Page 5 of 5 FirstFirst ... 345
Results 161 to 172 of 172
  1. #161
    Active Member Two Rings RHawk's Avatar
    Feb 23 2018
    Marion, il
    Quote Originally Posted by wkhanna View Post
    ....so long as they are not slotted.....
    ....& they are not made with separate left & right castings which have the vents oriented for the rotation direction of each side....
    I did some looking and the slot does not designate which side of the car it goes on, only the vanes inside the rotor determine left or right. Seems odd because I would like my slots all to slope from the front to the back on both sides, but I guess that has no effect on how the slots perform. Only the internal vanes, if directional, do. Radial vanes have no direction and can be mounted left or right, as the vane is straight from the center of the rotor to the edge of the rotor, they have no curvature whatsoever. So, in conclusion, if I get slotted rotors I may have one side of my car with rotors that look "backwards" when compared to the other side. As long as that does not affect braking performance I guess I'm OK with that.
    Sent from my HTC U11 using Audizine mobile app
  2. #162
    Established Member Four Rings fmzip's Avatar
    Aug 21 2017
    Quote Originally Posted by RHawk View Post
    Well I think my first question was not detailed enough. Upon some research I understand the slots can face towards the front or the back, no big deal, but are the vanes inside the rotor directional? I'm assuming if the rotor is both left or right side, the vanes are radial and can be put on either side of the car.
    This is the installation instructions from Brake Performance for their slotted rotors. They are marked left and right
    http://thetechhouse.myqnapcloud.com/...di/rotors1.pdf
    2015 S4 - Mythos Black - EPL Stage II/DSG Tune - Eurocode Alu Kreuz - Canyon Run CR-15 - 034 RSB/Billet DTB's - C-Quartz Nano - 3M Pro-X PPF - Audison Voce/Prima - B9 S4 V Spoke Wheels
  3. #163
    Established Member Three Rings Ford Prefect's Avatar
    Jan 20 2017
    2011 Silver S4, Mercedes Benz R350 ('07 & '11), Suzuki SV1000
    New Hampshire
    Quote Originally Posted by AWEs5 View Post
    Yup I do. Let me guess, you hear it when you are driving next to a line of cars or a wall? I’m also experiencing rattles only when I run over reflectors on the road while changing lanes.
    Here are the exact words from the mechanic who did my brake job. He compares the humming to a sprinkler going off. This is due to the wind cutting thru the slots on the rotors. As for the rattles going over the reflectors, he is saying that the Hawks 5.0 pads i bought do not have a material like oem pads that make the pads stick to the rotors. The humming/ “sprinkler” noise annoys the shit out of me. But as long as my windows are up, I don’t hear anything.
    So this has been driving me nuts. I have GD series EBC and red stuff pads and have been feeling like I did something wrong. I asked my daughter (12) how to spell the sound I made, she said “ch-ch-ch-ch” and specifically not “cha-cha-cha”.
    Is this the sound you guys hear? Trying to figure out the “sprinkler sound” If so I’m guessing the slotted/dimpled/drilled reason is right.
  4. #164
    May 12 2017
    needs cleaned
    Land of Archaic Anachronisms
    Quote Originally Posted by Ford Prefect View Post
    ...... I’m guessing the slotted/dimpled/drilled reason is right.
    ....most likely....
    ....does it make the sound with brakes are not applied......?
    i have slotted rotors.... they make a distinctly different sound than plain rotors.... but when the brakes are applied....
    ,,,,,does not bother me in the slightest... but thats just me.....
    Bill
    2011 A5 2.0T Old Man Project
    1983 Porsche 944 (Modified)
    1971 Moto Guzzi Elderodo
    Avatar Chart
  5. #165
    May 12 2017
    needs cleaned
    i inquired bout getting the high carbon slotted for upgrading my A5 to S5 spec (got the 'S' cals & brackets a while ago)...
    they said it would take a little while since they would need to machine the slots in the high carbon rotors...
    doing the brake job this weekend, so i could not wait...
    so.... i went with StopTech S5 slotted high carbon rotors & street performance pads, SS brake lines & high performance fluid....
    .... right about $800 for everything....
    S5 calipers & the bigger high-carbon stoptech rotors & sport pads up front on my A5 this weekend with some help from my dawgs.....
    (....rears already done as noted on previous post...)
