Results 1 to 22 of 22
    Established Member Two Rings madionS6's Avatar
    Feb 13 2014
    Madison,WI
    Launch Control Help Needed
    Okay, I've tried about 6 times now to engage launch control and it's only worked once. The other times the engines revs to about 2000 rpm and doesn't go any higher, seems real boggy.
    Yes I've read the owner's manual and here are my steps:
    1) disable traction control
    2) turn to dynamic mode, however shift lever still in D, not S or manual.
    3)left foot brake then within 1-2 sec
    4)floor the accelerator
    Not sure why this doesn't work everytime. What am I missing? Not pressing the brake hard enough? Not pressing the gas down fast enough?
    And please be kind, I've only had this car for 3 weeks :)
    Veteran Member Four Rings sciblades's Avatar
    Mar 20 2009
    North Salem/Palm Beach
    Just hit the traction control button once, brake to the floor hold it while pressing accelerator. Foot off brake to go.
    Check launch control counter if already launched 200 times it won't do it anymore
    Sent from my Z10 using Tapatalk
    2016 RS7 Stinger VIP laser and radar, Unitronic Stage1+
    Gone
    2013 C7 S6- v1 and LI- Unitronic tuned]
    B8 S4
    06 a3 Full Votex Kit, Unitronic III, apr tbe, precision 750 FMIC, apr HPFP forge dvi, EVOMS cai, BSH gt3076r turbo kit, IE rods, sb stage IV, LSD, on meth
    Established Member Three Rings gatorguy's Avatar
    Jun 12 2013
    BMW M5, Ford Expedition Limited
    Metro Orlando
    This is what I do:
    With the car already in dynamic mode, press brake to floor, then I hit the ESC button.
    Pull the shifter so it is in S mode.
    Floor the accelerator (should hit 5000 rpm's)
    After it revs, immediately release brake.
    2013 Estoril Blue S6
    20" Giovanna Sardina's|ECS Spacers|Custom Spoiler|30% Ceramic Tint|Blacked out filler panel|Escort Max hardwired|Escort ZR4 Laser Shifters|Opti-coat 2.0|Stasis Rear Sway Bar|Audi Puddle Lights
    Established Member Two Rings ellisina4's Avatar
    Aug 23 2012
    Chicago, IL
    Quote Originally Posted by sciblades View Post
    200 launches in 3 weeks? :)
    Established Member Two Rings mwar99's Avatar
    Oct 06 2012
    Deposit on 2014 911 GT3
    Northern NJ
    Quote Originally Posted by madionS6 View Post
    You need to have it in S I believe, not D
    2013 S6 - Estoril Blue
    2015 911 GT3 - Delivered!!!
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Needs to be in S, not D
    Veteran Member Four Rings superswiss's Avatar
    Jan 07 2013
    San Francisco Bay Area, CA
    Quote Originally Posted by 500HPS5 View Post
    +1. You are not in dynamic mode if the transmission is in D. The transmission mode overrides your Audi Drive Select mode for engine/transmission and btw, there is no difference between Comfort and Auto mode as far as the engine/transmission is concerned. Both Comfort and Auto have the same throttle map and shift points. So, Comfort = Auto = D and Dynamic = S. That also means D -> M is different from S -> M.
    2019 AMG C63CS, obsidian blk, blk leather w/ yellow stitching, aero pkg, CF pkg I+II, 19/20 wheels, lighting pkg, multimedia pkg, heat&vent seats, AMG perf seats, digital cluster, night pkg, parking assist, driver assist, european delivery
    2013 panther blk RS5, Ti pkg, blk leather/alcantara, nav pkg, sport exhaust, driver assist pkg, rear shade, alu kreuz, ECS spacers 15f/10r, ECS tru-float rotors, ECS brake lines, Hawk HPS pads, european delivery (sold)
    Feb 13 2014
    Madison,WI
    Quote Originally Posted by gatorguy View Post
    This is what I do:
    Thanks! I'll give your system a try!
