Page 5 of 9 FirstFirst ... 34567 ... LastLast
Results 161 to 200 of 341
  1. #161
    Active Member One Ring siimu's Avatar
    Feb 05 2015
    Estonia
  2. #162
    Senior Member Two Rings slunky's Avatar
    May 25 2014
    NorCal
    What is your wheel and tire setup?
    Wheels: 15'' OEM "Daisy" wheels
    Wheel size: 15x7.5
    Offset: None
    Size tires: 205 60 R15
    Suspension: OEM "Sport" suspension
    Alignment settings: None
    Body modifications: None
    Notes: About to change!
    UPDATE:
    Wheels: 17" S4 "Avus" wheels
    Wheel size: 17x7.5
    Offset: ?
    Size tires: 225 45 R17
    Notes: Finally how I like it!
    '00 B5 A4 1.8T QM, Ebony Pearl Metallic
    20psi Stage 1 Tune | APR 2.5'' Catback | APR Carbonio Intake | S4 Avus Wheels | S4 Rear Sway Bar
    RS4 Grille | Forge 007 DV | 034 Snub | HID CC's | AWE Boost Gauge | eBay Short Shifter | OEM "Sport" Suspension
    ECS Clutch | TT Coil Packs | Valeo Control Arms | Meyle Motor Mounts | Meyle Tie Rods | Meyle Endlinks
  3. #163
    Jun 10 2010
    *offset: et45
  4. #164
    May 17 2014
    Raleigh, NC
    Switched to 1.5in lips so now I am 17x9.5 all around. et35, no spacers and 225/45/17s. This is how it will remain for a while!
  5. #165
    Jun 17 2012
    Denver, PA
    New to this, hopefully it works.
    Wheels: Audi Flat Fives
    Wheel Size: 18x8.5 Front and Rear
    Offset (spacers ?): ET 45 15mm spacers in rear 10mm in front
    Size tires: Falken 235/40/18
    Suspension: Raceland Coils
    Alignment: Stock
    Body modifications: Front fenders pulled and rolled
    [IMG][/IMG]
  6. #166
    Feb 24 2012
    Tromsø/Norway
    Wheels: 3SDM 0.05
    Wheel Size: 18x9.5 Front and Rear
    Offset (spacers ?): ET40, 5mm spacers in rear
    Size tires: Bridgestone Potenza S001 225/40/18
    Suspension: Bilstein PSS9
    Alignment: Stock
  7. #167
    Feb 26 2015
    Woonsocket, Rhode Island
    Wheels: 04 Audi A8
    Wheel size (diameter and width):18x9
    Offset (spacers?):1 1/4 in front 1 1/2 in rear
    Size tires:235/45/R18
    Suspension: S4 suspension
    Alignment settings (camber, toe, etc.):factory
    Body modifications (rolled/pulled fenders):rolled fenders
    Notes:
    [IMG][/IMG]
  8. #168
    Veteran Member Four Rings Tanzimur's Avatar
    Feb 21 2013
    97 Brilliant Black A4 B5 1.8T
    Warren, MI
    Alrite i gotta question since no one is this dumped and running a4 b6 5spoke sport wheels. My question is right now im running 225 55 r16 stockies and rub on lock turns how bad is it going to get with the b6 wheels?
    GTF 23
  9. #169
    Veteran Member Three Rings Johns's Avatar
    Oct 03 2014
    Woodstock, CT
    Quote Originally Posted by Tanzimur View Post
    I wish I could be helpful but I just bought a set and I'm still trying to decide what size tire to run as I don't want to get spacers for the rear. What'd you go with?
  10. #170
    Feb 21 2013
    Warren, MI
    i have yet to pick my set up on monday! and idk im thinking ill have to go up with the height and add spacers cause the et on theese they sit inward more but are 7.5in in width vs 7 so its all god either way im just worried about rubbing!
