Results 1 to 40 of 60
    Veteran Member Three Rings Rodgman15's Avatar
    Jan 12 2014
    Fargo, ND
    Clutch question: pull tranny or motor?
    97 A4 TQM
    Going to be doing my clutch this upcoming weekend, flywheel, pressure plate, and disc. Being that I don't have a lift and only jackstands, I'm assuming it'll be easier to pull the motor. My question is, is the throw out bearing replaceable with the tranny still in the vehicle? The pilot bearing will obviously be replaced on the motor side, but my biggest concern is the throw out bearing being inaccessible. Thanks in advance to anyone with any advice!
    Sent from my HTC One
    May 19 2014
    2000 VW jetta 1.8T, 2001.5 audi s4 stage 3 rs6-r turbos
    Sterling, Virgijnia
    should be ez to get to with motor out if its anything like my b5 s4 2.7tt
    Oct 30 2008
    3 B5's
    Big Lake, MN
    Pull the motor for sure.
    "During my service in the United States Congress I took the initiative in creating the Internet." Al Gore, former Vice President of the United States of America
    2016 SQ5- Wife's ride
    2000 A4 Avant 1.8TQMS- Daily Driver
    2000 S4- Working?
    Jan 12 2014
    Fargo, ND
    Fudge. I was all geared up to bench press my tranny back in ;).
    Sep 24 2010
    Costa Mesa, SoCal
    I've done B5 clutch replacement twice on jack stands, with the engine in. This last time I toyed with engine pull but ultimately decided against it, one big reason was that I didn't want to mess with power steering lines and bleeding, but also didn't want to pull the engine harness. Doesn't help that I didn't have a cherry picker lol.
    If you get something like the Harbor Freight trans jack, it isn't too bad. Just gotta lift the car really high.
    2001.5 S4 Avant: Motoza E85 Stage 1+, SSAC HFC DPs + Borla 3" catback, APR bipipe, AWE SMICs, DW300 fuel pump, TTV FW + B7 RS4 clutch, JHM shifter, metal clutch slave + SS line, 2.0T coils, lowered, Aero wipers, SS brake lines, receiving lots of love ($$$)
    2001 Corvette (C5) Z06: just getting started
    2001.5 A4 1.8TQM: gone and missed. Parting out.
    Veteran Member Four Rings GrapeBandit's Avatar
    Dec 13 2010
    FL
    I have to pull my trans. going to do ot tomorrow. still deciding if I want to pull th3 engine instead. dropping transmissions is my least favorite thing in the world.
    r.i.p.CASABLANCA B5 1.8t
    r.i.p.BRILLIANT YELLOW B5 30V
    PCV? Just dump it on the ground!
    Jan 12 2014
    Fargo, ND
    It would be a no brainer if I had a lift, or even a true trans jack, but from what I can tell by the DIY articles I've read it's simply easier to pull the motor, even if it takes a bit longer. Now that you mention power steering lines... Ugh. I do need to replace my PS pump though so maybe that'd be a good thing to pull the motor.
    I feel like lowering the motor in would be easier than lifting the tranny up and less risky in terms of getting everything lined up.
    Oct 30 2008
    3 B5's
    Big Lake, MN
    Quote Originally Posted by MetalMan View Post
    Completely unnecessary to remove the PS pump. Just like the AC compressor, you just unbolt it and flop it to the side. Last time I pulled my engine I did the rack, and bleeding took about 5 seconds.
    2000 S4- Working?
    Jan 12 2014
    Fargo, ND
    That's definitely good news. I ditched the AC months ago so I won't have any of that garbage to contend with.
    Jun 30 2008
    Erie, Pennsylvania
    - You don't have to mess with power steering bleeding. Just toss the pump off to the side without disconnecting the lines. Not a big deal at all.
    - The thing you would worry about is the trans cooler lines, if it's auto-trans. Still not a huge deal, though.
    - One BIG plus to pulling the engine is that you get free access to drop the pan and clean your oil pickup. This is the killer of 1.8T's, so I highly recommend you do it.
    - Yes, you can replace the throwout bearing with the transmission in the car. You can even to the input shaft seal if you want.
