Page 3 of 8 FirstFirst 12345 ... LastLast
Results 81 to 120 of 299
  1. #81
    Jun 05 2009
    2020 Ducati Panigale V4S
    Scottsdale Arizona
    ^ Looking good!
  2. #82
    Veteran Member Four Rings avantagg's Avatar
    Jun 21 2015
    1999 T4 Eurovan
    Maine
    Those came out great Ty! Love the plate too.
    2012 B8 Avant (3.0t Swapped)
    034 DP | APR UC | Ported Charger | Mertop Headers | Milltek Resonated Exhaust | Bilstein PSS-10 | Alu Kreuz | CR-15 | H&R Sways | 034 Inserts | Ecodes | A5 Cluster Swap | 3G+ MMI | RS4 FBSW | Black Headliner Swap | BUILD THREAD
  3. #83
    Veteran Member Four Rings CONative's Avatar
    May 06 2015
    B8 A4 Avant / Subaru Outback Limited / Honda Odyssey
    Looks sharp....dammit, I need to get mine installed now lol - shot you a PM Jim about this weekend
    Cheers,
    Ry-man
  4. #84
    Senior Member Two Rings shellraider's Avatar
    Dec 03 2015
    North Dakota
    Quote Originally Posted by avantagg View Post
    Thanks man for all the help!
  5. #85
    May 06 2015
    After sitting in the basement for three months, finally completed this mod over the weekend. Big thanks to @Avantagg for sourcing the Euro-spec lights and @A4 Centaur for lending me his vag-com for the coding.
    A couple tips - I was able to snake the wire without removing any panels entirely, just reached my hand up the side pillar by accessing through either side compartment, and then snaking the wire down by the hinge. For the hatch panel - just loosened the bottom half and was able to fish wire behind the two clips holding the side of the panel, and then up to the inside taillight.
    I did build my own harnesses. $50 for the four connectors needed, $15 for wiring and butt crimps, $10 for the 5th wire for outside tails and $8 for terminal connector pins. I only bought one of the 5th wires as it had terminals on both ends, just cut it and used one for each outer tail. So ~$80 once all said and done. Sorry for the crappy iPhone pics.
    Cheers,
    Ry-man
  6. #86
    Jun 05 2009
    Scottsdale Arizona
    Looking good!! Glad you were able to get it done up right!
  7. #87
    Senior Member Two Rings ECDT's Avatar
    Jul 15 2015
    Philadelphia
    Every time I want to buy the EU FL tail lights for my avant I talk myself out of it and buy other parts cause they make more sense at the time. It looks so great on our cars might have to budget this for next year.
  8. #88
    Jun 05 2009
    Scottsdale Arizona
    They are very good looking lights. Shame you can't see then while driving! Haha
  9. #89
    Veteran Member Four Rings awdconnor's Avatar
    Jun 07 2016
    Portland, Oregon
    Quote Originally Posted by shellraider View Post
    I was finally able to get these popped into the car, I wish I could say I did it myself but the folks over at RedRiverMotorwerkz were willing to tackle it! My favorite update so far. Here are some pictures. It looks like a brand new car. I also found this video comparing the two for those of you on the fence. comparison
    nice! that personal plate... how long have you had it???
    [COLOR="#808080"][FONT=System][SIZE=2]2018 Audi S4 P+ | 034 Stage 2 E85 | Airlift 3P | BBS RSii
  10. #90
    Dec 03 2015
    North Dakota
    Quote Originally Posted by Tiggy View Post
    @tiggy
    Haha right! Well North Dakota has one sole Audi Dealer in Fargo so you really don't see many on the road however i'm still blown away it was available. Most of the typical ones were taken like OOOO, AWDI but some of the other choices were WAGOON, AVANT.
    Anyone looking to do the taillight update, I promise you, it will be one of the best things you have done to your car. Again HUGE HUGE thank you to @avantagg for all the help!
  11. #91
    May 06 2015
    Preach it!
    Cheers,
    Ry-man
  12. #92
    Jan 15 2017
    hey has anyone done a b8.5 sedan halogen to LED conversion? I have LED lamps and the stock LED harness but i'm unsure of the procedure. The only apparent difference is that the reverse light is on the outside lamp instead of inside.
    I have all the wiring planned out just would need someone to verify the proper coding.
  13. #93
    May 06 2015
    Man I feel dumb - they offered halogen housings with the facelifts? Every 8.5 I see has the same style taillights, sedan and Allroad.