  11. #171
    Feb 21 2013
    Warren, MI
    They fit lol no spacers needed and i am running 235 35 17 i had to roll the fender alot but its all good!
  12. #172
    Oct 03 2014
    Woodstock, CT
    Looks good! have any pics of the fitment?
  13. #173
    Feb 21 2013
    Warren, MI
    yup!
  14. #174
    Mar 11 2015
    New Jersey
    Hey everyone I need some help. I just purchased a set of Porsche twist wheels they are 17x7 fronts 17x8.5 rears. I will be running a 235/40 tire all around. What mm spacer/adaptor will I need for the rear to sit flush. The stock offset now on my wheels now +40, the new wheels are +45 in front +55 for rears. If anyone can help me out that be great message me or reply to this .. thank you
  15. #175
    Senior Member Three Rings DeathKing's Avatar
    Feb 15 2012
    New York/Los Angeles
    PMing you
    JP
    Current:
    '17 VW GTI Sport | VMR V804 18x8
    Sold:
    '99.5 2.8 Sport | k0mpressed tune | Apikol/034 mounts | TSW Bathurst 17x9 et35 | Falken FK453 235/40 | Bilstein B12 Kit | Neuspeed 19MM RSB | Magnaflow 14816
  16. #176
    Apr 30 2015
    Quote Originally Posted by B5_Avant_Noob View Post
    What wheels? --- OEM Audi A6 "Pie Plates"
    What size (diameter and width)? --- 17x8
    What offset? --- et 45 I believe??
    What size tires? --- 225/45/17s
    What suspension do you have? --- Raceland Ultimos Not positive on ground clearance, but its pretty low.
    What are your alignment settings (camber, toe, etc.)? --- Stock
    Any body modifications (rolled/pulled fenders)? --- None
    Notes --- I am in need of a fender roll. No rubs over bumps, but I get a rub in the front end while turning but only when someone else in the car. I realize the tire size is a little tall for a low car, however my wife drives the car on occasion and I decided a taller tire would save me from bent or cracked wheels.
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    Sorry for the crappy Iphone pics... I should invest in a camera.
    Am I the only one aside from ^^ that would put 17s on my car??
    I feel like 18s are big compared to the car.
  17. #177
    Jun 10 2010
    Quote Originally Posted by cavekidd View Post
    Well yea, especially since he's the only one with 17s in this thread.
  18. #178
    Veteran Member Three Rings bikerbob951's Avatar
    Jul 25 2008
    2006 Volvo XC70 AWD, 1936 Dodge D2 Touring Sedan
    Cincinnati, OH
    I'm looking into 17's, but mostly because I'm concerned with:
    - lightweight
    - big beefy, yet cheap tires
    - because racecar.
    Vorsprung Durch Technik.
    1999 AEB B5 A4 quattro
    My new build thread. Instagram
  19. #179
    Oct 18 2013
    Audi A4 97 1.8
    Costa Rica
    Is there a FB like button in here? thank God there's not otherwise I would have hit every single pic out there.
    Here's my default setup, running on 205/50 R16 with stock rims.
  20. #180
    Veteran Member Four Rings cjt671's Avatar
    Dec 14 2014
    B5 S4 sedan, 2018 Q5
    PNW
    Decided to play!
    BBS RSII 17x8 et 35
    No spacers but thinking of running 5/8mm
    245/40/17 Michelin Pilot Sport
    Lowered a bit on FK Coils
    Stock alignment, no body modifications
  21. #181
    Junior Member Two Rings Forced A4's Avatar
    Jan 19 2010
    Merrillville IN
    I need some advice guys, I've been doing research and can't come up with an answer. I'm looking to do a 18x8.75 et33 with 235/40 18 tires on a b5 a4. Will that combination fit. I do understand that I might need to roll my front fender
  22. #182
    Feb 15 2012
    Are they 18x7.5, 18x8, or 18x9? Either way you're fine. Your ride height may be a factor, but just roll the fenders if you have any issues.
