Originally Posted by
baggednbangin
265 is narrower. It's that 275 width that will catch the fender. Either lower profile or narrower you're good. Just not 275/35, that's why nobody runs them, they rub. Not a lot, just enough.
ok. if 275/35/19 is a risk with 10" wheels, i now see i can go with 9.5" wheels for summer use.
tire rack has some rims that show the following:
Offset: 34mm
Backspacing: 6.46"
Bolt Pattern: 5-112
Rec. Tire Size: 255/35-19
Weight: 30.0lbs.
Finish: Machined w/Anthracite Accent
Construction: 1pc. Low Pressure Cast & Shot Peened
so i've just changed my OP question to - will 275/35/19 tires on the above 9.5" wheels rub?
i asked tire rack, and they won't commit to a no-rub answer. they said to ask you guys.
keep in mind - no change to stock suspension/calipers and rotors.