    @Gunnark100 might be able to chime in, guy has some good knowledge in that area.
    Cheers,
    Ry-man
  14. #94
    Established Member Two Rings planekiller1's Avatar
    Jan 05 2017
    2000 Trans Am LS1
    Stuart, Florida
    I'm going to dig this thread back I'm installing LED tails in my 2012 Audi a4 Avant and I'm doing my best to follow along but my car only has 4 wires going to the rear lights each only have 4 going to it.
    I have a few questions, is this known and the lights get rewired exactly as specified?
    My Tail lights dont follow the same 12345 pin layout mine are 1234 with no fifth cable where does the 5th cable come from aka added from on the pin out from the 46 module.
    Also coding, but I'm more worried about where the extra wire comes from and how to rewire that? is it directly from the 46 module that my missing wire is from?
    If you need more info let me know I'm looking to complete this, this weekend.
    Thanks,
    -Kurt
    Updated: To reduce confusion.
    I checked this side using a 12v battery and working out what each connector linked up to bulb wise.
    Left Main
    1 Grey / Black - Brake / Turn
    2 Black - Reverse
    3 Green - Sidelight
    4 Brown - Ground
    Left Inner
    1 Blue / Black - Rear Fog
    2 Brown - Ground
    3 Gray - Sidelight
    4 Yellow / Grey - Sidelight
    (Both sidelights are independent bulbs left and right bulbs).
    I have not checked exactly what the right side does because I assumed it was the same as the other side but I am unsure now.
    Right Inner
    1 White / Grey
    2 Brown
    3 Grey
    4 Blue / Grey
    Right Main
    1 Brown
    2 Yellow / Brown
    3 White / Black
    4 Green / Black
    |2012|A4|Avant|S-Line|Glacier White Metallic|2.0TFSI|Quattro|ZF-8Trans|Custom CAI|P3 Gauge V1|Luft-Tecknik Intercooler|
    |Exhaust Cutout|LED Tails|HPA Intake Manifold|HPA Stage 2+ Tune|Catless|Custom Shift Knob|Bagged Airlift V2|
    IG:RS4M8
    Blog Here
    *Vag-Com available to use locally or rent pm for details*
  15. #95
    Feb 06 2019
    Czech Rep.
    hello, thank you for this forum. It helped me with the installation. The work lasted about 4 hours even with lunch :) I wanted to insert a photo, but it is not
  16. #96
    Jan 05 2017
    2000 Trans Am LS1
    Stuart, Florida
    So I reviewed my curent codes:
    195-14848
    196-14881
    197-13320
    198-13352
    203-14849
    204-14881
    205-13
    206-45
    207-73
    208-105
    209-51202
    210-51234
    211-51214
    212-51215
    213-16689
    214-3
    Is there anyone that could help with the recoding?
    Doesn't appear it would be the same?
    Thanks,
    -Kurt
    IG:RS4M8
    Blog Here
  17. #97
    May 06 2015
    Avant Facelift LED Taillight howto
    Quote Originally Posted by planekiller1 View Post
    Thanks,
    -Kurt
    I’m guessing you figured out the wiring? If I remember correctly (and it’s been almost 2 years now), there’s only one value to change in each entry. I believe your telling the car it’s LED versus Halogen. So for the first entry - 195 14848 - it would be 14849, so on so forth.
    Maybe @Gunnark can chime in, he’s pretty savvy with this stuff
    Cheers,
    Ry-man
  18. #98
    Jan 05 2017
    2000 Trans Am LS1
    Stuart, Florida
    Quote Originally Posted by CONative View Post
    Thanks for the reply hopefully he sees this and responds. I'll make a posting on ross-tech as well.
    IG:RS4M8
    Blog Here
  19. #99
    Jan 05 2017
    2000 Trans Am LS1
    Stuart, Florida
    So had a look at the wiring out of module 46 and am working on figuring out which one I need to tap into in order to sort the wiring out.
    I'm wondering if the wire taps into the brake line so that it can do both brake and turn or if it's a seperate pin that needs to be added into the module anyone know?
    IG:RS4M8
    Blog Here
  20. #100
    Veteran Member Four Rings Gunnark100's Avatar
    Oct 21 2012
    Earth...
    No need to add any pins(wires) to the module 46, you just need to make bridges between light functions, to get extra ones working, as you had 4pins now 5, means 4 more channels is needed. Just follow wiring in post1 if you retrofitting EU not US lights.
