Member Three Rings Let it snow's Avatar
    Aug 24 2014
    02 1.8TQ Sport 5 speed, 05 1.8TQ 6 speed
    Vermont
    Hi Guy. Do you know what drained the battery? Have you checked for water in your ECM compartment? It would cause problems and turn your radiator fans on until the battery drains. Ask me how I know:(
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    Much of the codes tie back to the battery. Check the battery to make sure it holds a charge. Also have the alternator and ignition switch tested. Clear out all codes and then let it sit overnight. Check voltage in the morning to see if levels have dropped (would indicate a short and draining power). Then check for codes again.
    My alternator went bad (seized up) causing the battery to go flat. When it was low enough, I saw most of the dashboard lights light up one at a time and then go completely dark until power loss stopped the engine.
    Do a sanity check as well. Check fluid levels (oil, coolant, brake, power steering). If all of those look fine, then check the ECU box for any water getting in as suggested above.
    USP CLUB MEMBER #34
    Aug 26 2005
    When this fault occurs, the shift lock solenoid is ON and you can't shift out of Park. Need to find out where the short to +Bat is located and fix that. Otherwise, clear all the codes and see if any/which ones reoccur. Post back any reoccurring codes, then we can go forward.
    Vorsprung durch Technik
    Mar 02 2014
    Examine that positive terminal wire for damage or breaks. It would explain the battery drain. Just be sure to disconnect the battery first
    May 09 2014
    So what happened is some whater got into the ecu box. After replacing the relays no more issues all though haven't connected the locking solenoid back to see if it's functioning properly.
    May 09 2014
    Thanks for all the help 👍😊
