The below post applies to the C7 Audi A6/S6 with Bose.
The subwoofer wires are located in the following locations on the T38 wire harness that plugs into the Bose amplifier:
Pin # 5 = subwoofer (-) [Brown/Blue wire]
Pin # 17 = subwoofer (+) [Brown/Gray wire]
I have an Audison BitOne in my 2013 S6 with Bose.
We tapped the following Bose outputs:
Front Tweeters (L/R)
Front Midrange (L/R)
Front midbass (L/R)
Subwoofer
7 outputs total. They are all active crossover at the Bose amp.
Keep in mind that I did a full system upgrade, not just subwoofers.
Here is my wiring diagram which I created.
2013 S6 Bose Wire Diagram - Audison BitOne Connections
Ignore the right side diagram, as that is for my amplifier and would not necessarily be relevant to you. But the left side shows all of the wire assignments and colors, and there is a picture of the T38 harness.
I tested all 7 of those outputs from the Bose with an oscilloscope and test signals. I can confirm that the Bose front midbass speakers
do NOT receive any sub bass signal. I used a 40 Hz test signal and there was
no signal present when testing the front midbass on my scope. None. Total flat line. I had to use the subwoofer output to get the 40 Hz signal to work.
I have not tested any of the rear speaker outputs from the Bose, however. So I cannot say with certainty whether they would supply a full range signal or not. But I suspect they do not, since the front midbass do not.
There are 4 rear speaker outputs from the Bose amplifier. 2 of those outputs go to the rear doors where there is a passive crossover, and it splits to a mid and tweeter. The rear deck speakers are called "Effects Speakers" in the Audi Repair Manual. I seriously doubt any of those rear outputs would provide a suitable signal for conversion to run a subwoofer.
Without actually testing the rear speakers, I do still feel confident that I can assume they also do not receive full range signal. My belief is that ONLY the subwoofer channel receives sub-bass signal. Therefore, if you want to add a subwoofer properly, you must tap the subwoofer output. Unless someone has tested those rear outputs and can confirm otherwise, this is the best info I can provide.