    OLD
    NEW
    ......new brakes have been for a while, now.
    long enough to have been bedded in for a bit.
    before comparison can be made, i need to state the condition of the previous brakes...
    the car is a 2011 A5 i purchased a year ago with 52k showing on the odometer.
    at that time, the rotors 'looked' to be in decent condition & the acura dealership i got it from had just installed new oem pads.
    after a few months of my 10 mile/day city commute combined with occasional other outings & highway miles, the peddle (& braking) began to oscillate & got progressively worse over time.
    needless to say, the braking was less than acceptable for a car of this weight & relative performance.
    so i went from substandard oem A5 to S5 cals & the stoptech highcarbon rotors (larger diameter) with stoptech sport pads & SS lines on both the front & rear.
    now that they are bedded in the overall increase in performance is significant, as one might expect.
    cold bite is V good. some of the best i have ever had.
    when warmed up, these are working really well.
    afa dust, surprisingly, it seems quite low to me.
    definitively less than previous.
    what i can compare is the performance of The Wife's oem brakes on her 2011 A4 to my 2011 A5 w/ the S5/stoptech upgrade....
    ...night & day with regards to stopping ability.
    dust is far lower, too.
    i would have been ok with more dust from the stoptechs, cuz i put performance above aesthetics & having to wash dirty wheels frequently....
    for now, i am exceptionally pleased with the way this package is performing from all aspects....
    jmho... ymmv.... ; )
    Bill
    Avatar Chart
  6. #166
    Jan 20 2017
    New Hampshire
    ....most likely....
    Now I have to check. I think it does it off brakes but gets loud while on.
  7. #167
    Established Member Two Rings AWEs5's Avatar
    Jul 18 2017
    Gardena CA
    “Ch-ch-ch-ch” sounds about right. I brought it back to shop that installed it as well as another indy shop for inspection. Nothing seem out of the ordinary. the noise doesn’t bother me anymore. What still bothers me is when my rear wheels go over the reflectors while changing lanes, it sounds like something is lose. It’s a slight rattle. Again I had 2 shops look at it and they both said it was fine. Never heard this noise before replacing the brakes. I replaced the front anti rattle clips during the install so it can’t be that and plus noise is coming from rear. There are no anti rattle clips in the rear I don’t think
    2013 Audi S5 Premium Plus | H&R springs | AWE S-Flo CF intake | AWE Touring Exhaust 102mm Diamond Tips | AWE non-resonated downpipes |
  8. #168
    May 12 2017
    needs cleaned
    i use a V thin film of high-temp rtv on the non-piston side pads....
    Bill
    Avatar Chart
  9. #169
    Established Member Two Rings BucDan's Avatar
    Jul 19 2017
    San Diego, CA
    Can I assume that the general consensus about the pads, both semi-metallic and ceramic in the kit, aren't that great? Better off going with Akebonos and just the rotors only? When you guys are changing rotors and pads, are you also changing the boots and the clips?
    What anti vibration compound are you guys using? Will likely get a set and take advantage of their deal before the end of the month. I'm at about 4mm for the front pads right now, but this deal seems too good.
  10. #170
    May 12 2017
    needs cleaned
    Quote Originally Posted by BucDan View Post
    i can not speak to any experiance with their pads, but would guess for a daily-driver they are fine.
    again, not sure if the Ake's are lower dust than the ceramic ones in their kit...
    ...i only know that i have never heard anyone with Ake's that was not happy with the all-around performance/low-dust characteristics....
    ....always.... why would anyone not insure their brakes are in tip-top condition, especially when doing the work yourself....?
    ....the replacement parts not expensive.... i consider them 'one-use disposables'......
    ....V cheap insurance & what could more important than properly functioning brakes??????
    ....i just use a V thin film of high-temp RTV ......a good buddy here swears by CRC 05016 Disc Brake Quiet
    i fully endorse this stuff:
    Bill
    Avatar Chart
  11. #171
    Jul 19 2017
    San Diego, CA
    Awesome, thanks for the response!
  12. #172
    Apr 02 2014
    DMV
    im a little confused regarding the ceramic pads. from their site it states their premium ceramic brake pads "are NOT recommended for heavy cars, trucks and SUV's because they do not have a high temperature fade resistance and friction level". i always thought ceramic brakes/pads were specifically meant to be used in high performance/temperature applications, hence why they are offered on high performance and race cars. and iirc, the main complaint regarding akebono ceramic pads i have read on this site are that they lack an initial bite on a daily driver because normal driving conditions do not produce enough heat.
    from tire rack, "These pads use ceramic compounds and copper fibers in place of the semi-metallic pad's steel fibers. This allows the ceramic pads to handle high brake temperatures with less heat fade, provide faster recovery after the stop, and generate less dust and wear on both the pads and rotors. And from a comfort standpoint, ceramic compounds provide much quieter braking because the ceramic compound helps dampen noise by generating a frequency beyond the human hearing range."
    am i missing something?
