Results 1 to 4 of 4
    Oct 07 2013
    Bellevue WA
    Coolant warning light comes on while driving
    I've experienced the red cooling warning light coming on after driving my B7 S4 Q25 for about 30 seconds after starting from a warm engine. This has happened twice in the past couple of weeks. In both cases the coolant level was near max and the oil level was reasonable (recently checked in other words and found to be ok). Both times also happened on warm to hot days, late afternoon time frame. Temperature gauge indicates normal engine temperature when starting the engine.
    I'm wondering if there's a latent heat issue with the car where the coolant continues to warm up once the engine has been shut off since there's no fan/air movement to cool it down. Then when I start the car up a few minutes later and drive off, the coolant temperature is higher than it should be, hence the warning light. In both cases the car was fine after I let it cool down. In other words, no warning light appears and when starting the car the next morning.
    Has anyone else experienced something similar to this? Is it indicative of an issue such as a faulty sensor or just what I described above?
    Veteran Member Three Rings vacsimile's Avatar
    Nov 15 2008
    2004 Audi S4, 1991 Nissan D21, 2001 GTi VR6
    Outer Space
    Make sure the coolant reservoir is plugged in good (connector is on the under side). You could have a bad coolant level sensor. Or for some reason your coolant isn't conductive enough for the sensor to work
    Veteran Member Four Rings Justincredible's Avatar
    Jul 24 2008
    chicago
    Quote Originally Posted by vacsimile View Post
    I would say the same thing. Check the wires. Pull the plug out and clean the contacts and put the plug back on the coolant container.
    If you don't have haters, then you're not kicking enough ass.
    JHM powered 12.2 On the JHM Tune With Launch Assist for the Automatic JHM Nitrous kit/JHM headers all this in a Automatic.
    And lastly for the grammar police that are bound to step in
    I came here from Germany in the 6th grade. I could not read or write a lick of English. I am working to get better. Thanks and sorry. I always try to edit my posts for the best grammar and easiest reading.
    Oct 07 2013
    Bellevue WA
    Quote Originally Posted by Justincredible View Post
    OK, thanks. Will check this out this weekend.
