Results 1 to 31 of 31
    Senior Member Two Rings santos.'s Avatar
    Dec 15 2013
    Los Angeles, CA
    Cross country on a trailer
    Moving to CA, not off to a great start...
    Car (stock height) was too low to get on the auto transport without a little help from some 2x8, but it took bottoming out on the undercarriage for the guys directing me to realize it despite me asking numerous times and being assured it was fine.
    Tore a bit of the insulating (thick felt) material and plastic, nothing mechanical or towards the midline. Should be covered by the insurance I bought but I'm wondering what it should cost.
    Any guesses?
    Senior Member Three Rings kap09's Avatar
    Jun 22 2010
    2017 Grand Cherokee, 2015 Fiat 500e, 2016 eGolf, 1989 Jeep Wagoneer
    My guess is it won't be worth the insurance claim. Provided it's just the panels under the car I'm almost positive you'll be able to buy replacements for less than your deductible. Removing/replacing them is a very easy process as long as you have a set of torx and a phillips screwdriver available.
    Welcome to CA btw! My family is all from Johnstown and I lived there a couple times growing up!
    2014 S4 | DSG | Ibis White | Sport Diff | MMI | Carbon Atlas | B&O | Side Assist | SC Badged
    GIAC Stage 2 v2 | GIAC DSG | Roc-Euro Intake | AWE 102mm | Brembo 380mm | Deval Rear | OZ Leggera | Michelin PSS | OE Sport | AluKruez | H&R Sways | 40% Pinnacle Tint | Hoen Endurance | VCDS Mods | Escort 8500 x50
    Past Rides
    2013 S4 6MT//2010 A4 Quattro//2000 BMW 323i//1991 Integra//1990 Jetta//1993 Civic
    @kap9 on Instagram
    May 17 2012
    Houston, TX
    uhaul trailers blow, but for the future, i would suggest not loading a car going up hill. it only increases the angle you are loading. its better to face downhill and it will reduce the angle you are driving up onto the trailer. I used to rent uhaul trailers for moving and buyiing a few camaro's when i was building them for HPDE's. I learned a few tricks along the way.
    Veteran Member Three Rings lv2000's Avatar
    Dec 04 2004
    Current. 2018 s6 prestige Past-997 turbo/ Audi S7 /13 A6 /b8 s4 /b8.5 s4 /b6 s4
    Las Vegas
    its probably 200 bucks just be careful i damaged a eval line from discount lifting my car incorrectly and cracked a plastic piece didn't look bad 2 days later check engine light came on the repair was 1200 bucks ! the plastic eval line was over 5 feet long welcome to west coast
    Dec 15 2013
    Los Angeles, CA
    Thanks guys, actually moving back! Excited except for the long drive, too adventurous (cheap?) to do it any other way though!
    That incline was much more level in person, we tried moving the truck to get it to dip the trailer down but didn't have any good areas to do it. Wood was the only way.
    Here's a closer look, hopefully the damage is just a flesh wound. Good to know those are cheap parts.
    In case it's worse than it seems, I have $5000 worth of coverage for the car through Uhaul (not my personal insurance). What lines are those running on the right side?
    Dec 15 2013
    Los Angeles, CA
    Quote Originally Posted by lv2000 View Post
    I think this may have happened unfortunately, there is some fluid leaking it looks like. Does the plastic fuel line run on the right side? Anything else it could be? Why the hell would the fuel line be that superficial??
    May 17 2012
    Houston, TX
    if its fuel you should def. be able to smell it immediately.
    Dec 15 2013
    Los Angeles, CA
    I could only see it from the other side, it's hard to see or reach from the same side. Couldn't get a hand on it to dab and smell, couldn't smell it from the side... Anything else it could be?
    Dec 15 2013
    Los Angeles, CA
    Here's a better shot of the "leak"
    I was able to get a finger on it, doesn't smell like gas and is actually pretty thick and greasy. Any ideas? It's on the plastic just behind the passenger wheel, right before the thick felt liner starts. Could have been there for a while for all I know.
    Jun 06 2013
    Model 3, MK7 GTI
    Carrollton,TX
    130 from Jim Ellis vw. Ordered the part because mine ripped on an abnormally large speed bump
    2016 M3 Mineral White
    2014 S4 Ibis White - Sold
    Dec 15 2013
    Los Angeles, CA
    Quote Originally Posted by milk242 View Post
    Nice. That per side? Have the part number by chance?
    Jun 06 2013
    Model 3, MK7 GTI
    Carrollton,TX
    Quote Originally Posted by santos. View Post
    It's per side. I believe you need the driver side correct?
    http://www.jimellisaudiparts.com/pro...K0825207C.html
    Aug 05 2013
    N/A
    Could be trans fluid, could be oil from when you had your oil change done poorly and some leaked out of the canister as they open it.
    Dec 15 2013
    Los Angeles, CA
    Thanks Milk, it's bilateral sadly, but that link will be good. Please tell me $100 shipping is a typo though!