    Retrofits: FL taillights / MMI 3G & 3G+(Street view incl.)/ Color Cluster & FL S5 Cluster/ BiXenon/ ADS Lite
    Other: ECU Tune/ VCDS Tweaks/ FL Gearknob/ Soundproofing/ Interior 6D Carbon Wrap/ Rieger Rep Front Bumper Valance/ Basic sound(8) upgrade to "ASS"(9+1) + B/O Sub(in sidepanel)/Tweeters + Activsub/ Efficiency Prog via Cluster & Gateway flash/ Sideskirts/ Window Tint/ Wsp Peeler reps/ License plate & Interior leds
  21. #101
    Jan 05 2017
    2000 Trans Am LS1
    Stuart, Florida
    Quote Originally Posted by Gunnark100 View Post
    I'm retrofitting EU lights on a US model thus I only have 4 pins per light and in the main post he has 5 pins per light so I'm just trying to find out where the extra 4 are going to come from?
    Missing is going to be turn signals on both sides and the brake on the middle (inner lights) that's my 4 extra channels I need to work out where those come from.
    Since the brake and turn are combined I'm guessing I need to split a pair of wires joined outside the module? Had a look but the bundle is quite complex to say the least.
    -Kurt
    IG:RS4M8
    Blog Here
  22. #102
    Oct 21 2012
    Earth...
    It is up to you, as you see on diagram, two wires each side from outer to inner, so to say "bridges" between brake and tail, pins 2 and 3.
  23. #103
    Jan 05 2017
    2000 Trans Am LS1
    Stuart, Florida
    I get that the inner brake and turn will be in a (y'd / joined / connected / paired) with the outter lights, but since my brake and turn is the same bulb (US spec) where do I break the two of those from being paired as I don't want the new brake and turn signals connected.
    Thanks for working through this with me
    -Kurt
    IG:RS4M8
    Blog Here
  24. #104
    Oct 21 2012
    Earth...
    but since my brake and turn is the same bulb (US spec) where to I break the two of those from being paired as I don't want the new brake and turn signals connected.
    -Kurt
    Dont overthink, coding will take care the rest(brake and turn will be separate), you cant have yellow and red together...it will look ridiculous:)
    6 adaption channels all separate!
    Channel Old Value New Value New Purpose
    195 14849 14849 Red stripe left
    196 14881 14881 Red stripe left(right)
    197 13320 5125 Brake right(left)
    198 13352 5157 Brake right
    203 14849 12 Turn left inner
    204 14881 44 Turn right inner
    205 13 13 Reverse left
    206 45 45 Reverse right
    207 73 73 Fog left
    208 105 105 Fog right
    209 51202 12 Turn left outer
    210 51234 44 Turn right outer
  25. #105
    Jan 05 2017
    2000 Trans Am LS1
    Stuart, Florida
    207 73 73 Fog left
    Hard for me to not overthink it. I like to know exactly what I'm doing before I do something just how OCD works I suppose.
    Also I'll try these and revert to the old coding and throw the old lights on if I have issues.
    Seeing the coding I don't have turns on the left and right inner lights only ambers on the outter so would I leave those alone?
    Thank you for all the help.
    Kurt
    Side note I see you did some sound proofing where did you add it been thinking about making it quiet roadnoise wise the cutout makes sure I'm loud when I want to be loud.
    IG:RS4M8
    Blog Here
  26. #106
    Jan 05 2017
    2000 Trans Am LS1
    Stuart, Florida
    Alright So new lights are in and they are awesome.
    Issues
    No errors when turning the car on with the light switch in off position
    Pressing brake "right brake light" / "left brake light" MIL on
    switch to auto "left rear light" and "right rear light" MIL on
    when turning the left and right signals on they blink for 3 cycles turn off and the MIL on, but they work however they seem to lightly pulse for those 3 cycles then no longer will turn on until igniton is cycled.
    When turning on side lights they work, but "right rear light" / "left rear light" MIL on
    Turning on fog lights "right fog light" MIL on the light works left fog light does not turn on nor does any code appear.
    Non issues:
    Reverse lights work as they should
    Update:
    Changed some coding by one value and if anything made things worse the brake now says, "left / brake / turn / signal" and "right / brake / turn / signal" or something along those lines.
    Sadly I dont know enough about the coding so don't want to do more harm than good. Any help will be appreciated greatly.
