Page 2 of 8 FirstFirst 1234 ... LastLast
Results 41 to 80 of 299
  1. #41
    May 08 2012
    2006 Suzuki SV650
    Atlanta, GA
    ??? I didn't think this required any module replacements.
    '11 S-Line A4 Avant
    '98.5 A4 2.8Q sedan retired after 14 years of service
  2. #42
    Jun 05 2009
    2020 Ducati Panigale V4S
    Scottsdale Arizona
    Quote Originally Posted by jamesmaverix View Post
    Does anyone know the part number of the comfort control module that is required replacement for the avant to achieve this modification?
    Not familiar with replacement of module, just adding wire and changing some values in hidden menu?
  3. #43
    Jun 05 2009
    Scottsdale Arizona
    Any updates this procedure? I remember that Qua77ro had done his as well.
    http://anleitungen.tuning-fanatics-s...8-Reihe_EN.pdf
  4. #44
    Veteran Member Four Rings avantagg's Avatar
    Jun 21 2015
    1999 T4 Eurovan
    Maine
    Ok, I actually had these installed a few days ago with the help of a friend who happens to be a VW master tech. We followed hk5ykw's wiring and coding guide. Lights are all working perfectly but we're now getting error codes for the tail lights, blinkers, reverse and fog lights..... it seems like there may have been some missing channel adaptations in the OP's guide. Has anyone else here done this how-to and run into similar problems? Here's a vid of the lights working below. Any help from those who have tackled this on their own would be greatly appreciated. Thanks!
    2012 B8 Avant (3.0t Swapped)
    034 DP | APR UC | Ported Charger | Mertop Headers | Milltek Resonated Exhaust | Bilstein PSS-10 | Alu Kreuz | CR-15 | H&R Sways | 034 Inserts | Ecodes | A5 Cluster Swap | 3G+ MMI | RS4 FBSW | Black Headliner Swap | BUILD THREAD
  5. #45
    Jun 05 2009
    Scottsdale Arizona
  6. #46
    Jun 21 2015
    1999 T4 Eurovan
    Maine
    Thanks A4 Centaur! I read them all and it looks like the Ross-Tech link might be getting the closest. I might follow up on that thread as well. Anyone else successfully tackled these yet?
  7. #47
    Jun 05 2009
    Scottsdale Arizona
    Man, I hope you can figure out what the issue is with the coding. I was going to start this project and thought the details were all worked out by now.
    Your issue have got to be coding related since the wiring appears to be very straight forward. Keep us posted! And good luck!
  8. #48
    Jun 21 2015
    1999 T4 Eurovan
    Maine
    Problem solved. The OP forgot to mention an important code missing from the code adaptations listed. If you input 0 to channel 181 into control unit 46, it tells the system that the lighting is LED and no longer bulb. Made the change today, no codes. Big thanks to Gunnark100 and rlarsen for the assist. Hopefully someone else will find this helpful!
  9. #49
    Veteran Member Four Rings Gunnark100's Avatar
    Oct 21 2012
    Earth...
    Quote Originally Posted by avantagg View Post
    Nice job - all sorted, small input for future 181=0 (no bulbcheck = no errors in dis and in module 46). Factory setting for 181 regardless which lights(led,bulb,fl led) should be 65535!
    Retrofits: FL taillights / MMI 3G & 3G+(Street view incl.)/ Color Cluster & FL S5 Cluster/ BiXenon/ ADS Lite
    Other: ECU Tune/ VCDS Tweaks/ FL Gearknob/ Soundproofing/ Interior 6D Carbon Wrap/ Rieger Rep Front Bumper Valance/ Basic sound(8) upgrade to "ASS"(9+1) + B/O Sub(in sidepanel)/Tweeters + Activsub/ Efficiency Prog via Cluster & Gateway flash/ Sideskirts/ Window Tint/ Wsp Peeler reps/ License plate & Interior leds
  10. #50
    Jun 05 2009
    Scottsdale Arizona
    Avantagg,
    Such a good looking ride! Congrats on the install and coding.
    I am looking to replicate this mod now.
  11. #51
    Jun 21 2015
    1999 T4 Eurovan
    Maine
    Thanks A4 Centaur! Your avant build is quite enviable.
    Loving the euro LED set-up. Let me know if you have any questions about the install. As the OP mentioned it's fairly straight forward if you get all those parts listed.
    Good luck!
  12. #52
    Aug 12 2013
    Luton
    Do you have any details on the wiring for the comfort control module? It appears according to the Audi retrofit lighting guide you need to move some pins around within 8K0.907.064.DQ module. I can see the pin numbers but I cannot see the names for the connectors. It mentions T17P and T170.
    http://anleitungen.tuning-fanatics-s...8-Reihe_EN.pdf - Page 6
  13. #53
    Oct 21 2012
    Earth...
    This guide is for preFL led lights retrofit!