    Nice to have you back Swank ;)
    Haven't even had my first oil change yet, womp womp. Would have to have done some serious damage to be trans fluid right?
    I'm almost due for my 5k service, maybe I'd better just let them check everything and tell me the damage. Hopefully it's just the lining and I can do it myself. Car was running fine so hopefully it's an easy fix, but lv2000's "2 days later" story has me concerned.
    Thanks all, time to give the wife a break from driving.
    Aug 05 2013
    N/A
    I think you misunderstood. I never said you did damage to cause the leak. I was implying that it could have been pooling up in there and collecting. You ripping it apart and scratching the belly pan (yes I see scratches) probably made it come out. I would take it to a dealer for a full inspection and tally of all parts broken. Then send that bill to UHaul for reimbursement through their insurance.
    Dec 15 2013
    Los Angeles, CA
    Word, thanks. With the car being so new I guess I assumed there shouldn't be any fluid leaking/accumulating, but probably that's an unsafe assumption.
    Aug 05 2013
    N/A
    Considering purchasers have picked up new cars with low oil level indicator in the MMI and other issues totally missed during PDI, I wouldn't be so sure.
    Veteran Member Four Rings Pilfer's Avatar
    Dec 13 2012
    To the Bay Area
    I'm moving back as well to the SF area. I'll be driving my car back. I can't wait for the drive
    996
    Model Y
    Apr 17 2004
    Socal
    i'd wager it's cosmoline.
    Aug 05 2013
    N/A
    Quote Originally Posted by paul View Post
    Could be if it's everywhere. He'd have to check. From his description and the pictures it looked more like a small section rather than an all over the place thing. I remember the first EVOs that came here had goods of it all over the bottom of the chassis. Everyone was freaking out. Lol
    Jun 06 2013
    Model 3, MK7 GTI
    Carrollton,TX
    Sorry, here's the link to their VW site, shipping is cheaper there.
    http://www.jimellisvwparts.com/produ...K0825207C.html
    Dec 04 2004
    Las Vegas
    I thought fuel line was passenger side ? Mine was a evap leak so no fluid just check engine light
    Dec 15 2013
    Los Angeles, CA
    I scraped on both sides, and the grease patch is on the passenger side. I can feel two lines running in the area but can't tell if they're damaged, but I don't think the grease is fuel. Would those be the fuel lines though? Or evap?
    Veteran Member Four Rings xuandatou's Avatar
    Oct 17 2012
    NoCal
    Quote Originally Posted by Pilfer View Post
    +1 Moving to SF
    I'm taking off sometime around July 25, but I won't be driving or towing it with a trailer
    2013 S5 Build Thread
    2001 S4 Avant
    2017 Ducati Monster 821
    Instagram
    Gone but not forgotten:
    2011 Q5 2.0T
    2011 A5 2.0T
    2013 S5
    2007 A6 3.2
    Jun 06 2013
    Model 3, MK7 GTI
    Carrollton,TX
    I hope you haven't ordered those panels yet. The one I got from them does not match up to my 2014 S4.
    Dec 15 2013
    Los Angeles, CA
    Hmm damn, but no I haven't, let me know if you figure it out.
    Account Terminated Four Rings
    Mar 08 2010
    San Francisco, CA
    Intercity Lines does a nice job moving cars on a covered carriage and not damaging them, for about $1700 from east to west.
    Dec 13 2012
    To the Bay Area
    Yea but the drive though :D. I've done it twice from SF to Philly and back again in lesser rides. This is a shorter trip and a much more enjoyable car. Thread hijacking over
    996
    Model Y
    Dec 15 2013
    Los Angeles, CA
    Dealership is telling me nothing else was damaged thankfully.
    Part numbers for the panels according to them, for posterity:
    LINING 8K0 825 207 D
    LINING 8K0 825 208 H
    RIVET 8E0 825 267
    Assuming they are correct, the letter at the end must designate different revisions.
    Jul 05 2015
    Lower Hudson Valley
    Quote Originally Posted by UncleScottie View Post
    Perplexity.ai says aftermarket replacement is 2-300 and new from the dealer likely around 5.
    Same exact thing happened to mine last week. I'm hoping to either fiberglass it or epoxy it. Getting my oil changed this weekend so I'll just tell my Indy guy to keep it off for me... then reinstall when fixed, however.
    You realize that you're necro posting to a ten year old thread.
    Jul 06 2020
    St. Catharines/ON
    You realize that there really isn't such a "thing" as "necro posting", right? Good answers to good questions never get old...especially since there are thousands of these models still on the road...still having the same issues with belly pans.
    And since I didn't see any ingenious suggestions for "fixing" it, other than "buy one from the dealer" (at hundreds of dollars), I thought I'd bring a little 21st Century, AI, cheap-ass Scotsman's repair-it option to the table! Cheers!
