Results 1 to 4 of 4
    Veteran Member Three Rings jrsAudiA6's Avatar
    Oct 11 2011
    2018 A5 SB
    Riverside, California
    Logging ECU Data
    I want to log ECU data that will tell me if pre-ignition is happening under WOT runs. I have looked at what is available from the Engine control module using VCDS but can not really identify what I need to log. I have also looked at the OBD-II data and again not sure what I should log. If anyone knows what to log to determine if pre-ignition is occurring please let me know.
    2018 A5 SB Matador Red Premium Plus
    2012 A6 Garnet Red, Prestige Pkg, Innovation Pkg, B&O, 20" Sport Pkg, H&R RSS + Coilover, Alcon Mono6/380mm front brakes, S6 rear rotors(356x22mm)/caliper carriers.
    034 DL fr suspension arms, 034 Track DL engine mounts, Eurocode Front and Rear sway bars & Alu Kreuz front brace, 034 ECU/TCU tune, DP PR 3.11, JHM Hx
    CTX 50% Tint F. S. Windows, CTX 30% Tint R. & R. S. Windows, 3M Pro PPF, hood, L & R fenders, AWE Exhaust w/o down pipes
    Established Member Two Rings PB4UGO's Avatar
    Oct 12 2010
    '14 A6 TDI - Previous RS4, 4.2 allroad, A4, A5
    Earth
    Oct 11 2011
    2018 A5 SB
    Quote Originally Posted by PB4UGO View Post
    Well I checked out APR's logging info but unfortunately it does not match what I see thru VCDS on my 2012 A6.
    Oct 12 2010
    Earth
    Each vehicle will be slightly different. APR's is more of a guide now than a perfect step-by-step example. For my TDI, under the Engine module, there are 200ish sensors one can monitor.
    Here is what Ross-Tech (VCDS maker) says - http://wiki.ross-tech.com/wiki/index.php/Fuel_Trim_Info
