Been a long time since I've put up any threads so I'd thought start a build thread. I've had my B6 S4 since 2008, picked it up lightly used with 30k on the clock. Little late for build thread I now lol.... Its Nogaro Blue with matching Nogaro interior. I searched far and wide for over a year back in the day to find a clean example of a noggy on noggy with six speed. Basically been a weekend garage queen and only gets out for shows and gtg's. I started modding it as soon as I got it so 1st thing on the list was exhaust. Next was suspension and never stopped since. Its been a long process and 5 exhaust setups later I'm happy with the progress! Updated mod list below...... hit me up if you have any questions.
Performance
JHM HD Heads
JHM V2 Headers / Ceramic Coated by Swain Tech
JHM FI Non Res Cat-Back / Custom Tips
JHM Intake Manifold
JHM IM Spacers
JHM Tune
JHM Stage 4 Clutch / 034 LW Flywheel / RS4 Pressure Plate
JHM Shifter trio
JHM LW Crank Pulley
JHM Mechanical Adjuster's & Timing Update
Stratmosphere HOTT Air Intake
Custom Intake Inlet with MAF built in
Brembo Grand Turismo GT BBK and SS lines
ECS LW Rear Rotors
Suspension
Airlift Bags
Accuair e-Level
Twin Endo-CT noggy tanks
SPC Adjustable Upper Control arms
H-Sport Front Sway Bar
034 Front Sway Bar End Links
034 Rear Sway Bar
034 Rear Adjustable Sway Bar End Links
034 Engine Mounts
034 Trans Mount
034 Tie Rods
034 Lower Control Arms
034 Snub Mount and zero gap bracket
034 Rear Differential Carrier Mount Insert
Silver Project Adjustable Rear Control Arms
ECS Rear Diff Mount
ECS Magnetic Drain Plug
ECS Billet Oil Filter Cap
USP Titanium Lug Bolts
Show
OEM Bentley Continental GTC Flying Spurs PSS Tires
Mk2 RNS-E LED
E-Codes
HID fogs / LED plate lights / Chrome Signals / HID Reverse lights / LED interior
FK LED Tails
B8.5 Custom RS2 Blue weave CF Flat Bottom Steering Wheel
RS4 Shifter with RS2 Blue weave Custom CF
Silver CF Trim
RS4 Pedals
RS4 E-Break Handle
R8 Engine / Coolant Caps
RS2 CF Blue weave washer fluid cap
ECS Billet Engine Oil Dipstick
B7 Aero Wipers
Custom Powder Coated Calipers, Valve Covers, IM, Intake Inlet, hardlines
Alcantara trunk and headliner.
Photo's!!!!!!
[IMG]
[IMG]
[IMG]
[IMG]
[IMG]
[IMG]
[IMG]
[IMG]
[IMG]
