Results 1 to 16 of 16
Thread: So this is new
    So this is new
    My rear diff locked up on me on the freeway at about 65 mph .. No sighns of trouble before, no leaks, no grime built up... What the? Anyone else have diff problems ?
    And the "glamour" shot. First time my b5 has seen a trailer
    Using Tapatalk
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    how sure are you that it was the rear diff?
    2020 SQ7- Wife's ride
    2008 RS4- I like this car
    2000 S4- Working?
    Has to pull cv axles and driveline to get it on a trailer, diff is locked
    Using Tapatalk
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Sure it isn't the center diff?
    2000 S4- Working?
    Apr 01 2011
    B5 on jack stands
    charlotte
    Keep us up to date...I'm with redline, center diff.
    Quote Originally Posted by redline380 View Post
    Well I pulled the diff out, and managed to tear it down some. Btw what a PITA ! Anyway it is indeed the center diff. Anyone have any suggestions to a company that makes parts for our differentials ?
    Using Tapatalk
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by josh.smuin1 View Post
    Yeah, the junkyard lol
    Edit- what are you running for tires?
    2000 S4- Working?
    I am running falken 225/40/18 on bbs rc's. No spacers
    Using Tapatalk
    Veteran Member Four Rings RallyeBourne's Avatar
    Sep 10 2013
    San Diego County, CA
    In your situation, I'd contact JHMotorsports about a center diff. 4:1 FTW.
    Quote Originally Posted by RallyeBourne View Post
    But wouldn't that mean changing the final drive ratio in the transmission?
    Using Tapatalk
    Sep 09 2012
    Austin, TX
    No, the 4:1 doesn't refer to the final drive, it refers to the power split. Basically you can have 80% of the power go to front or rear. Can't remember what the ratio is stock.
    Veteran Member Four Rings BaseDrifter's Avatar
    May 18 2010
    No. The center differential is responsible for distributing torque to the front and rear wheels.
    JHM describes it best:
    The factory torsen center differential in the S4 and A4 provides a 2:1 torque distribution between front and rear. What does this mean? This enables the end of the car that still has traction (most of the time the rear) to deliver double the torque to the tires with traction. JHM's experience has found that this closer to even distribution is best for drag racing. So this modification is not for you if you are into drag racing primarily. However for Auto Crossers, Road racers and others who prefer the twisties JHM recommends a bias ratio of 4:1. This is the same bias ratio that Audi has provided in the stock RS4 driveline.
    http://jhmotorsports.com/shop/catalo...only-p-46.html
    | Update thread / Youtube Channel |
    97 A4 1.8TQM: Frankenturbo|TyrolSport SMIC|034 HFC|Borla catback|Carbonio/007 DV|Vogtland GT3|034 RSB|Apikol Bushings|034 SD motor/tranny/strut mounts|A8 brakes/SS lines|JHM trio|Meyle HD CA/TREs|
    01 S4 2.7T: Stock
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by fed0ra View Post
    I'm like 99.9999999% sure it is 50:50. Newer ones are 60:40
    2000 S4- Working?
    Sep 09 2012
    Austin, TX
    Well, I know its 50:50 by default, but the max split is something like 60:40.
    Sep 10 2013
    2:1
    Oct 04 2010
    Kearneysville West Virginia
    Drifty time for the a4??? 4:1 .... mmmmm
