Results 1 to 40 of 40
    Oct 20 2008
    Denver
    B8/8.5 S4 Random Questions Thread
    Figured the B8 S4 section needed one of these threads. The B7 section has one of these which is where i got the idea. The concept works great and is very helpful for those wanting to ask random questions or have concerns that they may come across, without having to start new threads every day.
    So for my first question, does anyone know the function of the "heat sink" thing behind the battery in the trunk? I've seen a few builds where it's removed completely for more room and wondered if it's necessary to have.
    Thanks in advance,
    Joe
    p.s. not my photo
    Account Terminated Four Rings
    Mar 08 2010
    San Francisco, CA
    I thought it was some kind of amplifier for the B&O.
    Feb 13 2004
    Silicon Valley, CA
    Quote Originally Posted by westwest888 View Post
    B&O amp is in the left sidewall cubby.
    Kevin - Moderator, Audizine
    Aug 27 2008
    Houston Area
    By "heat sink thing" -- you mean the control module that has a electrical harness plugged into it?.
    In my S5, it's 8K0907163B - AWD control module - I wouldn't recommend taking it out.
    Oct 20 2008
    Denver
    Quote Originally Posted by B8_Jim View Post
    the reason why i ask is because i'm trying to find a place under the floor to put my 3 gallon tank for my new setup, and i've seen somewhere that a 3 gal was place directly where this control module currently is.
    actually found it, gejay's B8 setup
    Senior Member Three Rings Nicholassballs's Avatar
    Jan 18 2014
    Boise / Idaho / North-West
    Another question, are we able to set different fan speeds between drive/pass sides?
    '06 Toyota 4Runner SR5
    '06 Audi S4 25Quattro Anniv. Ed. #60
    '14 Audi S4 6MT Progress thread
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    yes i believe so. at least i can in my B8.5 i think. Ill have to try it again. Yea the sales guy said the sub was under the tire i was sure lol. I knew it wouldn't be there.
    Established Member Three Rings roger v's Avatar
    Oct 24 2013
    Quote Originally Posted by chaos2984 View Post
    How do you set different fan speeds? I know that you can set different temps.
    2014 S4 | AWE | Deval | Forgestar | GMG | H&R | P3 | Roc Euro | SPC | StopTech | Toyo | 3M
    Jan 18 2014
    I figured it would be similar to how you adjust temps separately but I can't figure it out.
    Aug 27 2008
    Houston Area
    There is only one fan motor...
    Jan 18 2014
    Oct 20 2008
    Denver
    we should definitely sticky this.
    Feb 25 2013
    MI
    Kind of related to random questions lol
    Anyone have advice for a real small door ding? Noticed it when I cleaned the car yesterday, no pics, but I can grab some if it would help. About half the size of a dime, you can only notice it when looking at light reflection.
    Are these kind of things useful?
    http://www.aliexpress.com/item/Dent-...BnQaAhB58P8HAQ
    Oct 20 2008
    Denver
    ^ wish i could help! hope others can chime in
    also, anyone use Panavise mounts before? install is super easy
    http://panavise.com/pdf_indash/75102-109.pdf
    Mar 28 2009
    Minneapolis, MN
    Quote Originally Posted by AudiTFSI3o3 View Post
    Panavise mounts are great. Nice & sturdy and they hold the phone very snug. I'm using one in my IPhone 5 setup: http://www.audizine.com/forum/showth...-in-my-B8-5-S4
    Oct 20 2008
    Denver
    i give up on new, random threads.
    Veteran Member Four Rings KRp220's Avatar
    Aug 23 2011
    NH
    i'll play. on my B7, I could hold "auto" on the thermostat to make the temp on the passenger side the same as the driver's side. tried to do it in my B8 with no luck. am I missing something? it was a nice feature to have when your GF wants her side 10 degrees warmer...
    2013 S4 // ESTORIL BLUE // 6MT// RS BUMPER // GIAC STG 2 // FORGE CC // AWE+SCORPION // ECS INTAKE // BILSTEIN+H&R // VOSSEN VFS5 // PSS 265/30/20 // AK // 034 MOUNTS // SB STAGE 3 CLUTCH // CR 15
    + ECS Diffuser, BFI shift knob, tints, sports diff, j-codes, Akebono pads, SS clutch line, Ceramic Pro...