    Nov 18 2013
    2007 Suburban 3" lift/33" Terra Grapplers
    United States
    Manuel clearly states, need to be in (S) and or Dynamic. If you switch to dynamic, the program shifts to (S) for you. You can do it in comfort by just shifting to (S) if I am not mistaken as well. But sport has to be enabled for it to work.
    Feb 13 2014
    Madison,WI
    Quote Originally Posted by airborne6 View Post
    The manual is clear, which is why I said I read it but was still having problems. I had been using dynamic mode only, which bullet point 2 says is OK. So airborne6, what was your suggestion?
    Jan 07 2013
    There is a small problem with the instructions in the manual. That is if you are already in Dynamic mode at the time you start the engine, you are actually not in Dynamic mode, because every time you stop the engine, the transmission goes back to comfort/auto. Everything else stays in Dynamic mode. The instructions in the manual assume that you are currently not in Dynamic mode, because then as soon as you select Dynamic mode, the transmission goes into S.
    Feb 13 2014
    Madison,WI
    Quote Originally Posted by superswiss View Post
    So good! Thanks you for this explanation. I will re-try launch control when the weather conditions here improve.
    Also, I wish the instrument cluster would say something bad ass like "Launch Control Engaged" when all the appropriate conditions were met. :)
    Nov 18 2013
    United States
    You said you were in dynamic, yet the trans was in (D) not (S). The manual states it has to be in S. Like my post said, if you have the car running, switch to Dynamic, the trans goes into sport mode. If you drive in dynamic every day when you stop the car, and restart it the setting are all dynamic, except the trans. My suggestion is put the car in (S) as this seems to be the only thing you had off from the manual, and then go through with the directions.
    Not trying to be a dick, but the instructions seem pretty clear, as I felt my post was.
    2014 S7 Glacier White/Black l DAP l Inno l Black Optics l Carbon Inlays
    2007 Suburban LTZ 3" Lift / 33" Terra Grappers / Spyder Halo's/LED's / Alpine 8" Nav
    Feb 13 2014
    Madison,WI
    I'm not trying to be a dick either, but now you are just paraphrasing the answer by superswiss, which actually was clear.
    Nov 18 2013
    United States
    Truthfully, I didn't read his/her post. I posted from experience, I drive in Dynamic or Individual pretty often.
    But it's cool, hope it works out for you. It's pretty fun once you get it down.
    Feb 13 2014
    Madison,WI
    Thank you everyone for the help. I was able to get the launch control to work yesterday! Didn't realize the key was seeing S>D on the display. All better now. :)
    Established Member Two Rings clintb's Avatar
    Apr 02 2014
    How can one check the launch contol counter?
    2013 S7 // APR 560HP|580TQ // AWE Black Diamond // 15mm Factory Drop // 20x10 TSW
    Jan 18 2010
    Los Angeles, CA
    Quote Originally Posted by clintb View Post
    vaqcom cable and a laptop. you can buy the cable from rosstech.
    Junior Member Two Rings bisynchronous's Avatar
    Jul 26 2010
    Miami, FL
    Quote Originally Posted by MLee View Post
    Where exactly is this in the VCDS program? I was trying to find it the other night when changing codes around. Anyone have the exact location?
    2013 Audi S6 Brilliant Black | Stock | Valentine V1 hard wire | VAG Codes |
    Gone (but never forgotten)
    2010 Audi B8 S4 Quartz Grey 6MT | 35% Tints | REVO 93 Tune | JHM SS | Stratmosphere Intake | Valentine V1 hard wired | VAG Codes | AWE Exhaust (stock DP's) | RS4 Grill |
    Jul 26 2010
    Miami, FL
    Never Mind... Found a post on it.
    http://forums.audiworld.com/showthread.php?t=2843486
    There's the link for anyone that wants to find the Launch Control Counter.
    Jun 12 2013
    Metro Orlando
    Yep, and even when not doing launch control having it in S mode will make a difference.
    Apr 02 2014
    Very cool... Thanks
    Quote Originally Posted by bisynchronous View Post
