As you know the electric parking brake on the rear wheels of the S4 has eliminated our ability to install BBKs all the way around our cars. We owe a big thank you to the below gent who has found a way around the issue. Your cars parking brake will be inoperative but now you can install big brakes on the rear axle too. I'm having a some Brembo's installed next week by GMP and will confirm the procedure works.
THANK YOU Doug!!!!!
Doug Schuler
Apikol -Performance Automotive Components
303-731-3571 - office
866-505-4126 - fax
www.facebook.com/Apikol
www.apikol.com
I was able to fully delete the rear parking feature on my customer's B8 S4 with the following steps:
1. Unplug Rear Brake Control Module
2. Remove Parking Brake from Module Gateway via Vag-Com
3. Change instrument cluster coding to remove Parking Brake
After those changes, there were no lights illuminated in the dash, and no issues noticed during driving. However, there were 4 modules (engine, trans, etc.) that had a fault code for missing brake module. I suppose it would be possible to change the coding in those modules (like I did in the instrument cluster) to make them ignore the missing brake, but since there were no lights on the dash, I didn't feel that is was necessary.