    JP
    Current:
    Sold:
  23. #183
    Jan 19 2010
    Merrillville IN
    Quote Originally Posted by DeathKing View Post
    They are 18 x 8.75 (8-3\4"). I don't mind rolling my front fenders but I really don't want to pull the rears
  24. #184
    Veteran Member Four Rings AudiBoy808's Avatar
    Sep 28 2004
    99.5 A4
    Honolulu, HI
    19x8.5 et32
    99.5 silver A4
    FI CF hood | Eurogear CF Euro trunk | Eibach Pro-St coil overs | Crimson K6 | Kerscher frnt | Avant garde sides | RSR Rear | Vibrant exhaust | Silver CF rear seat inserts |
  25. #185
    Jul 25 2008
    Cincinnati, OH
    Wheels: Axis OG SAN in Graphite w/ machined lip, 20lbs
    Wheel size (diameter and width): 17x8
    Offset (spacers?):ET35, no spacers
    Size tires: 225/45R17 BFGoodrich Sport Comp2
    Suspension: HR sports & Bilstein
    Alignment settings (camber, toe, etc.): Stock
    Body modifications (rolled/pulled fenders): None
    Notes: I was looking for a beefy, track appropriate fitment, nothing to wide so my roll center stays as it should. I think these fit the bill perfectly.
  26. #186
    Oct 24 2013
    girls MK4 1.8t
    United States
    Wheels: Privat Kup
    Wheel size (diameter and width): 18x9.5
    Offset (spacers?): ET +30
    Size tires: Falken 612 225/40/18
    Suspension: raceland ultimos
    Alignment settings (camber, toe, etc.): rear camber maxed, front lower control arms relocated out to the A6 mounting points on the subframe. adjustable uppers coming soon.
    Body modifications (rolled/pulled fenders):fronts rolled, pulled and mangled.
    Notes:
    Stupid drift A4
    R.I.P RWD-converted '99 A4 Avant 1.8T
  27. #187
    Veteran Member Four Rings pbcrazy's Avatar
    Feb 06 2013
    VA
    Wheels: Alzor 349
    Wheel size (diameter and width): 18x8
    Size tires: 225/40r18, Michelin Pro Sport A/S 3
    Suspension: H&R sport springs
    Notes: front sits about .5" higher than rear, not enough for me to buy $700+ coil overs to fix
    98.5 Audi A4 1.8T Quattro | 5 Speed | AEB | Laser Red
    | FrankenTurbo F21L | United Motorsports Stage 3 | 630cc Injectors | 3" MAF | ICM Delete w/FSI Coils | Scorpion 2.5" Catback/RAI 3" Test Pipe | Forge 007 | 034 Silicone PCV | Alzor 349 | FMIC | ECS RA4 LWFW/S4 Clutch/S4 P.Plate | AEM | Krauto | etc.
  28. #188
    Jan 15 2015
    florida
    Bone stock
  29. #189
    Veteran Member Three Rings Sumo337's Avatar
    Jan 07 2015
    2011 B8S4
    Pittsburgh, PA
    Wheels: Schmidt TH-lines
    Wheel size (diameter and width): 17x8 2.5" lip / 17x9.5 3.5" lip
    Offset (spacers?): +35 all wheels
    Size tires:205/45/17 all wheels
    Suspension: Airlift
    Alignment settings (camber, toe, etc.): OEM mostly, airdout = camber
    Body modifications (rolled/pulled fenders): Rolled, some hood work so the bags don't hit it.
