Results 1 to 18 of 18
    Senior Member Three Rings millerrh's Avatar
    Jun 15 2013
    Austin, TX
    Squeaking/squishy sound coming from front suspension
    I've got a strange sound I can't seem to figure out what it is. It occurs when I'm driving slowly over something like a speed bump or small bump like entering a driveway. It sounds like something rubber that isn't lubricated properly.
    If you saw my previous post on my coils making noises, I suspected it was the silencer rubber I added to the springs squishing around. Since I settled on some grease to take care of the issue I removed those silencer rubber pieces hoping to get rid of this sound. But the noise is still there. Now I am suspecting the Eurocode sway bushings might not be lubricated properly.
    Anyone have issues with sway bars squeaking before? Or am I barking up the wrong tree here? Let me know if anyone has any tips on how to pinpoint the cause.
    2014 S4 Premium Black Pearl | 6MT
    Sports Differential | 19" Peelers | B&O Sound | Carbon Atlas Inlays | CF Supercharged Badges | Bilstein PSS10s | Eurocode Alu Kreuz | Eurocode USS Sways & Endlinks | Roc Euro Intake | AWE w/Res DPs, 102mm
    Veteran Member Four Rings RWD2quattro's Avatar
    Dec 29 2011
    Lexus IS250, Volvo 850R, Ford tractor
    The Bay
    As per my previous cars, if it sounds like a old mattress (creaking) when driving slow over bumps or up/down/side ways on driveways, could be lack of lubrication on sway bar bushings. End links will develop a clunk or thump when driving over bumps. Let me know what you find.
    BMW M4CS, Frozen Blue, Full XPEL, CCB, DCT. Dinan HAS kit, Fall Line end links, Hotchkis sway bars, K&N filters, CF interior goodies. More goods are coming...
    Gone: 2014 S4, Audi Exclusive DRM, 6MT.
    Gone: 2012 S4, Brilliant Black, Prestige, S-tragic.
    Jun 15 2013
    Austin, TX
    Yes you nailed the sound I am hearing. Sounds just like an old creaky mattress. It definitely has a certain bouncy creakiness to it which is why I originally thought it was the rubber things I had attached to my springs rubbing with the motion of the springs.
    I was not the installer of my sways, so not sure how easy it will be to lube the bushings. Is it possible to get to them without removing the whole sway bar? Looking at the installation manual, it looks like attaching these bushings to the car is one of the last steps. Is it possible to just remove those clamps, lube up the bushings and just reattach the clamps?
    I seem to recall someone posting up a thread recently about this, but a search is not pulling up anything for me for some reason.
    Dec 29 2011
    The Bay
    You may have to remove sways to apply lube to the inside of bushing where it makes contact with sway bars. Go back to the shop and explain what your experiencing and they may do it for free. You'll never know until you try.
    Veteran Member Four Rings Jones2012s4's Avatar
    Nov 09 2011
    Michigan
    Quote Originally Posted by RWD2quattro View Post
    This...
    2012 S4 - DSG B8 - [email protected]
    Feb 25 2013
    MI
    Yea, here's what you were looking for: http://www.audizine.com/forum/showth...ion-Clunk-Gone
    For the record, I haven't had any more noise since doing this myself.
    Dec 05 2010
    Los Angeles, CA
    My noise, which sounds like a creaky mattress, is coming from the rear. Unfortunately, the sound persisted after removing the EC rear sways and end links. Any ideas??
    2019 Nardo with all OEM options
    Feb 25 2013
    MI
    Quote Originally Posted by BzzzBom View Post
    What do you mean removing? You replaced EC hardware with OEM? You could still lubricate those.
    Dec 05 2010
    Los Angeles, CA
    Quote Originally Posted by drob23 View Post
    Eurocode removed the sway bars and end links and we test drove the car - the noise persisted. It was a mild rattle while driving slow over uneven pavement. Unfortunately the rear noise continues to get worse and now sounds like a creaking mattress. I was at EF1 Motorsports in Signal Hill. Fabrizio, the owner is the guru of European car suspension. He heard the creaky noise and diagnosed it as coming from sway bar bushings. I'll report back after bushings are lubricated.
    Aug 05 2013
    N/A
    How can it be the sway bar bushing if you said the bars were taken off and the noise persisted?
    Jun 15 2013
    Austin, TX
    Yeah... Totally confused by what you are saying.
    Feb 25 2013
    MI
    Quote Originally Posted by SwankPeRFection View Post
    Assuming now it's the stock bushings/bar creating the problem.
    Good luck getting this problem fixed...amazing how much better you feel about the car when it doesn't sound like a 95 corolla going over bumps.
    Sent from my SCH-I535 using Tapatalk
    Apr 11 2012
    I had the creaking mattress sound on one of my older cars, it was from the polyurethane bushings in the camber kit. Every time I went over a speed bump, its sounded like someone was getting it on, lol. Sometimes I even make that sound today when I go over speed bumps since it was so ingrained in my mind after living with it for years.
    Dec 05 2010
    Los Angeles, CA
    The mild clunking has continued but now I also have a different and louder noise which sounds like what has been described in this thread. Sorry for the confusion.
    Dec 05 2010
    Los Angeles, CA
    PM Sent
    Nov 15 2013
    oc
    Quote Originally Posted by millerrh View Post
    Do you also experience the sound in tight slow turns?
    Jun 15 2013
    Austin, TX
    Quote Originally Posted by rdef View Post
    No, this is generally wheels straight, slow driving. I hear it worst going out of my driveway which has a small 1" drop. Strange 1" can make that kind of noise. Also going over speed bumps does it if I go slow.
    I did have low speed turning sounds (like when pulling into a parking spot). This was caused by spring binding. I have since fixed that with a rubber silencer material and grease. Originally I thought this squishy mattress sound came from the rubber parts on my springs. But I took those off in the sound is still there that's why I think it's the bushings.
    Jun 15 2013
    Austin, TX
    To close out this thread:
    I took off the bushings and they were dry as a bone. The shop that installed them never put any grease on them. Should have just done these myself. I greased them up per drob23's post above and everything is silent! Finally!
    I haven't had a silent suspension since I got my coils and sways installed back in January, so I am really happy now.