    2001 Laser Red A4 1.8TQM, 5-Speed Swapped, 4.11 Final Drive, APR 93, R8 coil packs, Labree HFC & DP, 2.5" Exhaust, ST Coilovers, 034 RSB, A8 Brakes Front & Rear, 18" RS4 Reps
    "You need to know what you are doing...Its like a rainbow jungle in there." - Redline380
    Oct 30 2008
    3 B5's
    Big Lake, MN
    2000 S4- Working?
    Jan 12 2014
    Fargo, ND
    Optimally I wanted to replace all that stuff (oil pickup tube and what not), but after spending near $1000 on my clutch setup, cleaning the pickup tube is my only option lol. I'm DEFINITELY going to be doing that along with replacing the PS pump (mine is toast).
    In terms of cleaning the pickup tube, guessing a can of carb/brake cleaner will work just fine? Along with removing visible contaminants obviously.
    Veteran Member Four Rings nynoah's Avatar
    Jan 16 2006
    01.5 A4 avant Past cars: 95 S6, 85 Golf II VR6, 2 sciroccos, 92 Corrado VR6, 86 Euro BMW 535 Alpina
    LA CA
    Pull the engine and tranny as a unit. Much easier to deal with that way.
    2001.5 black on black avant 5spd, EFR 6758, Pag Parts band manifold, Vibrant GESI High flow CAT, 2.0L 06A, IE intake manifold, built AEB head, 1000cc Boosted Euro Tune, bosch 044, Ringer Racing stage 3 hybrid Organic/Cerametalic 240mm clutch, S4 interior upgrade, full S4 brakes front and rear with lines, 17in OZ Racing Ultraleggera, 034 HD suspension arms, Stern soft mounts, mirimoto bixenon etc. http://www.audizine.com/forum/showth...s-Build-thread
    Oct 30 2008
    3 B5's
    Big Lake, MN
    Quote Originally Posted by Rodgman15 View Post
    A pickup tube is around $20, and I don't know how much the gasket is but it aint a ton. You can spend an extra $50 to do it right.
    Pro tip- pick up a bottle of zip strip. Its nasty stuff, but literally melts sludge away.
    2000 S4- Working?
    Sep 24 2010
    Costa Mesa, SoCal
    Sounds so simple haha. Didn't even think of pulling the PS pump like you do with the AC compressor! Still doesn't help if you don't have a source for borrowing a cherry picker and engine stand or have the space to store them (if you buy them).
    Oct 30 2008
    3 B5's
    Big Lake, MN
    For some reason I am in a pic-happy response mood this morning
    2000 S4- Working?
    Jan 16 2006
    LA CA
    Don't be a cheap ass, buy a new pickup tube. If that thing clogs, your engine is toast. Your 50 dollar savings just cost you 2K or more. Cleaning it.... well unless you have real cleaning solvents at your disposal for FREE, it not worth the 30 dollar savings. The oil pickup tube is the Achilles heel of the 1.8t.
    Jan 16 2006
    LA CA
    Buy a used one of Craigslist. Then sell it for what you paid for it when done.
    Jan 12 2014
    Fargo, ND
    Quote Originally Posted by nynoah View Post
    Lol i didn't realize it was that cheap.
    No worries on being a cheap ass haha, I've got thousands in tools, and I'd have access to a hoist if my old man hadn't retired and sold his shop a year ago. At my work I have access to every chemical under the sun, there's nothing aircraft stripper can't remove :)
    Dec 13 2010
    FL
    real cleaning solvents such as diesel fuel can be found up the street for cheap. thats what I use in my parts cleaner. its a great degreaser
    Jun 30 2008
    Erie, Pennsylvania
    For the pickup screens: soak in carb cleaner, then light it on fire.
    Replace with new works, too.
    Registered User Four Rings
    Feb 08 2011
    B5 A4 2 liter HTA3586r
    Phoenix, Arizona area
    You don't need a trans jack if all your doing is a clutch/flywheel install. You can do the job with just a single floor jack to lower the transmission down and then back up, you just leave it on the jack pushed back while you are dealing with the clutch/flywheel. When you go to put it back in you just lift it up with the floor jack and slide it into place lifting it slightly from the back so you can turn it slightly and spinning the rear flange to line up the spline with the clutch spline. I have done it that way for years without any problems. It is just tougher if your swapping transmissions since at that point you have to pull the transmission out from car.
