Results 1 to 12 of 12
Thread: Engine surging
    Oct 15 2021
    Usa
    Engine surging
    So my 2008 A4 2.0 quatro surges as I drive it, especially on low throttle. Around 20-40 miles per hr. The RPMs go up and down and I feel the car surging too. If I step on it, it doesnt do it. Any ideas?
    Thanks.
    Veteran Member Three Rings Low and Behold's Avatar
    Feb 21 2015
    Rip City
    If it’s when the engine isn’t fully warmed up, or on a short drive, I would think it’s the torque converter on the trans. Common. Are you tiptronic?
    Casey | @cshore | B7 A4 Avant 2.0T | B8 Q5 2.0T
    Oct 15 2021
    Usa
    Yea usually when its first started. Its the automatic 6 speed with sports shift... not sure which one that is.
    So its normal? Or is something going to break? :)
    2008 Audi A4 2.0 Cabriolet
    Feb 21 2015
    Rip City
    Yeah that’s tiptronic (automatic) Sadly normal. Mines been doing it for years. Nothings going to break that I’ve heard of. Besides, new TCs are ungodly expensive
    Oct 15 2021
    Usa
    Thats good. But ugh yea I can't imagine the cost. :) Thanks for the info.
    Veteran Member Four Rings Jayz691's Avatar
    Jan 21 2018
    2005 Subaru Legacy GT
    frackville, pa US
    Quote Originally Posted by Tedsterb View Post
    Can get an aftermarket one, thall hold up, for about $800. But also gotta change it, lol.
    Sent from my LM-G710VM using Audizine Forum mobile app
    Jun 13 2017
    nowhere
    Quote Originally Posted by Low and Behold View Post
    what about changing the lifetime transmission fluid and filter? A guy that did it seemed to notice improvement, I think he posted on here. The fluid was black in color when it was drained... yuck
    Jan 21 2018
    frackville, pa US
    Quote Originally Posted by blakefife View Post
    Yes, trans service did greatly help mine. Its not 100%, but id say 80% better. I did a filter/fluid change with ZF parts/fluid, takes about 5 liters. Also did a second drain and fill, which took about 3 liters. Also supposed to do a reset/adaptation drive afterwards, which I haven't done yet.
    Senior Member Two Rings HerNameIsBeast's Avatar
    Jun 11 2020
    Detroit
    I had it done on mine. It didn't help much or at all but I was going to get that service done in either case.
    Sent from my Pixel 4 using Audizine mobile app
    Dec 14 2011
    Chagrin Falls, Ohio
    My avant had the torque converter slipping (surging) all the time, hot (after driving for hours) or cold. After I changed the filter and fluid (with the correct fluid!) the surging has completely stopped and the shifting has greatly improved. YMMV
    Oct 10 2021
    Under your valve cover
    You should definitely try changing out the transmission fluid its to thin and dirty now after years of use. I've had this issue with many automatic cars and 9 out of 10 times to repair or make it better all I had to do with a quick drain and fill to the transmission fluid and never had any issues before. Typically the fluid will xome out black Grey and very thin try using oem fluid to replace what comes out.
    Junior Member One Ring
    Dec 24 2019
    Finland
    I have the same problem. I changed the fluid and filter without sucess.
    Was there an "adaptation" that can be done?
