for 2.7T APB into B6 chassis, experimental for B7 A4
Wiring Should be accurate as of 2/8/17 for the B7 A4 thanks to Ali SC3 for testing.
This information was pieced together from elsawin diagrams and AudiA4_20T's thread http://www.audizine.com/forum/showth...ness-Explained
Will Work for all b6 Chassis if done the recommended way, and now B7 A4's as a direct wire harness, a jumper harness requires slightly different wiring.
WARNING THIS IS FOR MANUAL CARS ONLY, auto's require more wiring and have not been covered as of yet
Read all the post pertaining to the part of the swap you are doing (engine or abs), if you have a question read it again before asking, using nothing other than whats provided here the car will run.
Known B7 issues:
ABS needs to be retrofitted(see bottom of the post for wiring)
The dash has 2 issues, first is the oil level sensor, this should be fixable with an B7 RS4 or A4 Sensor(same part) as it has the right readings for the dash and same shape as the 2.7
The second dash issue is the close fuel cap message, this is thought to be fixed with a b6 ccm(still being tested), Update only works with switching the cluster out for a b6 one.
Alternatively you can fit a b6 cluster and fix both issues.
Signal | S4(A6) APB | B6 Chassis | B7 A4 | NOTES |
Throttle Pedal | T15(T15e) WHITE Pin5 grey | T17e WHITE Pin1 brown/green | T17e WHITE Pin1 brown/green | |
Throttle Pedal | T15(T15e) WHITE Pin2 yellow/Violet | T17e WHITE Pin2 yellow/violet | T17e WHITE Pin2 yellow/violet | |
Throttle Pedal | T15(T15e) WHITE Pin3 brown/red | T17e WHITE Pin3 brown/red | T17e WHITE Pin3 brown/red | |
Throttle Pedal | T15(T15e) WHITE Pin1 yellow/blue | T17e WHITE Pin4 yellow/blue | T17e WHITE Pin4 yellow/blue | |
Throttle Pedal | T15(T15e) WHITE Pin4 grey/yellow | T17e WHITE Pin5 grey/yellow | T17e WHITE Pin5 grey/yellow | |
Throttle Pedal | T15(T15e) WHITE Pin6 brown/green | T17e WHITE Pin6 brown | T17e WHITE Pin6 brown | |
Brake Light Switch | T15(T15e) WHITE Pin11 red/black | T17e WHITE Pin11 red/black | T17b GREEN Pin6 red/black | Wire must be run from the ecu harness to the Left kick panel under the dash On B7 Chassis where this connection Is Quick connect terminal Recommended |
Brake Vacuum Vent Valve | T15(T15e) WHITE Pin12 white/red | T17e WHITE Pin12 white/red | T17d RED Pin12 white/red | |
Clutch Vacuum Vent Valve Switch | T15(T15e) WHITE Pin13 red/green | T17e WHITE Pin13 red/green | T17d RED Pin9 green/grey | |
Connection (crash signal) in instrument panel wiring harness | T3au(T3au) RED Pin2 violet/blue | T17d RED Pin6 violet/blue | T17j BROWN Pin14 violet/blue | THIS IS AN AIR BAG CONNECTION note *2 |
CAN BUS -Low | T15m(T15u) RED Pin14 orange/brown | T17d RED Pin13 orange/brown | T17e WHITE Pin13 orange/brown | |
CAN BUS -High | T15m(T15u) RED Pin15 orange/black | T17d RED Pin14 orange/black | T17e WHITE Pin14 orange/black | |
Starter Wire | T10(T10o) BROWN Pin4 red/black | T10a BROWN Pin4 red/black | t17j BROWN Pin16 red/black | |
K-diagnostic Wire | T10(T10o) BROWN Pin1 green/black | T10a BROWN Pin6 green/red | T17d RED Pin13 green/red | |
Oil Level Thermal Sensor | T10(T10o) BROWN Pin8 black/red | T10a BROWN Pin2 black/red | T17e WHITE Pin17 black/red | |
Oil Level Thermal Sensor | T10(T10o) BROWN Pin9 red/gray | T10a BROWN Pin9 red/gray | T17e WHITE Pin9 red/grey | |
D23 - Connector (over fuse 229) | T10ar(T10n) ORANGE Pin1 red/green | T10 BLACK Pin5 red/green | t17d RED Pin17 green | * see additional note #6 for b7 |
