Results 1 to 18 of 18
Thread: splash shield
    May 24 2013
    splash shield
    hello,
    I noticed that when I bought my car that the splash shield was missing. I asked for a used car parts dealer here in Canada for a quotation and he came with the following part number : AU1228102.
    I did a google and found on the internet that this splash shield is used on sedans and convertibles 2.0t, 3.2, 1.8T and 3L engines and this for the B6 and B7.
    Can somebody confirm that this part works on my 2007 2.0 quattro convertible.
    I have seen knockoffs at all kind of prices. Anybody ever dealt with those people and are their shields good : https://www.rockauto.com/dbphp/x,cat...AU1228102.html
    I don't want the metal splash shield.
    I'm also looking for the front plate filler on the grill for a convertible s-line.
    thanks for the help
    Senior Member Three Rings dba4's Avatar
    Sep 02 2010
    Markham/Ontario
    get an aluminum one. the plastic ones don't last and you may end up buying a new one after every winter. I bought the thor skid plate and have had a few times i was very happy to have it.
    May 24 2013
    I don't think they have something for the convertible.
    Veteran Member Four Rings BenMTL's Avatar
    Dec 19 2012
    Europe
    Shouldnt the one for the regular B7 sedan and the B7 convert be the same? Also, I'd definitely go with another black plastic one vs a sliver metal one but that might just be me...
    Race: 2006 A4 2.0 T / Quattro + 6 Speed / JHM Stage 2 93 w/HPFP / Custom 3" Turbo back exhaust / AWE Boost Gauge / JHM Short Shifter + Intercooler / White CF Trim / S4 Door Blades / DTM Conversion / RS4 RSB / HFC
    Daily: 2012 Audi A7 3.0 TDI / Twin Turbo / True Sline / Quattro + 8 Speed ZF / HUD + ACC + Sunroof / APR Stage 1 / Eurocode Alu Kreuz + Mounts / 034 RSB
    Senior Member Three Rings dbens's Avatar
    Jun 07 2011
    Montreal
    Quote Originally Posted by BenMTL View Post
    are you lowered? how many of the black plastic ones have you gone through?
    2007 B7 A4 QG TI S-Line / Debadged / 35% front & 20% back tint/Evomsit stage 1 flash/ Neuspeed Springs / Emilgevor interior led kit / Hoen Xenon matched fog lights
    May 24 2013
    I bought it last summer and noticed it but now I want to install one. So in other words the previous owner lost it. It is an s-line so it is a little bit lower then the regular ones.
    May 24 2013
    because you don't like the color? Any good (good prices) places in montreal for audi parts?
    Established Member Two Rings JPS's Avatar
    Jun 15 2013
    United States
    I have the thore and it's a beast. Only problem is that sometimes when starting and coming to a stop it rattles on my oil pan I think.
    Sent from my SCH-I605 using Tapatalk
    Sep 02 2010
    Markham/Ontario
    Quote Originally Posted by JPS View Post
    get new urethane spacers to replace the crappy plastic ones it comes with. also helps absorb any impacts the skid plate may take. the thor has saved my oil pan a few times so its well worth its price.
    Jun 15 2013
    United States
    Quote Originally Posted by dba4 View Post
    I bought some thicker ones from home depot but they were plastic and still rattles on the oil pan. you know where to get some urethane ones?
    Sep 02 2010
    Markham/Ontario
    to be honest i found mine at my friends shop, i beleive they are subaru wrx subframe bushings actually. I can't remember, they are a replacement suspension bushing though.
    my best guess is they are these, http://www.tougetuning.com/store/kar..._86_93_137_379
    May 24 2013
    Seems that for the convertible you have only the original audi spash shield. All aluminium ones are for sedan and wagon only.
    If somebody knows an other source please let me know.
    thanks
    Veteran Member Two Rings dackler's Avatar
    Jan 31 2005
    Cortland NY
    Quote Originally Posted by canada g View Post
    If you're being told that a splash shield fits the sedan and convertible, then the aluminum ones will fit it too (as they obviously fit the sedan and avant, they're the same).
    But since you don't want an aluminum one, you're stuck with plastic.
    For the $30 for the RockAuto one, just go with that. It's only $30 and it's likely VERY similar to the original except made by a different mfg'r.
    May 24 2013
    at thore they told me that they don't have the skid plate for the convertibles.
    the cheap rockauto option could be the solution. I maybe will have to drill other holes and do some cutting.
    What if I drive without the skid plate? A dirty engine and a risk of killing the oil sump....
    Jun 07 2011
    Montreal
    I have been driving like that all winter. I do not reccomend and I will pony up and by the thor/evolution/panzer plate shortly...
    Jun 10 2011
    North Jersey
    I actually have a related question... does anybody have the part numbers and diagram for the fasteners?
    I took off my splash shields to do some work and can't for the life of me figure out where I put the screws. Guess I need to order all new ones :(
    Veteran Member Four Rings billyhoyle's Avatar
    Jul 29 2010
    2007 GSXR-600, 1977 GS750, mice
    Calgary, Alberta
    Do you need the whole kit (here: http://www.ecstuning.com/Audi-B7_A4-....0T/ES2587686/) or just the screws (8D0805121)? Those guys are $5 a pop (!!), but they have cheaper aftermarket ones too.
    2005 B7 A4 2.0T | Brilliant Red | 6MT
    Jul 29 2010
    Calgary, Alberta
    Actually europaparts.com has the screws for $3 each. Slightly more reasonable.
