Page 2 of 2 FirstFirst 12
Results 41 to 46 of 46
  1. #41
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Glad I could help. I monitor a lot of Audi forums but in my opinion the Audizine B6 forum is the best one available. I have picked up a tremendous amount of information over the years form AZ members and I am more than happy to pass it on.
    Cheers!
  2. #42
    Veteran Member Three Rings B6_Dolphin's Avatar
    Apr 10 2005
    PNW
    I went through the same diagnosis... had a rattling at 2500-3000 rpm. Thought it was the sepentine belt tensioner (no), alternator pulley clutch (no), and then took off the serpentine belt and ran it. Still rattled. Decided to do a TB and WP kit. The bearings in the WP (metal impeller) had migrated and were not uniformly spaced. I had 30k miles on the WP - disappointing. Went 75k on the factory one, and it didn't get noisy - it leaked.
    Maybe the metal impeller WPs aren't all they're cracked up to be...
    2023 RS5 Coupe - Ascari Blue/Black; Mods: IE A2A IC, 034 Strut Brace, ECS Poly Trans Mount, APR CF Intake, EuroCode FRT & RR STB + Endlinks, DTE Systems PowerControl X & Pedalbox Pedal Tuner, AskCarbon Steering Wheel, ROW Tailights
    2021 SQ5 S/B Prestige - Daytona Gray/Black
  3. #43
    Veteran Member Three Rings auditi's Avatar
    Nov 19 2007
    Burlington, WA
    What do you do if you can't get the old CCT compressed to put slack on the chain? I can push down on it, so it's not stuck, but the tool isn't compressing the pads at all...
    -'11 VW Golf 2dr TDI 6-speed manual
    -'59 VW Bus
    -'05 B6 A4 1.8T Quattro USP - Arctic White/Black, 6MT, unk chip, S4 brakes/SS lines, S4 grille, tint, PODI gauge, forge dv, Bose w/ Aux & Sub - sold
    --USP Club Member #212
    -'01.5 B5 A4 1.8TQMS - Silver/Black, tint, M3 lip spoiler, Bose+sub, 1.3 bar custom Neuspeed p-chip, Evo MS CAI, 710n, H&R sports, S4 shocks, short shift, 19mm Neuspeed RSB, poly snub, Blitz dtt w/ red led's - sold
  4. #44
    Veteran Member Four Rings BARRY's Avatar
    Nov 02 2007
    SF Bay Area, CA
    that means your engine isn't at TDC.
  5. #45
    Veteran Member Four Rings a4lownslow's Avatar
    Feb 12 2014
    2007 Audi A4 2.0T
    Hudson WI
    Quote Originally Posted by auditi View Post
    I’m going to assume your engine is at TDC otherwise you shouldn’t even be attempting to mess with the chain tensioner yet.
    If so there really is no reason it wouldn’t compress unless the threaded rod on the tool is not making contact with the threads on the tensioner or the threads are stripped.
  6. #46
    Nov 19 2007
    Burlington, WA
    It seems it would have to be a TDC issue.. Buddy said it was at TDC when I was turning the crank, and marks lined up on the pulley, so that's when I pulled the VC and tried to put the tool on, after marking the cam/chain.. I'll check it myself tomorrow, called it a night, don't want to mess anything up...
