Results 1 to 7 of 7
    Apr 22 2014
    2005 Audi A4 1.8T Quattro
    new york
    Oxygen Sensor Spacer
    when buying the 034Motorsport High Flow Catalytic Converter (1.8T) which Oxygen Sensor Spacer should i get and how many?
    034Motorsport Oxygen Sensor Spacer
    034Motorsport Oxygen Sensor Spacer (Ultra Low Profile)
    Veteran Member Three Rings Gooner1886's Avatar
    Jul 20 2009
    Indiana
    B6 A4 1.8T Quattro Unitronic Frankenturbo stage 2+
    AKA: MitchFalk10
    Veteran Member Four Rings seanf86's Avatar
    Feb 27 2011
    04 A4 2.7T swap, 13 Q5 3.0T S line, 02 A4 quattro 1.8t
    Winnipeg
    you're going to have to get the low profile one, with 2 non foulers my 02 sensor hits the trans and their spacer looks to be about the same length, I'd go with the low profile one, I'm running one drilled out non fouler on my rear 02 with no cat codes for the last 20k however so you can always try the spark plug non fouler route
    Veteran Member Three Rings Audi body's Avatar
    Jan 03 2013
    bike and a pit bull powered pair of rollerblades!!
    the woodlands tx
    I tried and tried the o2 spacers with no luck. I still got cel but I do have a TP . With your highflow cat and one spacer you should be fine. I have heard that some times with just the HFC it doesn't give any codes.
    Veteran Member Four Rings mauromj's Avatar
    Jul 22 2012
    Pullman, WA
    Just code it out and do it right.
    Apr 22 2014
    new york
    Thanks Guys!