  14. #54
    Aug 14 2016
    Sweden
    I have the pre-facelift LED version, do I still need to do the coding-part if I want to upgrade to the facelift LED version?
  15. #55
    Oct 21 2012
    Earth...
    Quote Originally Posted by __Audi__ View Post
    Yes
  16. #56
    Aug 12 2013
    Luton
    Just testing an install. I used an aftermarket wiring harness to allow for easier wiring. With the coding mentioned previously I only get the inner strip left/right and fog lights working. Some of my old channel values are different to the ones mentioned. These are channel 197/198/207/208/209/210. Not sure if that makes a difference. This install was facelift LED to pre-facelift Halogen on Audi B8 Avant. Any thoughts on how to get this sorted?
  17. #57
    Jun 05 2009
    Scottsdale Arizona
    ^ You got to have the wiring sorted the exact same way with those splices between the two segments (inner and outer) which I assume is why you only get the inner lamps working?
    I thought the BCM requires the coding for Ohm/Resistance and or power requirements? Regardless, I picked up my kit from [email protected] and didn't have a problem, except the friggen junction blocks in the hatch area and the ones in the right rear.
    The tool I picked up was too big to release the pins (VAS 1978/18).
    For coding I would try the following values which is right out of the instructions I received:
    Channel 46: enter 16017 (Security Access Code)
    Channel 181: Enter 0
    Channel 195: 51201
    Channel 196: 51233
    Channel 197: 5
    Channel 198: 37
    Channel 200: 9
    Channel 201: 41
    Channel 203: 12
    Channel 204: 44
    Channel 205: 13
    Channel 206: 45
    Channel 207: 5
    Channel 208: 37
    Channel 209 51201
    Channel 210: 51233
    I have double checked the values, but don't guarantee anything since I don't know if you have a Kufatec harness or whatever.
  18. #58
    Aug 12 2013
    Luton
    No joy on this coding either. It was an ebay plug in version similar to this - https://goo.gl/kNu2is - I guess it is a wiring issue unless someone has another idea.
  19. #59
    Jun 05 2009
    Scottsdale Arizona
    ^Shoot me a PM if you don't think you can replicate the wiring shown in the first few pages of this thread.
    This is the Kufatec PDF which outlines the procedure and parts: "LED-Rückleuchten B8-ReiheN.pdf"
    http://audi.the-webring.at/Kufatech_...Attachment.pdf
    http://www.motor-talk.de/forum/nachr...-t4398991.html
  20. #60
    Jun 21 2015
    1999 T4 Eurovan
    Maine
    I had luck building my own harness from the parts list by the OP at the beginning of this thread. The coding he listed for the DIY works. I can't speak for the kufatec or aftermarket harness though.... I'm not sure if they are configured the same way as the wiring mentioned here.
  21. #61
    Aug 12 2013
    Luton
    I'll go through and check the wiring on the harness and make the pin adjustments accordingly. Thanks for the help.
  22. #62
    Oct 21 2012
    Earth...
    You said your oem adaption values are different then OP had, so Usa or Uk Luton?
  23. #63
    Aug 12 2013
    Luton
    All sorted. The wiring on the aftermarket adapter was all messed up, so rather than cut loads of wires I released the terminal connectors to place them in the following setup and coding. This might be of use to some guys as it expands on some of the other guides:
    https://www.flickr.com/photos/maveri...posted-friend/
    Channel Old Value New Value New Purpose
    181 65535 0 Let car know LED lights
    195 14849 14849 Red stripe left
    196 14881 14881 Red stripe left
    197 14852 5125 Brake right
    198 14884 5157 Brake right
    203 14849 12 Turn left inner
    204 14881 44 Turn right inner
    205 13 13 Reverse left
    206 45 45 Reverse right
    207 12 12 Fog left
    208 44 44 Fog right
    209 0 0 Turn left outer
    210 0 0 Turn right outer
    200 73 9 Possible Fog left
    201 105 41 Possible Fog right
    I've shown the old wire colours and how they connect to the new lights, plus the two extra wires per side to connect for the brakes and the red strip. The coding was pretty much as per this guide, just a slight variation on the coding for the fog lights/indicators. This is for a UK spec Audi A4 B8 avant (2008) from Halogen to Facelift LED.
  24. #64
    Jun 05 2009
    Scottsdale Arizona
    ^Glad to hear! Now post up some pics.
  25. #65
    Aug 12 2013
    Luton
    One thing though. I'm getting a bulb out warning for the indicators. Its the internal double speed indicator signal. I've changed to code on channel 181 to 0, so not sure what else to adjust. The indicators are working normally.
  26. #66
    Jun 05 2009
    Scottsdale Arizona
    Read the error and then clear it. I bet it comes back but perhaps we can compare the settings?
    Are the taillights OEM or Dectane?
  27. #67
    Aug 12 2013
    Luton
    All sorted. I had 6 channels feeding the signals, so adjusted the code to only have 4 and updated the channel values in my previous post to reflect this. All works fine now. Thanks for all your help.