    @chetbagged
    2011 B8S4 Prestige
    460HP-384TQ Manual
    APR / ECS / P3 / WCI / Sportshifters / Polo Performance / Airlift / Caractere
  30. #190
    Feb 05 2015
    Estonia
  31. #191
    Veteran Member Three Rings Wrath And Tears's Avatar
    Apr 03 2014
    17 GTI Sport
    Wheels: Sparco Assetto Gara
    Wheel size (diameter and width): 17x7.5
    Offset (spacers?): et35
    Size tires: 225/45ZR17
    Suspension: Stock for now
    Body modifications (rolled/pulled fenders): Stock
    Notes: Just installed today. Love them. First time I've ever gotten rims and the first time I've ever had four new tires.
    2017 MK7 CSGM GTI Sport DSG
    PP (Golf R Brakes, +10HP, VAQ LSD), LP, Kessey
    LW 17" Sparco Assetto Garra's, 034 Res-X resonator Delete
  32. #192
    Senior Member Three Rings crazyquik22023's Avatar
    Jan 30 2012
    Brunswick, Ohio
    Wheels: BBS Aero II Custom
    Wheel size (diameter and width): 18x8.5" & 18x9.5"
    Offset (spacers?): et34 & et20
    Size tires: 215/40/18 & 215/45/18
    Suspension: V-Maxx
    Alignment settings (camber, toe, etc.): Natural -2.5 - -3
    Body modifications (rolled/pulled fenders): Pulled & Rolled fenders & quarters
  33. #193
    Senior Member Three Rings OMEGA SUPREME's Avatar
    Mar 29 2007
    Gig Harbor
    OZ Ultraleggera's. 17x8. Tires Falken azenis rt-615k.
    [IMG][/IMG]
  34. #194
    May 25 2014
    Wisconsin
    Alzor 010
    18x8.5 et 35
    12mm spacer in the front 15 in the back
    ST Suspension
  35. #195
    Veteran Member Four Rings rockbeau25's Avatar
    Dec 06 2014
    B5 A4 Avant, 4L Q7 TDI, Van Diemen RF99
    WI
    Sparco Tarmac 17x8 ET35
    Dunlop Direzza DZ102
    Solowerks Coilovers
    B5 A4 Avant
    4L Q7 TDI
    Van Diemen RF99
  36. #196
    Veteran Member Four Rings melomandn's Avatar
    Nov 08 2010
    958 CTT, 996 C4S, old motorcycles
    Upstate New York
    Quote Originally Posted by AudiBoy808 View Post
    19x8.5 et32
    Wait whattttttt, hold the phone. Blue chrome?? How did I miss this?
    Please tell me you have more pics
    - B7 avant, 3.0t swapped
    - B8 S4, Stage 2+
    - B6 S4, not stock
    - B5 S4 Clone, built motor, 2871r
  37. #197
    Jan 13 2010
    Hull, UK
    Sparco tarmac 18x8". Et 48 12mm spacer front & 15mm rear. H&R coilovers. Tyres Nankang NS2R 225/40/18
    Sent from my SM-G920F using Tapatalk
  38. #198
    Jan 07 2015
    2011 B8S4
    Pittsburgh, PA
    Wheels: Audi W12 A8 Sewercaps
    Offset (spacers?): et48 with rear 10mm spacers
    Size tires: Nankang NS-20 / 215/40r18s
    Suspension: Airlift bagged
    Alignment settings (camber, toe, etc.): all depending on the psi
    Body modifications (rolled/pulled fenders): rolled
    Notes: Polished, brushed, and black paint in the inserts
    @chetbagged
    2011 B8S4 Prestige
    460HP-384TQ Manual
  39. #199
    Active Member Two Rings DaDa4450's Avatar
    Jan 06 2015
    queens
    Rr
  40. #200
    Jan 06 2015
    queens
    Wheels: Audi b7 5 spokes
    Wheel Size: 17x7.5
    Offset (spacers ?): Front ET45 / Rear ET45 (0mm spacers)
    Size tires: 225/45/17
    Suspension: Racelands ultimos
    Alignment: Stock
    Dropped pretty low, no rubs unless some one is in the back
    Sent from my SM-N920P using Tapatalk[/QUOTE]
