Results 1 to 14 of 14
    Dec 29 2013
    Bellingham
    Fuel Pump Questions
    Hi All,
    About a week ago my fuel pump went out and I have been researching what pump to buy. 034 Motorsports has a couple drop in Pumps Bosch 040 and 044 for around $400 and then I found a DW300 but I don't know if that one is a drop in. Currently upgrades are, ko4's, 630cc injectors, 85mm Maf housing, 3" exhaust and Custom Tune. Wondering if anyone might be able to point me in the right direction and save some of my sanity, it would be greatly appriciated.
    Dec 29 2013
    Bellingham
    also wondering if a stock fuel pump would work just fine or if because of my upgrades I need a bigger fuel pump.
    Veteran Member Four Rings 01audia4's Avatar
    Jan 31 2008
    Philly home of the cheesesteak
    The DW300 will be fine. It is cheaper than the 040/44. A stock new one should also be sufficient for K04's but I don't know how much truth is to that statement. I went 044 so I would never have to worry again(IE bigger turbos than k04)
    2001 A4 2.8-->1999 a4 1.8tq 220K-->2000 K04 S4--->2001 F21 S4 eating corn w/ stock rods
    Aug 05 2011
    Memphis, TN for now!
    Quote Originally Posted by Silverbullet00 View Post
    Hi All,
    It is not a drop in but can easily be made to stay in place. Do a search and you should see that vast I think used to use that pump and sell it with an install kit. Just need some hose clamps to keep pump from falling to low and some orings to deal with pump being smaller in diameter than stock.
    Veteran Member Four Rings jpurre's Avatar
    Jun 11 2013
    2004 BMW 325i
    South Florida
    USP Motorsports has a drop in pump as well for more fuel flow. FYI, I am running 550cc EV14's with an OEM fuel pump and it seems just fine after 7k miles.
    2001 Silver F21 TIP (SOLD)
    Build thread--> http://www.audizine.com/forum/showth...ally-Happening
    Veteran Member Four Rings xalents23's Avatar
    Oct 26 2011
    CA
    Just an FYI I was looking into the high output drop in kit from USP Motorsports. And they have confirmed the fuel pump they use in that kit is the 044 pump.
    Dec 29 2013
    Bellingham
    I didn't know about this company. I'll check them out. Hoping to get something that will drop in. Because of my lack of knowledge at the moment :-)
    Veteran Member Three Rings insomniacxp1's Avatar
    May 10 2010
    01.5 B5 S4
    Rochester, NY
    I've got the 034 Motorsports 044 drop in, amazing piece, works beautifully, and is as stated, straight drop in. No messing around with changing out just the pump itself into the old basket. Just make sure when ya go to change it you've got like 2 gallons left in your tank, is gonna make things a lot easier. Also the two power and ground wires your gonna hook up, that you think are (+) and (-) are reversed, the wire you think should go to (+) goes on the (-) and vis versa, idk why but it's just that way hah
    01.5 Imola S4. Stage 3 F21's/To much to list
    Dec 29 2013
    Bellingham
    Quote Originally Posted by insomniacxp1 View Post
    Good to know. I ended up buying the USP one because it was $50 cheaper but it looks like its the same. Thanks for all the input guys!
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    Here is how the install is going to go.
    Step 1: Install, wont start.
    Step 2: Pull back out, remove plug on inlet, reinstall, still wont start.
    step 3: Pull out again, put the wires on right (black is +12v), put back in, success!!
    JK but I have seen this done before.
    I have only hooked one up backward once, while talking shit to the owner about dumb fuks hooking them up backwards
    Veteran Member Three Rings killerkali's Avatar
    Jan 01 2011
    Nor cal
    I don't know the Walbro 400 pump is not more popular, cheaper than any other pump and outflows them all for most setups. http://www.ebay.com/itm/WALBRO-400LP...a19c19&vxp=mtr Drops right into stock basket with some o rings and your done..
    Jul 28 2010
    2001 S4, 2006 A3, 2006 Touareg
    Pontiac, IL
    I've been considering aem e85 fuel pump.
    That wire thing got me as well on my last s4.....
    Tapa Talk from my Note 3!
    Veteran Member Four Rings Gujuhammer's Avatar
    Oct 07 2010
    02' Avant
    Florida
    I have a freshly pulled stock fuel pump if you want to go that route...PM me if you are interested.
    Dec 07 2012
    Shell high octane lol
    UK
    Quote Originally Posted by killerkali View Post
    me too but why so small in looks compared to an 044 for instance?