    IG:RS4M8
    Blog Here
  27. #107
    Jan 05 2017
    2000 Trans Am LS1
    Stuart, Florida
    The lights look amazing and I'm sure once all the bugs have been worked out it'll all be worth it.
    Kurt
    IG:RS4M8
    Blog Here
  28. #108
    Oct 21 2012
    Earth...
    Abort process ASAP.
  29. #109
    Jan 05 2017
    2000 Trans Am LS1
    Stuart, Florida
    Abort process ASAP.
    Too late for that stayed up till about 3am working out the kinks and taking little things from each thread I could see compiled a list and made changes.
    Best one I say that help[ed was 203 to 73 which worked and the left fog is now active. Also detection turned off to get rid of those pesky dash notification which also inherently solved the turn signal issue they now work normally the only thing left is sorting out the turn signal inside on the cluster blinks at double speed which is in another thread in which the issue was never solved at least not from what I read. As of right now all the lights function as they should and no errors on dash because 181 is bulb detection and I turned that off for the time being until I can figure out the correct coding needed.
    As far as aborting I'm not a fan someone somewhere will have the issue resolution for this and I wont turn back now with everything running.
    Kurt
    IG:RS4M8
    Blog Here
  30. #110
    Oct 21 2012
    Earth...
    Abort was sayed, in meaning for skipping config in post one, as turns out those are prefl leds. Now i understand what you ment with few words and questions you told at the end!
  31. #111
    Jan 05 2017
    2000 Trans Am LS1
    Stuart, Florida
    Thank you lmao, so anyone know where to go next?
    IG:RS4M8
    Blog Here
  32. #112
    Jan 05 2017
    2000 Trans Am LS1
    Stuart, Florida
    Completed the Mod all lights working thanks to Ross Tech forums. All lights are working as they should the only issue I have is that the cluster turn light blinks twice as fast the only fix anyone knows of is with the Audi VCP or ob11 which I won't worry about. Thanks for all the help from everyone and anyone looking to do this know it is totally worth it!
    IG:RS4M8
    Blog Here
  33. #113
    Senior Member Two Rings DG7's Avatar
    Jun 02 2012
    B8.5 S4 Avant, 8V S3 SB, F36 435i, F56 JCW
    California/Tuscany
    Why do yours light up like that? My LED tails do not light up that way at all. The areas illuminated in your photo are the what light up when you step on the brakes. The pictures I included show how they light up without the brakes being stepped on.
  34. #114
    Established Member Two Rings CAWagon's Avatar
    Mar 06 2017
    California
    Quote Originally Posted by DG7 View Post
    I just sent you a DM. Have a coding question on your pre-facelift LED tail lights. Beautiful car BTW.
  35. #115
    Jan 05 2017
    2000 Trans Am LS1
    Stuart, Florida
    There are infinite possibilities for wiring anyway shoot me with your questions I’ve got this pretty much fully sorted.
    Kurt
  36. #116
    Active Member Two Rings olehenri's Avatar
    Feb 26 2019
    Norway
    Hi! I just installed this on my 2010 Allroad with the oem led lamps but i have one "problem" after upgrading to the facelift. Everything works fine and i have no error codes after using the kufatec wiring and coding, but i have no reverse lights on the car..
    On my oem lights the reverse light is integrated in the bulb socket/holder but in my new lights there are nothing, i have one hole on each outer lamp that are for a w16w bulb, but i do not have any calbes or socket for that.
    Have you had any similar issues? I guess there are no problem to wire up trough the lamp connectors but i have to find a socket that will fit the lamp, does anyone have any ideas?
  37. #117
    Oct 21 2012
    Earth...
    Rev bulbs wiring is inside, but seems you missing those bulbs and holder for it?
  38. #118
    Feb 26 2019
    Norway
    Yes, this hole on both outerlamps. I miss holder and the wiring to that as the reverselights on my oem lights was
    different to this. I have ordered some holders off ebay noe but if those will fit i dont know 😅 what pins do i have to connect to?
  39. #119
    Oct 21 2012
    Earth...
    Quote Originally Posted by olehenri View Post
    If you used kufatec wiring kit, your pins should be connected already! FL avant rev light is outer pins 4
  40. #120
    Feb 26 2019
    Norway
    Yes, everything from the kufatec adapter and oem connectors is connected but i have no reverse light, and no w16w bulb/socket. So i dont quite know how to get that sorted out and what i need that will fit.
