Results 1 to 7 of 7
    Established Member Two Rings Zaki84's Avatar
    Jul 17 2013
    Adelaide Australia
    Will S4 instrument cluster fit to A4?
    Will instrument cluster from s4 B5 fit to A4 b5 2000 model?
    Oct 30 2008
    3 B5's
    Big Lake, MN
    physically? yup, it sure will.
    "During my service in the United States Congress I took the initiative in creating the Internet." Al Gore, former Vice President of the United States of America
    2016 SQ5- Wife's ride
    2000 A4 Avant 1.8TQMS- Daily Driver
    2000 S4- Working?
    Veteran Member Four Rings GrapeBandit's Avatar
    Dec 13 2010
    FL
    r.i.p.CASABLANCA B5 1.8t
    r.i.p.BRILLIANT YELLOW B5 30V
    PCV? Just dump it on the ground!
    Veteran Member Four Rings bhusted's Avatar
    Sep 11 2011
    B5 A4 4.2L V8
    Kirkland, WA
    If your car has DIS, it should be fairly plug and play. I've retrofit an S4 cluster into my 99.5 car without DIS and the wiring is a little crazy.
    | B5 4.2L V8 Quattro | Tein S-Tech | O.Z. Ultraleggera 18x8 | Stabila Course 22mm rear swaybar | Agency Power WRX swaybar links | S4 front brakes | A8 rear brakes | FX-R HID projector retrofit | Fog projector retrofit | RS4 Grill |Aero wipers |
    Jul 17 2013
    Adelaide Australia
    Quote Originally Posted by bhusted View Post
    Yea mine has DIS ...... So should be just plug in....
    Sep 11 2011
    B5 A4 4.2L V8
    Kirkland, WA
    Yeah. Should just plug in. You'll have to have the mileage reprogrammed to match your car though. Is there a particular reason you're interested in swapping?
    Jul 17 2013
    Adelaide Australia
    That display is not working, and I tried to install those rings that goes around the RPM and speedo and I broke one of the needles ..... and cracked that front plastic cover.
