*GONE* 2016 S4, Premium Plus, BO Package, DSG, Sport Diff, Daytona Grey, CR-15 Strut Brace, EuroCode AK, 034 Trans Insert, ECS Drivetrain Inserts, 034 Rear Sway Bar, HRE FF01 19x9.5 Wheels, Brembo GT 380mm BBK, EPL Stage 1 & DSG Tune
2020 BMW M2 Competition, M Drivers Package, White
2016 Q5 3.0T GIAC Stage 2, HP tuners TCU tune with help from P3U and BG SQ5, aFe 11-10121 Pro Dry S filter, 034 Throttle body hose, AWE Cold Front Heat Exchanger
93 octane tune (0-60mph 3.90 seconds (1 ft rollout), 0-60mph 4.12 seconds, 1/4 12.31 secs @ 112.40, 0-60ft 1.90 seconds)
Race 104 octane tune (0-60mph 3.70 seconds (1 ft rollout) , 0-60mph 3.89 seconds, 1/4 12.09 secs @ 115.34, 0-60ft 1.88 seconds)
'15 S4 - Monsoon | GIAC DP 183-fluidampr / 57-awe & DSG tune | Autotech HPFP, GIAC LPFP | iABED 75mm TB | Tampa Ported SC & 4" Intake | AMS Alpha Cooler | 034 Street Density Eng Mounts
EuroCode Sways, Links, Alu Kreuz | CR-15 | ECS 2pc D/S Rotors, EBC Red Stuff | HRE FF01, Pilot SS | Bilstein PSS10's | RSE Test Pipes | AWE Touring /Res DPs
2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
2015 S4, IE DP tune, 3.28 SC ratio, Merc HX
Current: ‘21 RS5 Sportback B9.5 Nardo Grey
Retired: ‘13 S4 B8.5 Phantom Black Pearl
EPL Stage II DP Tune | EPL 57.60mm SC Pulley | 183mm Fluidampr Crank Pulley | S4Matty Ported SC and TB| Aquamist WMI 375cc Jet @ TB| AMS Alpha Heat Exchanger | Milltek Sport Non-Resonated CBE | ECS Kohlefaser Luft-Teknik Intake | Alu Kreuz | CR-15 | 034 Drive Train & Trans Inserts | Bilstein PSS10 | SPC Upper Control Arms | TSW Bathurst 20x10 | Pulley Ratio=3.177
2014 Audi S5
034 Stage 2+ ECU & TCU | 75mm TB | Ported SC | Roc Euro CAI | Merc Hx | B12 Pro Kit | 034 Rear Sway + Links | 034 Motor Mounts
JHM Test Pipes | EC Alu Kruez | CR-15 | EC T&B Diff & Trans Mounts | USP SS Brake Lines | EBC Yellow Stuff Pad | BP Slotted & Drilled Rotors
Custom DP 194/57 E40 Water-Meth (Aquamist) | BG HPT ZF8 Tune | APR CPS with AWE Reservoir (Divorced Coolant Loop) | APR Open Intake and 034 Intake Tube | RSE Heat Shielded HFCs | CTS Downpipes with Vibrant UQ Resonators Added | AWE Touring Exhaust | 034 RSB | Bilstein B8 Shocks and H&R -3 Springs | ECS Trans and Drivetrain Inserts | 034 Trans and Motor Mounts | Moog Front End Links | Headlight Projector Retrofit and Painted Housings