    GONE 2010 S4 // QUARTZ GREY // 6MT // GIAC STG2 // AWE TRACK // ROC EURO // 034 TRANS MOUNT // H&R OE's // AG M610 FF 19x8.5 // + random stuff
    Feb 25 2013
    MI
    Quote Originally Posted by KRp220 View Post
    Push and hold the button in the middle of the driver side temp knob, it'll sync them up
    Aug 23 2011
    NH
    Quote Originally Posted by drob23 View Post
    word. thanks!
    Oct 20 2008
    Denver
    does anyone know how long the first trial of Tmobile 3G lasts? I don't tether at all just use it for live updates on traffic and closures. i'm waiting for it to end so i can grab a SIM from walmart or somewhere cheap
    Aug 27 2008
    Houston Area
    It was was 6 Mo when I got my '13 S5 2 years ago. But traffic is through the Sat Radio connection - it's for 4 years - I don't have T-mobile any more (only use a data connection occasionally) and I still have traffic.
    Jan 18 2014
    I'm pretty sure 6 months. Have you checked your usage?
    Feb 25 2013
    MI
    It's somewhere in the 3-6 month time frame. The traffic and closure updates are via sirius traffic (which is a 4 year included free subscription). You can run a sim from trusim (there's another choice but I forget it) if all you care about is sending the car destinations via phone/computer or doing google voice searches. If you need the wifi-hotspot or google earth, then I'd suggest something else.
    Oct 20 2008
    Denver
    Quote Originally Posted by Nicholassballs View Post
    not yet, at work now will probably in a few hours.
    funny thing is my XM just expired, yet I still get live traffic?
    just saw this. didn't realize they were separate haha
    Oct 20 2008
    Denver
    has anyone upgraded their bulbs before? i'm guessing the OEM D3S bulbs are 4300k?
    Senior Member Two Rings Dragoncub's Avatar
    Oct 07 2014
    New York
    [This thread should be a sticky to cut down on the number of threads, its worked really well in other forums]
    How do you lock the doors from the outside if you have the car started? I went to warm up the car in the morning, the key was in pocket and tired to lock the door from the handle and it didn't work, then tried the remote and that didn't work either. Any ideas?
    Mar 28 2009
    Minneapolis, MN
    Quote Originally Posted by Dragoncub View Post
    You have to pull the metal key out of the fob and turn it in the lock like a peasant.
    Oct 20 2008
    Denver
    lol thanks for the bump. i tried long, long ago but failed miserably. no one here seems to mind the 1000s of threads on the same topics, same goes for the mods who apparently don't even do their jobs moderating this section.
    if you have keyless entry you still need to pull the metal key out of the fob, and manually lock the doors from the outside. when the car is on you can't use the fob to control anything
    Feb 25 2013
    MI
    This section has no moderator...only subtek from the A4 boards.
    Veteran Member Four Rings ballinb5's Avatar
    Jan 16 2011
    CA
    I bought a used 2013 and it does not have the 4 yr free sub for traffic. Am I missing something?
    Feb 25 2013
    MI
    Quote Originally Posted by ballinb5 View Post
    You don't see colors on the interstate for traffic? There is an option somewhere in the nav settings to enable/disable it. Presuming that you've done that, I'd give a call to Sirius xm or your Audi SA to track down the issue.
    Jan 16 2011
    CA
    No i do not. I only see the colors when sirius xm has a free trial out during certain times of the year... Are you sure you're not just subscribed to xm?
    Oct 20 2008
    Denver
    definitely not. my XM expired November but traffic is still active
    Oct 14 2012
    Empty...for now...
    SE PA
    Anybody else notice this unusual shape to their B8.5 front crash bar? I don't remember my B8 crash bar looking like this:
    SOLD 2015 Daytona Gray S4
    Mar 28 2009
    Minneapolis, MN
    That's normal. The crimps give it strength.
    Oct 07 2014
    New York
    Thanks, I guess I'll revert to being a peasant as needed, lol.
    Oct 07 2014
    New York
    Is there a way to increase the intensity of the heated seats? I would like for them to be a little more toasty. From what I remember, my B5 A4 seats used to get much more hotter.
    And oh man how I wish the steering wheel was heated as well
    Oct 24 2013
    On mode three my heated seats feel like they are going to burn through the seat.
    Jan 16 2011
    CA
    Quote Originally Posted by roger v View Post
    Same but my man does have a point about the b5 a4... Very toasty
    Oct 07 2014
    New York
    Not when you've got on a heavy winter jacket. I don't think its get cold enough in LA for you to understand what it feels like when its below 20 degrees.