D22 - Connector (over fuse 234) | T10ar(T10n) ORANGE Pin8 green/yellow | T10a BROWN Pin8 green/yellow | t17d RED Pin15 black/blue | |
Injectors | T10ar(T10n) ORANGE Pin5 black/blue | T10a BROWN PIN 1 red/blue T17e WHITE Pin15 black/violet |
see note *1 section B7 | *1 |
Alternator/Generator | T10m(T10p) BLACK Pin1 blue | T10 BLACK Pin1 Blue | T17e WHITE Pin11 blue | |
Oil Pressure Switch | T10m(T10p) BLACK Pin3 white/grey | T10 BLACK Pin3 white/grey | T17d RED Pin6 white/grey | |
Sensor Ground | T10m(T10p) BLACK Pin5 brown/yellow | T10 BLACK Pin6 brown/yellow | T17e WHITE Pin10 brown/yellow | |
Engine Coolant Level (ECL) Warning Switch | T10m(T10p) Black Pin7 blue/yellow | T10 BLACK Pin7 blue/yellow | T17d RED Pin2 blue/yellow | |
Fuel Pump (FP) Relay(also Powers fuses for injectors) | T10m(T10p) BLACK Pin8 red/blue | T17d RED Pin10 red/blue | T17j BROWN Pin12 red/violet | |
Engine Coolant Temperature (ECT) Sensor | T10m(T10p) BLACK Pin9 blue/brown | T10 BLACK Pin9 blue/brown | t17d RED Pin3 blue/brown | |
Speedometer Vehicle Speed Sensor | T10m(T10p) BLACK Pin10 brown/red | T10 BLACK Pin10 brown/red | n/a see additional connections | Not on 2003+ see additional connections |
Leak Detection Pump | T10ar(T10n) ORANGE Pin6 white/yellow | T17d RED Pin1 white/yellow | T17d RED Pin4 yellow | |
Leak Detection Pump | T10ar(T10n) ORANGE Pin7 yellow/red | T17d RED Pin2 grey/red | T17d RED Pin5 grey/red |
notes:
*1
These are wired this way to provide the correct fused amperage connections needed to be as close to factory as possible
B6 Chassis
1) find where the pin 3 from the ecu ties together with the injector harness (near the ecu box rubber boot) and cut it separating pin 3 from the injectors.
2) pin 3 from ecu goes to T17e WHITE Pin15
3) the main black/blue injector wire should tie into T10a BROWN Pin1 for a fused connection that turns on with the ecu fuel pump relay signal.
4) T17e WHITE Pin16 red/grey needs a 12v good current feed, run an 14 gauge wire from post 30 to one side of a relay and then from the other to T17e WHITE Pin16, trigger the relay from the same one that is used with ECU pin3 which is T17e WHITE Pin15, see below picture
the reason for this way is the ecu can now work correctly and cut power to the injectors in case of a problem.
*2
air bag crash signal can be found at T12i (black plug) pin 8 lilac/blue on the ccm in 03+ models.
B7 A4
2) pin 3 then goes to t17e WHITE Pin17 along with the Oil Level Thermal Sensor wire(fused power for sensors).
3) you will need to add an inline 20amp fuse and a relay that is triggered from the ecu, using the same line that trigger the fuel pump module T17j BROWN Pin12 red/violet.
4) Supply the above relay with an appropriate gauge wire attached to post 30 power supply, and the other side connects to the injector wire you seperated(the thicker black/blue). the reason for this is the ecu can now work correctly and cut power to the injectors in case of a problem. see image below
5) The B7 will also need a switched supply to t17j Brown Pin1 red/grey, I recommend at least an 14 gauge wire supplied from post 30 through a relay triggered from t17e WHITE Pin17 for a total of 3 wires needing to be connected to this pin. see below image
6) finally the b7 also needs a switched power on the T17d Red pin 1 green/yellow and t17d RED Pin 17 green(along with above connections), this can be done the same way as the two relays above, the trigger can be from the same pin t17e WHITE Pin17 or one of the other relays powered from it. use a 20amp fuse to supply 2 relays or a 30-40 amp with suitable 40 amp relay to power both.
