Six piston Black & Blue & Red Porsche Cayenne caliper, caliper carrier, pads, two-piece rotors...
These massive rotors are moved outwards from the center of the wheel to provide much greater clamping leverage, and the slotted and drilled aspect helps to evacuate braking gases and heat to give better contact between rotor and pad.
Also included are brackets for your new calipers, all hardware, new pads, fluid, and even stainless steel flexible lines. These new lines will reduce swelling found in factory brake hoses and provide more pressure to your new calipers.
Kit Features:
- Six piston 18z Porsche Cayenne calipers
- Calipers available in Red, Blue, or Black
- ECS 2-piece 358x32mm rotors
- Hawk HPS brake pads
- ECS Exact-Fit stainless steel brake lines
- ECS caliper relocation brakets
- Super DOT4 brake fluid
Brake Fast
Fits:
Audi MKI TT 1998-2007
Be sure to check out our -----> Installation PDF <-----
Jason
