Results 1 to 3 of 3
Thread: coil conversion
    Senior Member Three Rings Breppinq's Avatar
    Apr 05 2012
    VW ATLAS, VW JETTA GLI MK4
    Long island, NY
    coil conversion
    Its been about a month and a half since i did the conversion all good until i got a CEL for ignition amplifier open circuit i think it was and random misfire anyway the idle good, it drives good everything sounds good no problems with boost or anything at all, that can only mean the wiring that eliminated the ICMs isint good right? instead of buying the kit i cut and spliced all the wires for the coils and ICMs.
    Veteran Member Four Rings ilyafil's Avatar
    Nov 03 2011
    Bay Area , CA
    Some wire is loose or something. If you got the wires wrong on the ICM delete, it wouldn't start.
    "Basically the B7 is the girl you bring home to mom, and the B5 is her slutty sister."
    For Sale: Neuspeed Sport Springs
    Apr 05 2012
    Long island, NY
    Yeah that's what I figured I'm thinking it has to be one of wires where the Icm was. Guess I'll just redo them better