  28. #68
    Aug 12 2013
    Luton
  29. #69
    Veteran Member Four Rings CONative's Avatar
    May 06 2015
    B8 A4 Avant / Subaru Outback Limited / Honda Odyssey
    So I'm going to pull the trigger on a set here in the next month or two. Most have built their own harness but I wanted to research what was available from kufatec. Anyone tried this kit? $212 is rather pricey; looks like I can stay under $50 if I build my own.
    https://www.kufatec.de/shop/en/Audi/...t3?action_ms=1
    Cheers,
    Ry-man
  30. #70
    Junior Member Two Rings
    Oct 19 2014
    Toms River, NJ
    build your own harness. The Kufatec harness I had tried did not have the correct connectors on either end to work with my US stock tails and Euro LEDs even though I ordered the harness listed specifically for that combination. You won't need the "dongle" if you have or know someone with VAG-COM
  31. #71
    Jun 21 2015
    1999 T4 Eurovan
    Maine
    Quote Originally Posted by ovrwrkd View Post
    ^ this. I went the OEM build your own route and followed the OP's coding and all is good.
  32. #72
    Active Member Two Rings steelblade's Avatar
    Feb 14 2013
    Sweden
    Hi! I have some issue with my lights. Bought the kufatec adapter without the coding box. Tried to change my codes as described in this thread. Not working. I have changed from led to led. EU car.
    My old values is:
    195: 7811
    196: 7843
    197: 5124
    198: 5156
    203: 73
    204: 105
    208: 37
    209: 0
    210: 0
    Any ideas?
    //Mattias
    Audi A4 Allroad 2.0tdi
  33. #73
    Nov 23 2015
    AV4NT.6MT.HPA.K04
    NH
    when i purchased my car it came with this mod from the former owner.
    now i have an issue to troubleshoot.... on my Avant the Right Outer LEDs arent illuminating. this includes DRL/Running light feature as well as Turn Signal; however, the Reverse light IS working.
    I swapped the Left and Right housings to confirm that the Housing is not at fault, so it must be in my wiring somewhere.
    Where should I look?
    I tried poking around with my test meter but could not read any voltage on either the Left or Right sides.... I wonder if this is because its a CAN / LED system?
    I specifically found the one extra wire lead that runs from Module-46 to my Right Outer. I checked for Voltage there (on both the right and left sides, actually, using a paper clip to make contact inside the connector) and got nothin'.
    Stumped! (help?)
  34. #74
    Nov 23 2015
    AV4NT.6MT.HPA.K04
    NH
    also, there is no dash warning light telling me that i have a tail light out
  35. #75
    Jun 05 2009
    Scottsdale Arizona
    Might be the housing has gone bad? Meaning the LED's in that unit are dead?
  36. #76
    Nov 23 2015
    AV4NT.6MT.HPA.K04
    NH
    @a4 Centaur i was able to confirm that the housing is OK (i plugged it into the Left side and it worked!) so i think it's somewhere in the wiring that's gone bad, i'm just having a hard time finding voltage with my test meter. what voltage should Module 46 be sending to the LEDs, 5v ?
  37. #77
    Established Member Two Rings schubby333's Avatar
    Dec 16 2016
    2012 A4 Avant, 2000 Corvette
    Madison Heights, MI
    Just finished up this mod and I'm loving the updated look!
    I've made all the code changes as noted in the original post as well as the change to input 0 for channel 181 but I'm still getting a hyper flash in my cluster. The exterior lights aren't hyper flashing at all... just the interior arrows. Any ideas on how to resolve this? I don't have any codes showing up for any lights being out.
    One clarification I'd like to make (and maybe it's somewhat intuitive): the square connectors near controller 46-Central Conv. where you're splicing into the grey wires (black at top, beige on bottom)... Beige is passenger side. Black is driver side.
    2022 SQ5 Prestige, Sport, Black Optics - Daytona Gray
    2012 A4 Avant Prestige, S-Line, Black Optics - Glacier White, IE Stg 2
    2000 Corvette - Navy Blue
  38. #78
    Nov 23 2015
    AV4NT.6MT.HPA.K04
    NH
    FYI this was the source of my problem, worst corroded connector i've ever seen because the retrofit kit used did not have environmentally sealed connector pins
  39. #79
    Veteran Member Four Rings pierreb's Avatar
    2020 A4 allroad
    NH
    Quote Originally Posted by johnnySV View Post
    Holy cow!!
  40. #80
    Senior Member Two Rings shellraider's Avatar
    Dec 03 2015
    North Dakota
    I was finally able to get these popped into the car, I wish I could say I did it myself but the folks over at RedRiverMotorwerkz were willing to tackle it! My favorite update so far. Here are some pictures. It looks like a brand new car. I also found this video comparing the two for those of you on the fence. comparison