    I don't have an exhaust on my car just a down pipe and it only takes me about 30 minutes to have my transmission complete down on the floor and that is with the car on jack stands and 1 floor jack. But then I have done it way too many times on my own A4. lol
    Throw-out bearing is on the clutch fork which will be in plain site and accessible if you pull the transmission out or if you pull the motor out. You will see it once the transmission and motor are separated from each other.
    BTW if you plan on pulling the pilot bearing make sure you have a slide hammer bearing puller, other wise it will be a huge PITA to get out. Also make sure you put the new pilot bearing in the right way seeing 1 side of the bearing has a slightly larger opening then the other, if you put it in backwards the input shaft can catch and drag on it causing shifting issues. The pilot bearing is one of those parts that should only be replaced if it is bad, no point in replacing if it is perfectly fine which is why most clutch kits don't come with one.
    Dec 13 2010
    FL
    ^the best, easiest amd fastest way to remove pilot bearing is with bread...
    Feb 08 2011
    Quote Originally Posted by GrapeBandit View Post
    Haven't tried that, but then it only took me less then 1 minute to remove one with a slide hammer bearing puller and I didn't have to make a mess. lol
    The pilot bearing goes in pretty tight, so it doesn't come out all that easy without some force.
    Dec 13 2010
    FL
    bread method is super quick too, and everyone has some in their house. no need to pay for a tool. I know it sounds weird and most ppl probably never heard of it, but it works like a charm
    Jan 12 2014
    Fargo, ND
    I think I'm going to pull the motor as opposed to the tranny, that way I can service the oil pickup tube. Does the oil pan have a gasket or is it just sealant? If so, RTV red?
    Oct 30 2008
    3 B5's
    Big Lake, MN
    care to elaborate?
    2000 S4- Working?
    Oct 30 2008
    3 B5's
    Big Lake, MN
    yes, aeb's have a gasket. and I think it uses sealant in certain places too, but not positive
    2000 S4- Working?
    Dec 13 2010
    FL
    Quote Originally Posted by redline380 View Post
    care to elaborate?
    look at my above post, I added a video of it. the bread has nowhere to go when its hammer3d in, and it forces the pilot out
    058 blocks get gaskets, 06a/06b sealant
    Oct 30 2008
    3 B5's
    Big Lake, MN
    I don't think the bread method would work on a 1.8t. the race is so narrow it would hard for it to grab. I kinda want to try it though
    2000 S4- Working?
    Feb 08 2011
    Ok but it not might not work on every car seeing it will depend on how wedged in that pilot bearing is. I tried doing it like that but using something other then bread it it would not budge which is why I ended up using a pilot bearing puller which I have used a few times already.
    BTW the bearing in the video is pretty large while the one on the A4 is really small and has very little space behind since the hole in the crank is not very deep.
    Dec 13 2010
    FL
    I have done it on my 1.8. do you think I just bable nonsense
    Oct 30 2008
    3 B5's
    Big Lake, MN
    No, but that's impressive. I'm totally trying it next time. last time I had a hard time finding a slide hammer attachment that would fit inside the bearing nicely
    and I forgot. not sure if your avatar picture was taken in person, but I got one in person last week
    2000 S4- Working?
    Dec 13 2010
    FL
    haha. i know it sounds asinine, but it really worked. ive done it twice on 1.8t pilot bearings. believe me, I was skeptical before I tried, and surprised after it actually worked..lol
    I forgot what size socket I used, but I put the socket in backwards to have the most flat area facing the engine, put the extension inside, and hammer3d away
    Feb 08 2011
    But was it that easy like in that video? Because it is working on surface area and pressure, the smaller the bearing surface area on the back means less pressure against it to push it out. The 1.8t pilot bearing has very little surface area since the body is so small.
    Dec 13 2010
    FL
    ^it was just as easy as it looks. like I said, I was surprised myself how well/easy it worked out
    Oct 30 2008
    3 B5's
    Big Lake, MN
    Quote Originally Posted by M-Hood View Post
    Think about that longer. Same force over smaller area equals greater pressure.
    2000 S4- Working?
    Feb 08 2011
    Yes but only if pressure is still the same. I tried doing this with something other then bread and only thing it did was waste my time. lol
    Dec 13 2010
    FL
    what did you use? grease? I know ppl have tri3d grease and failed. bread is thicker than water...lol
    Dec 05 2007
    It works. Guy in the B6 section did it and they were making fun of him for it. Why? Because he wanted to save some money, I guess
