Thank you, Phil! I pulled everything apart and the relays looked fine, but I swapped them anyway. It's still not working.
I decided to try to hot wire the A/C cooling fan directly to the battery. I tried two scenarios - I jumped the brown wire directly to +12V and then jumped the brown wire directly to +12V and the purple wire to ground. In both scenarios, the main radiator fan powers on high, but the smaller passenger-side A/C cooling fan does NOT power up at all.
Am I correct in thinking that the A/C cooling fan should be powering up when directly connecting it to the battery this way? If so, it seems that my fan is dead.
Is it possible to swap out the passenger-side A/C cooling fan without removing the entire radiator fan assembly or radiator cross-brace up top?
By the way, I have a VAG-COM cable and I plugged it in to find that I've tripped the following fault:
001152 - Coolant Fan Control Circuit 1
P0480 - 002 - Electrical Malfunction - Intermittent
Thanks for the help!
