B6 S4 w/ 122k miles. Battling a crank-no-start issue. In the past it has intermittently been rough to start - maybe only 2-3 times in the year and a half I've owned it, but would always start after a couple tries.
I've tested power to the fuse, and can confirm that the relay is "clicking" on. The tricky thing is there is no power to the pump harness when cranking, but when I hot wire the pump to the battery I don't hear anything. Leaning toward the pump being bad, but the no power to the harness part is stumping me.
Could it be a bigger problem than the pump? What are symptoms of timing chain issues? Would it even crank? It does not have any of the typical symptoms of a bad tensioner...
