Results 1 to 3 of 3
    Feb 20 2010
    TT225, Touareg, Tiguan, TDI, A3, RS6, Jetta
    Brighton, MI
    Engine/tranny swap from 2003 A6 2.7T into 2004 A6 3.0
    Can i swap engine and transmission (auto) from
    2003 A6 Quattro 2.7T
    into
    2004 A6 Quattro 3.0
    Do I also need to swap the rear end (if 3.0 tranny has different gearing than 2.7T tranny)?
    Alternative:
    swap
    2003 A6 Quattro 2.7T auto
    into
    2001 Allroad auto
    (I know rear diff needs to be swapped also, but possible aside from that? Drive shafts (front, center, rear)?
    01 Allroad Tiptronic, TCU tune, mild stg 3 (350 HP) tune (stock injectors) KraftwerkTurbo TM1. Lower, Wider. Custom tip vent pod with Podi
    02 Allroad 6 spd, Kraftwerk Turbo TM6, 750cc, 3" MAF, piggy, FMIC, CM stg 5 (hate). 30 psi at 3600 rpm. Needs stronger rods (coming).
    05 Golf TDI
    Looking for 2001 A4 1.8T quattro manual with blown motor
    www.regulatorfix.com
    www.kraftwerkturbo.com
    May 16 2008
    South Texas
    Quote Originally Posted by vtraudt View Post
    into
    2004 A6 Quattro 3.0
    Alternative:
    swap
    into
    2001 Allroad auto
    If the AR has the air suspension then you need to use the AR front axles. Also the A6 propshaft has to be shimmed to be used in the AR.
    Feb 20 2010
    Brighton, MI
    Quote Originally Posted by Scotty@Advanced View Post
    Decided to use the 2.7T drivetrain from the 2003 A6 in the 2004 A6 3.0. Can I swap engine and tranny into the 2004 3.0? Are trannies identical? Do I need to softcode/change the TCU?
    Or is everything 'bolt on' and 'plug and play' (from 2003 2.7T to 2004 3.0).
    Correction: the 3.0 A6 is a 2002 (just looked up the VIN)
    This is the 2002 3.0 TCU scan:
    Address 02: Auto Trans Labels: 01V-927-156.lbl
    Part No: 4B0 927 156 FF
    Component: AG5 01V 3.0l5V USA 1213
    Coding: 0001002
    Shop #: WSC 03419 444 53463
    VCID: 70EF6851602FBB9E643-5106
    No fault code found.
    This is the 2003 A6 2.7T scan:
    Part No: 4B0 927 156 FE
    Component: AG5 01V 2.7l5VT USA 2222
    Coding: 01002
    Shop #: WSC 02325
    VCID: 6FED6B2D2D11A460C91
    05 Golf TDI
