Originally Posted by
rreeves91
Correction GIAC uses the red tops with their tune. There 74 mm but I'm not sure if that is from O ring to O ring. Or the the total length. I'd be interested to know if anyone has ran these in their car.
Thanks
Giac does not use 74mm injectors with their AEB tune or atleast not when I had mine. They are factory length. I think you are messing up the fact that people call them redtops. Hell that really does not mean anything specific except color and there is several different injectors that are called redtops. The difference between the injectors you posted and new injectors are night and dy and it would be worthwhile to upgrade if you can.
Most of these tunes like the AWE and Giac were made sometime ago so these new injectors were not availible.
Did Audi change the length of injector body somewhere in the B5 line? I know the AEB is 60mm O ring to O Ring but for some reason I thought the later was 48mm O ring to O ring. I may be wrong but I think when I was searching injectors I ran into this.
