Results 1 to 11 of 11
    Sep 16 2010
    Central Wash
    Another Blauparts Timing belt roller bearing failure
    Sold my old 01' S4 Avant to a friend a little over 3 years ago, I did the timing belt just before selling it. He made it just about 20k miles, trouble free.
    Just heading out of his driveway the other day and the engine stalled. "Weird" he says..tries to fire it back up..he says no noise, no warning of any kind. He was coasting at maybe 15mph, engines just dies.
    No compression when tried to start.
    Bought the kit from Blauparts- nothing against them, but this is SHITTY. The car has 160k on it I think and it's an auto so this basically makes it worthless. And he loved the car.
    Belt and everything else looks perfect, tension is still perfect. This is the picture he sent me..I looked at it yesterday, but didn't have to apart far enough to see all of it.
    Senior Member Three Rings PSU S4's Avatar
    Feb 03 2009
    2001.5 Imola RS4 Body 034 STK Avant 2001.5 S4 Nogaro Stage 3 Avant
    Philadelphia
    Thats no fun. I had one fail from them 6k in.
    May 11 2013
    Nnj
    That sucks,is this a common occurrence. ? I have used them everytime i do a timing belt awesome company to deal with. I've had 3 s4 and probably change the tb about 5 or so times 0 problems. I'm actually about to bring my current s to stage 3 specs and have a tb kit from blausport waiting to go in.
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    You see that boss directly below the roller?
    Take a good look there and at the roller for contact between the two.
    I have seen the hyd tensioners go and make contact there. This extra bs may be what took it out.
    May just be the bearing that went, but just 2x check you are treating the problem and not the symptom.
    Veteran Member Three Rings killerkali's Avatar
    Jan 01 2011
    Nor cal
    I just recently had an NTN tensioner roller fail nearly blow my motor. Im going to make a post about it soon
    Nov 27 2013
    B5 S4
    IL
    I had a kit from ECS fail. Took out a bunch of valves. Genuine Audi timing parts from now on for me.
    Sep 16 2010
    Central Wash
    Yeah. I know there are no guarantees and statistically there has some be "some" failure of a mechanical part, so somebody has to be the unlucky one. But I don't know if I have ever heard of dealer purchased timing belt parts failing so early. I always assumed they were probably more or less the same manufacturer.
    But this is definitely higher failure rate AND sooner than we should see for such a critical part.
    Worst part is it makes the car garbage; a stock tip silver S4 Avant with high miles.. hard to justify even swapping in a used engine much less 30-40 hours on pulling the engine, turbos, heads, etc.. all while avoiding all the junk it probably needed (seals, hoses, turbos) before it broke.
    I try and stay current...but ...this car is basically worthless...right?
    Veteran Member Four Rings xhackerekx's Avatar
    Jul 23 2007
    10S6C6_12Q7TDI_A4B6 3.0_VNL730
    Scranton , PA / Poland UE
    timing ecs kit for my previous b5 1.8t failure and cost me new head also ecs timing for my b5 s4 almost failure made crazy sound on idle so I check and find this:
    now I use whole timing kit from blauparts and my 4 audis happy :)
    Nov 16 2010
    WetSide, WA
    If I was a forensic audiologist, I would think that one was damaged from bolting it down on top of the relay rocker.
    Hard to say though, shit happens
    Active Member Two Rings Strat321's Avatar
    Jun 22 2014
    Denver
    Quote Originally Posted by zillarob View Post
    Haha love it I almost agree as I've never even heard of such an issue unless pulleys and tensioner weren't replaced.
    Established Member Two Rings estoniancartel's Avatar
    Aug 10 2009
    2001 S4 Avant 6 MT
    Boulder, CO
    Could be a candidate for a 6 speed swap if the body is in good condition. People are always after avant shells, possibly even tip.
    2001 S4 Avant 6MT OEM RS6 on E85
    2008 A4 Titanium Avant 6MT
    2015 Allroad APR Stage 1
    2024 RS3
