So A quick run down of the after run pump and how I usually hook it up. Using the b6 relays I replace the one that supplies the ecm power with a generic 5 post relay so that when the key is on it powers the ecu, and ll the associated bits. when the key is off it supplies power to another relay, both the coil and supply pole (I use the stock b6 one thats closest to the fron of the ecu box), then using the switched ground from the after run switch, T10n (orange plug) pin 9 brown/red, to trigger the relay, which supplies T10n (orange plug) pin 3 red/yellow with power. When I get home I'll add another diagram to the first page if this is unclear. As for the crash signal you can tap it at a few modules, the easiest being the ccm under the carpet, T12i (black plug) pin 8 lilac/blue. Side note on my 2004 1.8 the wire was on the body plugs and worked, so its hit or miss if its actually been discontinued.
If you do wire the afterrun pump do like tankdeer said and swap the switch for a lower temp one, otherwise it will probably never turn on unless you do a hard pull then immediately turn of the car, which is a big no-no for turbo cars.
