Results 1 to 18 of 18
    Established Member Two Rings dogears's Avatar
    Sep 05 2014
    How to launch S6 question
    Hi guys,
    I am about ready to order (build) a 2015 S6. I drove it twice but did not get a chance to launch it from a stop. I know about the 200 launch limit on the launch control, but is it possible to get a better than dog start without using the launch control? Nothing crazy, but is it possible to spool a little by holding the brake and giving it some gas?
    I am going to load it up btw.... Still deciding on night vision. Any thoughts? Also, black optics versus thesprot 20s with double spokes.
    Thanks!!!
    Established Member Two Rings mwar99's Avatar
    Oct 06 2012
    Deposit on 2014 911 GT3
    Northern NJ
    You can spool a little, not like the launch control though.
    2013 S6 - Estoril Blue
    2015 911 GT3 - Delivered!!!
    Veteran Member Four Rings sciblades's Avatar
    Mar 20 2009
    North Salem/Palm Beach
    If you leave traction control in you can brake boost.
    2016 RS7 Stinger VIP laser and radar, Unitronic Stage1+
    Gone
    2013 C7 S6- v1 and LI- Unitronic tuned]
    B8 S4
    06 a3 Full Votex Kit, Unitronic III, apr tbe, precision 750 FMIC, apr HPFP forge dvi, EVOMS cai, BSH gt3076r turbo kit, IE rods, sb stage IV, LSD, on meth
    Veteran Member Four Rings Xtek's Avatar
    Jun 09 2013
    Quote Originally Posted by sciblades View Post
    Careful doing this, without a wet clutch it puts a little more stress on the drivetrain.
    - Chad
    2014 S6 Estoril Blue - APR Stage 1, AWE Exhaust
    I have USB HEX+CAN VAG-COM cable, if you need mods let me know.
    Sep 05 2014
    Thanks guys..... Not talking about crazy launch, just stuff like getting the jump on a lane merge when at a red light. Something for a slightly better jump than just hitting the gas pedal, which has a bit of lag. Even in S or manual mode.
    Senior Member Two Rings TunTap's Avatar
    Oct 17 2013
    LA
    On the RS5, it lets you do half-launch control where you rev up to whatever rpm you want, drop the brakes, and take off. Doesn't seem to work on the S6 as well though - it just bogs down. As far as night vision - I personally am not a fan, it makes the windshield glare a lot in the sun, and the big plastic blob above the instrument cluster isn't very appealing. Oh, and it's a common thing to rattle as well. The functionality is mostly useless unless you drive at night on country roads a lot.
    '05 S4 Avant
    Gone: '13 S6 | '14 SQ5 | '13 S5 | '11 Q5 | '06 A3
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    Quote Originally Posted by TunTap View Post
    ?.. As far as night vision - I personally am not a fan, it makes the windshield glare a lot in the sun, and the big plastic blob above the instrument cluster isn't very appealing. Oh, and it's a common thing to rattle as well. The functionality is mostly useless unless you drive at night on country roads a lot.
    As for windshield glare and rattles, you are referring to the HUD which is standard on 2015 S6 now.
    The night vision itself is unfortunately an expensive item. It does work...when it's below 77F...but I feel it has limited functionality unless you have many joggers darting out in front of you on dark roadways. A8 supposedly has deer or large animal detection, I have not seen if that works on the S6 yet.
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Quote Originally Posted by Xtek View Post
    I believe the S6/S7 transmission, as well as the B8 S4 DSG, all use wet clutches; thus why they don't wear out.
    I know some of the low-output VWs use (used) dry clutches in their DSG units, but I think that's because the torque output is so low that wear is not an issue.
    In high performance cars with dry clutches, they tend to wear very fast. The E-Gear Gallardo is a great example. Those needed to be replaced as often as their manual counterparts, and it's not unusual to have a clutch last ~5,000 miles.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Oct 17 2013
    LA
    Quote Originally Posted by gk1 View Post
    Yes, sorry. I was referring to the bundled night vision / HUD package for the 2013-2014. Forgot they're separate now.
    '05 S4 Avant
    Aug 23 2014
    Parker, CO
    Quote Originally Posted by dogears View Post
    Who are you merging in on? I had a Ferrari (not sure of type - best guess F430) try to get the jump on me the other day and fail. I'll give him the win on sound anyway.
    Sep 05 2014
    Everyone!
    Quote Originally Posted by ZaphodBx View Post
    Veteran Member Three Rings Ensoniq's Avatar
    Jul 12 2014
    Raleigh NC
    Everyone!
    +1
    2014 Phantom Pearl Black RS7
    2014 Mercedes ML350 4Matic AMG package
    2008 Corvette Z06 (Sold)
    1996 Corvette Collectors Edition (Sold)
    Jun 09 2013
    Getting the jump on a lane merge... I do this all the time even with 50% throttle. But I've found it faster to roll into full throttle rather than just floor it. Stops the TCU from thinking too hard.
    - Chad
    Aug 23 2014
    Parker, CO
    Everyone!
    Fair 'nuff. ;)
    I definitely agree that rolling into full throttle seems to work much better... The car doesn't seem to do well with just mashing the accelerator.
    Sep 05 2014
    Hence my question.... I did mash it on the test drive and noticed this. I was not aware of the 200 launch limit at the time so I did not try spooling a tad by holding the brake.
    Fwiw, I used to drag an 87 Grand National that was pretty worked! It was a nice 11 second ride. Brake torquing was a way of life with that beast!
    Fair 'nuff. ;)
    Dec 10 2011
    CLT | MKE
    Turbo lag isn't much of an issue on the 4.0T. Throttle response is a bit delayed but greatly improved in S mode. The S6 hauls off the line regardless, certainly woudn't call it a dog. You will smoke most anything without even using launch control.
    -Hayden
    Dec 22 2013
    VA
    Using M with the paddle shifters works well. Or M on shifter rolling on 1st is pretty responsive.
    Oct 06 2012
    Northern NJ
    Quote Originally Posted by LINDW4LL View Post
    +1
    I have no issues mashing the throttle at a red light in S from a dead stop, no lag for me. Still waiting for someone to even be close when I need to merge into one lane. Was behind an F Type R Coupe this morning and I kept with him with no issues and he mashed the throttle, trust me and I don't have a tune. Now sound of the exhaust - Jag wins hands down...