Additional Connections: (THESE ARE NEEDED FOR BOTH B6 and B7)
Run from the plug you adapted to the 2.7T harness
1) 12v+ post 30(nut in plenum chamber) to ecu pin 62 red (T10m BLACK pin4 red on 2.7T plug)I RECOMMEND A 10AMP FUSE INLINE
2) T17d RED Pin5 blue/brown - to A/C Compressor (3.0 or 1.8T compressor required other side of the plug from the compressor goes to ground)
a)need a way to trigger the codensor fan, a second pressure switch tee'ed into the condenser from an c5 a6 or b5 s4/a4 should work(Currently developing a trigger for the stock sensor that should eliminate the need for any other sensors being added)
3) Vehicle Speed Sensor 5k limit
A4 1.8T 2003+ - Run a wire from T17b GREEN (in the kick panel drivers footwell, left hand side for RHD cars) Pin17(B6) or Pin9(B7) white/blue to T10 brown Pin3(2.7T plug), I suggest a quick disconnect for easy harness removal
Starter Interlock Relay
coming soon should you want to retain this functionality. 3/15/07
Quick and easy fan wiring for those asking
*********** ADDED 08/06/2015 Thanks to kristof for testing on his car ***********************
b7 ABS 8.0 to 5.7 swap
This needs to be done to retain abs in a B7 because the 2.7 ecu (apb) only communicates with the abs controller through the k-line, which is not present on the 8.0 controller
items needed
5.7 abs module and pump(with attached g201 brake pressure sensor)
B6 master cylinder to abs lines
5.7 module plug do not cut the wires going to the brake pressure sensor take it with them(with good size lead if not re-pinning and plan to crimp)
g202 yaw rate sensor (behind the stereo head unit)
Bosch 8.0 | Bosch 5.7 | |
pin 25 red/lilac | fuse s242 | pin 6 red/lilac |
pin 32 black/brown | A20 S7 | pin 23 black/brown |
pin 13 brown | ground 26 | pin 1 brown |
pin 38 brown | ground 26 | Pin 5 brown |
pin 31 blue/brown | g44- | pin 30 blue/brown |
pin 19 blue | g44+ | pin 31 blue |
pin 18 black | g45- | pin 15 black |
pin 6 yellow | g45+ | pin 16 yellow |
pin 33 green/yellow | g46+ | pin 29 green/yellow |
pin 20 yellow | g46- | pin 14 yellow |
pin 34 black | g47- | pin 28 black |
pin 22 green | g47+ | pin 12 green |
pin 26 orange/black | A121 Can high | pin 24 orange/black |
pin 14 orange/brown | A122 Can low | pin 40 orange/brown |
pin 36 white/blue | A27 vss | pin 33 white/blue |
pin 11 black/red | cluster t32/16 | pin 17 black/red |
pin 16 grey/red | cluster t32/22 | pin 20 grey/red |
pin 30 red/black | A18 F(brake light switch) | pin 32 red/black |
pin 8 white/red | F47(Brake Pedal switch) | pin 37 white/red |
pin 4 black/green | pin 6 E132(Anti-Slip Control Switch) | pin 27 black/green |
G201 Brake pressure(on 5.7 pump) | ||
yellow/black | pin 25 yellow/black | |
yellow/green | Pin 26 yellow/green | |
red/white | Pin 42 red/white | |
G202 Yaw rate Sensor(behind head unit in b6) | note this must be oriented the same way as it was originally | |
white/black | pin 39 white/black | |
white/lilac | Pin 21 white/lilac | |
white/green | Pin 9 white/green | |
green/black | Pin 8 green/black | |
white/yellow | Pin 10 white/yellow | |
white | Pin 41 white | |
K-line | connect to t10a/6 in ecu plenum(same wire as 2.7t ecu connection) |
