Okay got rid of the N335 air intake switch over valve issue, somehow I had rock salt in my connector to the bottom of the airbox...now im stuck with this, checked soark plug, changed the coil pack...still no fix...help please VAgcom stats
Address 01: Engine Labels: 079-907-560-CAU.clb
Control Module Part Number: 8T0 907 560 D HW: 8T0 907 560
Component and/or Version: 4.2l V8/4V H10 0004
Software Coding: 01140009190F0120
Work Shop Code: WSC 08307 444 85554
VCID: 3B7536C9BA8303C68E5-806E
2 Faults Found:
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 -
Freeze Frame:
Fault Status: 01100001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 113059 km
Time Indication: 0
Date: 2014.03.24
Time: 16:35:56
Freeze Frame:
RPM: 3032 /min
Load: 73.7 %
Speed: 68.0 km/h
Temperature: 52.0°C
Temperature: 13.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 14.605 V
000770 - Cylinder 2
P0302 - 001 - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 113059 km
Time Indication: 0
Date: 2014.03.24
Time: 16:35:56
Freeze Frame:
RPM: 3032 /min
Load: 73.7 %
Speed: 68.0 km/h
Temperature: 52.0°C
Temperature: 13.0°C
Voltage: 14.605 V
